need info for 1977 308 oil change please? | FerrariChat
Discussion in '308/328' started by blkdiablo33, Apr 26, 2017.
  1. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,461
    hi a friend of mine has a 77 308 whats eng oil capacity for oil,filter chaNGE?and do you guys rec 20/50 conv oil?is there only 1 eng oil drain plug when draining oil? thanks
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,595
    San Carlos, CA
    Mitchell Le
    20W50 if he lives someplace warm
    10W30 if he lives in Alaska
    There are 2 plugs, one is for gear oil, and one is for engine oil. He will want to drain the right one.
    He needs 10 qrts
    Filter is UFI or Baldwin, don't buy anything else.
  3. blkdiablo33
    Jul 12, 2004
    4,461
    thank you
  4. Rifledriver
    37,122
    I would suggest using dinosaur oil since it is an old iron cylinder car. They usually burn a lot if synthetic is used.
  5. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    I like Brad Penn oil. The green oil. Has a lot of zinc in it for the older cars.
  6. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    This is an oil thread in disguise. Are we being trolled?
  7. Vonbarron
    Vonbarron Formula 3
    2,263
    Westside Mofo
    S B
    Only Harley Davidson 20/50 is recommended in 2 valve cars. Science
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Bwahahaha!
  9. SJP 5
    SJP 5 Karting
    Jun 7, 2015
    93
    Do not forget the oil in the clutch transfer case.
    Separate drain and fill plugs.
  10. Rifledriver
    37,122
    He asked about motor oil. That is not for motor oil.
