Hello all, I am trying to resurrect a left for dead Mondial T. I do not have a WSM and it appears that the site that had them is no longer around. I am desperately trying to find out the fuel system specs, specifically the pump. How many PSI is it rated at, and how many LPH does it flow? I will use these specs to get the car waken from a 15 year slumber. I will be very grateful for the specs. I am posting here, as I am not getting the answer in the Mondial section. Thank you, and Happy Easter to those who observe it Rich
There should be 2 fuel pumps and two regulators. The early 348's ran 3.5 bar while the later ones updated to 3.8 bar. You should upgrade to the 3.8 bar version - 55 psi. The injectors are rated at about 200 cc per minute at 43.5 psi, or estimated at 220 cc per minute at 55 psi. You should upgrade to the 4-hole injectors we have discussed in the power mod thread.
