need info on 348 A/C | FerrariChat
Discussion in '348/355' started by tamf328, Aug 29, 2006.
  1. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    A/C in my car is not working. controls seem correct. No errors, fans work correctly.
    the compressor clutch is not engaging, not is the condensor fan working.
    Anyone have a circuit diagram for those specifics or suggestions what to check?
    thanks in advance
  2. Ricambi America
    Sponsor Owner
    Got enough Freon?
  3. tamf328
    Mar 9, 2005
    477
    Yeah, I was suspecting one of 2 things, low pressure cut out switch (low freon)
    or some electrical screw up.
    the thing was working couple days ago. seemed to be all of a sudden.
    I don't have the circuit diagram to look for the problem.
  4. Standig
    Standig Karting
    May 13, 2002
    152
    Spring Hill, Fl
    Stan DiGuiseppi
    1st.. thing to do in diagnosiing a/c ...put gauges on and check pressures.... don't waste your time on electrical if the system is not charged.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Ding! Ding! Ding!
    What Standig and Daniel said above.
  6. tamf328
    Mar 9, 2005
    477
    right low freon, low pressure switch open on the dryer.
    I found it easier just to open up the cover over the dryer and check
    the low pressure switch. It was open, indicating low freon.
    took about 3 minutes to do.
    Thanks all for the help!
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Can you snap a photo of the above for the 348 Primer, please?
  8. tamf328
    Mar 9, 2005
    477
    Sure, I'll take some pictures tonight.
    Actually you and PAP are the ones that helped me. One of you guys posted part of a schematic at some point in time :))
    item 105 min/max pressure switch & evaporator control switch.
    If the low pressure switch is open the compressor clutch can't be engaged...
    safety thing. Was told that if you just turn on the key to on and push the A/C
    button on the control unit the compressor clutch will engage.
    I made sure the complete circuit was working by "jumping" the low pressure switch. You can also check the condesor fan and circuit by jumping the hi pressure side. You don't need to have the engine running.
    Where can I get a circuit diagram for a 348, I'm new to this car.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  10. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    We experienced another small problem this summer. The A/C does not work if you have more freon than the spec says. Should be betwen 950 gr up to 1000 gr. Not more.
    FloridaIsland348 likes this.
  11. PAP 348
    Dec 10, 2005
    100,219
    Mount Isa, Australia
    Pap
    That is correct. You never want to 'overgas' your A/C system. The compressor takes 210cc(.37pints) of compressor oil. :)
  12. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    Thank you for this post. I just replaced my solenoids 68 and 67 along with the hidden 30amp fuse, then put some more 134a in the system to what I thought was 40psi, but the AC compressor was not kicking in on victory ride. I feared I had connected the solenoid 67 wrong, but I read this post first, then double checked the high and low pressure with a different manifold. The pressure was too high and pressure switch was preventing the compressor clutch from kicking it. Everything seems to be fine now. Thanks Image Unavailable, Please Login Image Unavailable, Please Login
