Need Help With Lift | Page 2 | FerrariChat
Need Help With Lift
Discussion in 'Detailing & Showroom' started by 3POINT8, Dec 29, 2021.
  1. Graz
    Graz Formula 3
    Oct 15, 2012
    2,333
    New Jersey and Florida
    Graziano
    I put a single post lift in by American Custom Lifts about 7 years ago and couldn't be happier with it. Its commercial grade quality, less obtrusive than a 4 post, and much easier to drive on and off due to wider ramps. Check them out.
    plastique999 and 3POINT8 like this.
  2. 3POINT8
    3POINT8 F1 Veteran
    5,468
    great thanks sir thats about what my garage will be like
  3. 3POINT8
    3POINT8 F1 Veteran
    5,468
    great tip thanks
    defiant likes this.
  4. 3POINT8
    3POINT8 F1 Veteran
    5,468
    another great tip thanks!
  5. 3POINT8
    3POINT8 F1 Veteran
    5,468
    will do
  6. Graz
    Graz Formula 3
    Oct 15, 2012
    2,333
    Graziano
    I found this Youtube video on the installation
    plastique999 likes this.
  7. JohnnyRay
    JohnnyRay F1 Rookie
    Nov 2, 2014
    3,707
    Central FL/NW WI
    For 4 post lifts, I recommend DirectLift. Owned by the same company as Rotary (commercial lifts), so a decent service network available - if needed. Have one of these in Wisconsin and am quite pleased with it. Just added a Triumph Classic in Florida, due in part to their unique short length. Functional, but not as nice as the DirectLift. Was lucky to get it one this year from anybody though, due to the shipping/supply chain dilemma. This was the last one my dealer could get...
    BTW - both of mine operate off of a 120V/20A circuit and no shop air needed. BendPak, on the other hand, is 220V and needs air to release the safety catches. Two negatives for that brand IMHO.
  8. nis1973
    nis1973 Formula Junior
    Jan 19, 2013
    494
    NYC/CT
    I got two 4 post lifts from DirectLift back in 2020. They appear to be very well made.
  9. 3POINT8
    3POINT8 F1 Veteran
    5,468
    thx direct looks like a great company. the height calculator on their site is very handy
  10. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    Is yours in Florida or NJ?
  11. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,871
    SoCal
    Edward
    Do they have to dig into the ground to stabilize the single post ?
  12. SirTony76
    SirTony76 Formula Junior
    Jan 18, 2004
    303
    MN
    When I ordered my bendpak they gave me the 220 vs 110 option, both were same price. This is true regarding an airline to release the locks.
  13. Graz
    Graz Formula 3
    Oct 15, 2012
    2,333
    Graziano
    No they don't have to dig. They do put bolts into the concrete (concrete should be at least 4" thick) to secure the plate and L shaped section.
  14. Graz
    Graz Formula 3
    Oct 15, 2012
    2,333
    Graziano
    Mine is in NJ
  15. plastique999
    Nov 9, 2008
    8,871
    SoCal
    Edward
    Awesome definitely going to look into this!
    Any pros and cons ?
  16. Graz
    Graz Formula 3
    Oct 15, 2012
    2,333
    Graziano
    Hi Edward, no cons that I can think of in its build quality and performance. Its great for storage and detailing. A full base instead of two separate ramps would be ideal but the ramps that come with it are pretty wide so its not difficult to drive on and off.
  17. nis1973
    Jan 19, 2013
    494
    NYC/CT
    One decisive con for me was that I have heated floors. Driving bolts into the concrete runs the risk of going through one of the pipes and ruining my heating system. Very clean solution otherwise.
  18. SirTony76
    Jan 18, 2004
    303
    MN
    For what its worth, the 4 post bendpak doesn't require you to bolt to the floor, but I believe it is recommended. I have the bolts and have debated doing it, but haven't been able to bring myself to drill my floor.
    I've never felt concerned with it not being bolted--however I definitely would if my wife was parking under it, but thankfully she is terrified to go on that side of the garage.
    AD211 likes this.
  19. nis1973
    Jan 19, 2013
    494
    NYC/CT
    My four post lifts aren't bolted either. That's the reason I got them.
    SirTony76 likes this.
  20. ItalianOne
    ItalianOne Formula Junior
    619
    Mich
    Kevin R
    Bendpak 4 post wide and very happy with it… Did not bolt down to the floor in case it needed to be moved.. which I think they make a special dolly for…not sure .. was a 220 version had to run a special plug to the breaker box.
