Need instructions on removal of F355 front rotors? | FerrariChat
Discussion in '348/355' started by mjsdas, Dec 31, 2004.
  1. mjsdas
    mjsdas Rookie
    Jul 22, 2004
    27
    Connecticut
    Michael Sheridan
    Can anyone provide me with instructions on the remoal of the front rotors on an F355? I have a shop manual but it only provides instructions on changing the brake pads. I need to know how to remove the calipers and the proper torque settings for the bolts when reinstalled. Thanks for your help.
  2. tbakowsky
    tbakowsky F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    19,947
    The Cold North
    Tom
    Remove the 2 large bolts that mount the caliper to front wheel upright. But be awear of the shims. Count the shims that each bolt had and be sure to but them back in the right spot. Now lift off the caliper. On the rotor you will see 2 rubber "tits" around were the wheel bolt holes are. Remove the rubber, and undernieth you will find a 5 or 6mm allen head socket. Remove these bolts. The rotor should now just fall off.
    I can't remember the torque spec of had..but I THINK it is 65ftlbs.
