Need help with tail light one side out :( | FerrariChat
Discussion in '456/550/575' started by PRS Guitarist, Feb 7, 2017.
  1. PRS Guitarist
    PRS Guitarist Formula Junior
    Oct 13, 2013
    312
    Maryland
    Bob
    #1 PRS Guitarist, Feb 7, 2017
    Passenger (R) tail light is out. Here is what I have done.
    Bulbs changed- new bulbs work on left side old bulbs work on L side too.
    Fuse checked- Fuse good and swapped with L side just to be sure
    Reverse lights work- center bulb
    No power to harness (bottom 2 should show approx 24 v on the meter, L side good r side no voltage.
    Parking light button lights the lights on both side just fine. (Not a broken wire)
    Sooooo.... The left side rear tail light works when I turn the lights on but the right side only works when I engage the parking lights with the button on the console)
    2000 550 Maranello L hand drive (US).
    What have I not checked and what am I missing?
  2. 00 550
    00 550 Formula Junior
    Oct 20, 2009
    412
    FL
    That guy
    Not sure, but I had similar issues and it was a hot red wire in the tunnel harness. Jumped the connector and spliced it, no more problems
  3. PRS Guitarist
    Oct 13, 2013
    312
    Maryland
    Bob
    Will you elaborate on what you mean by jumped the connector and where was it located in the tunnel?
  4. 00 550
    Oct 20, 2009
    412
    FL
    That guy
    The connection in the tunnel harness was not making good contact. Narrowed it down to a red wire which i assume to be 12 volt. Cut it on both sides of the white male/female connector and spliced wire to "jump" the connection. My mechanic figured it out, took forever to find issue, I believe there was some blackening or other signs of poor connection at that site. Might be same as you but sounds similar
  5. 00 550
    Oct 20, 2009
    412
    FL
    That guy
    Have to take center console apart (easy). It was the harness that, at least in my car, was located on the right side of tunnel next to gear box. There are several connections in there. If you unplug the correct one I think all power to rear goes away, that was the one malfunctioning for me
