News
Need new front brakes discs on my F355
Discussion in 'Technical Q&A' started by yfc, Aug 5, 2004.
  1. yfc
    yfc Karting
    Dec 23, 2003
    212
    Geneva / Switzerland
    Christophe
    The front brakes discs on my F355 (97) are almost dead. I measured the following thickness on both front discs :
    - 26.12 mm on the right disc;
    - 26.28 mm on the left disc.
    If I don’t mistake me, the “Min TH” for the front discs of the F355 is 26.00 mm. Can someone confirm me the min thickness value?
    In order to get good performance at a good price (compared to the Ferrari’s option), I’m planning to order myself a pair of Brembo discs.
    On the Brembo Web site (www.brembo.com) I could only identify “AM” (After Market) discs for a street usage. Apparently, none of the “High Performance” products is allowed on the European open roads. Does anybody know if there is another Brembo product line authorized on the streets?
    Any experience with Brembo discs are welcome (lifetime, feeling, price, performance, … )?
    Lastly, I’m also interested by good address(es) in Europe where I can purchase the discs (idealy in Switzerland or France).
    Many thanks in advance for your advice.
    Bye,
    Christophe.
  3. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    992
    Outside of Boston
    Dennis
    FWIW, in the US, Gary Krumian (gary@interautoparts.com) has those Brembo rotors at $200/$180 apiece, about $90 cheaper than what Tire Rack is asking. He's been very helpful to me, and ships out quickly. Dunno what the shipping charges are to Switzerland or France.
    I just use the OEM Brembo disc - not drilled, not slotted. Works fine for me, and I get LOTS of track days out of them.
    vty,
    --Dennis
  4. Dino
    Dino Karting
    Nov 3, 2003
    116
    San Diego
    All I know is my factory pads on my 355 squealed horribly. They were replaced with Porterfield pad which don't squeal. I won't go with factory pads again...
    Dino
  5. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,273
    Switzerland (NW)
    Chris,
    Think twice about using noticeable non-OEM parts, a picky inspector at the DMV could easily notice that the discs are non-standard and ask for manufacturer homologation paper, same story as rims.
    Don't know how the guys are in Geneva, but in Lausanne ...
    Cheers, JC
  6. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    @Dennis,
    That's exactly the model I'm targetting. Plain not drilled, not slotted one.
    Thanks for your experience.
    @JC,
    I did not though about that to be frank.
    By looking for Brembo homologated products specific to the car, I thought that the local car inspection would not have been an issue.
    Could Brembo not provide the homologation papers ... if requested? This would eleviate the control issue.
    Any information about the min TH value?
    FYI I read 26.5mm in the Ferrari workshop book. But I'm not shure whether it's the lowest value for a disc rectification. Or if it's simply the min TH value.
    Bye guys,
    Christophe.
  8. f355b
    f355b Formula Junior
    Jan 23, 2004
    445
    Little Silver,NJ
    are the Bermbo crossed drilled rotors any good? i saw a set for $1460.00
    also the price you quoted for Bermbo rotors $200/$180 seems very cheap.
    i have also read you can if you want get these drilled for $35.00 a rotor.
  9. BigHead
    Oct 31, 2003
    992
    Outside of Boston
    Dennis
    But why would you want them drilled? They don't help cooling, they don't noticeably reduce weight (and here, the more mass, the better the disc can take the heat), and drilling weakens the rotor and shortens the life thereof. The holes do help clean the pads, but it's really not worth it. Buy the solid discs for $200, and save yourself a LOT of money - spend it on tires instead! :)
    vty,
    --Dennis
  10. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    No experience with Brembo discs so far?
  11. velocityengineer
    velocityengineer Formula Junior
    Nov 8, 2003
    488
    Globally
    Eric Dahl
    Try www.girodisc.com.
    Girodisc makes a great 2-piece replacement unit for about the same proce as the Brembo Oe replacement 1 piece.
    check the pic.
    Eric
  13. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    11,392
    MO
    velocityengineer, welcome to the site!
    Please take the time to fill out your profile.
    BTW absolutely stunning 355, which color is it? It cannot be G. Alloy is it?
  14. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    Thanks for all the valuable feedback / input.
    By the way, does anybody has the Ferrari product number of the standard front brake discs?
  15. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Christophe,
    Here is the data you require, basically as your discs are just above the 26mm mark there would be not enough material to machine them and keep above the minimum thickness of 26mm.
  16. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Velocityengineer,welcome to the site,if you check my profile you will see we have something in common.
    Dave Mc
  17. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    Thanks for the information Malcolm.
    Regards,
    Christophe.
  18. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,563
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Geezzzz ! Gestapo or what. Ya'll need to live in the US. We remove our cats when no one is looking ( not me or course ! ) :)
    Shamile
  19. cinquevalvole
    cinquevalvole Formula 3
    Feb 6, 2004
    1,149
    Germany, Bayern
    Hi Chistophe,
    stock is fine unless you go on the racetrack.
    How did the old discs behave around Andermatt?
    forza
    cinque
  20. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    @ Shamile,
    You are right!! It's simply anoying the way they control us here! But it's live ...
    @ Cinque,
    Since the pace was quite slow, I did not had any major problem in Andermatt. I was however getting some vibrations in the steering wheel when braking. But nothing very important.
    Last Friday, I got the front discs replaced. They were anyway only 0.2 mm above the lower limit. So since the local Ferrari dealer gave me a quite good price (only 20% more than for a similar job on my Volvo), I went for a replacement with stock (Brembo) discs.
    The feeling is now ... whouah. No vibration, good breaking. I'm almost re-discovering my car.
    The most important thing is that now I'm really paying attention to :
    - Cool down the discs before stoping the engine;
    - Not washing the car when hot.
    So. It should help avoiding to warp the discs again (luckily). :D
    Bye for now,
    Christophe.
  21. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    #18 yfc, Aug 29, 2004
    Before I brought my car to the dealer for the front discs replacement, I checked all fours wheels, discs, brakes pads, ...
    During this check-up, I noticed that my rear right brake disc has a crack (2cm long).
    It's quite surprising to get a crack on (1) Rear discs (2) that are not drilled. Did anybody had a similar problem on a F355?
    Christophe.
  22. cinquevalvole
    Feb 6, 2004
    1,149
    Germany, Bayern
    Hi Christophe,
    one case I remember: cracked disc + brocken wheel bearing.
    Maybe both to hot and the grease boiled out.
    Don't use the cracked rear disc any longer.
    Try to do "cool down laps" even after street use and never wash a hot 355.
    forza
    cinque
  23. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    I am a little late with this info, but thought some of you may still want the data as stamped on the edge of my front rotor.
    00 95A BB
    Min thickness 1.0236" or 26mm
    Brembo 160051 5L
    Regards,
    cwwhk
  24. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    Thanks to everybody for the feedback.
