Need help with wireless network | FerrariChat
Discussion in 'Other Off Topic Forum' started by kdross, Apr 20, 2004.
  1. kdross
    kdross Formula Junior
    887
    NJ
    Ken
    I have a Linksys wireless network system (g system) at my office and my house that I use for Internet access for my laptop. Recently, the office below me and my neighbor have also installed a linksys wireless system. As a result, I get a message on my laptop that more than one signal is available and I then lose my connection to my network. I must then manual connect to the system again until I lose connection once again. How do I setup the network system so that I keep a constant signal and do not get cut off?
    I had a computer guy (technical term) change the settings to my office Linksys router were my router was renamed "linksys0". He also enabled the WEP security feature since other people with wireless cards could use my Internet connection. I can now see the two separate signals (linksys and linksys0), but I still get cut off from the signal. The unit at my house still shows just one unit ("linksys") since the router has not been renamed.
    Any suggestions would be appreciated in preventing my signal from getting cut off. Prior to the installation of the other units I never lost a signal to the router and did not experience any problems.
    Thanks.
    Ken
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,613
    E ' ' '/ F
    Enzo Gorlomi
    The two wireless networks are probably on the same channel. Have your tech switch the channel on your access point and your card and see if that resolves the issue
  3. spidr
    spidr Formula Junior
    Nov 13, 2003
    281
    Switch channel. Make sure WEP is enabled, use MAC filtering if you have to. You could also chosse"diable" for the other signal so it will not allow through
