Need OBD1 Codes | FerrariChat
Need OBD1 Codes
Discussion in '348/355' started by mgv1, May 12, 2007.
  1. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Hi All,
    I searched but have not been able to find them.
    Can anyone email me the OBD1 codes (I think the file is too big to post). I have a 95 355B and get an intermittant 5-8 check light.
    Also I forgot how to reset the light by pressing the button, so if someone would be good enogh to repeat the sequence I would appreciate it.
    Thanks in advance.
    Mark ([email protected])
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Did you run an advanced search of the archives yet???????
  3. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Yes Ernie, I've searched and the old forums too but I can't find anything. Also there was a thread where a guy told how to reset using the switch but I can't find that either.
    Anyone help?
  4. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Bump...
    I guess I should have put " I bet no one knows the OBD1 codes". Cum' on fellas I can't believe no one has these?
  5. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    isn't the 95 355 same motronic as the 348? (2.7)? If so, I think all the codes are on the humoungous 348 tech page that you can find at www.the348.com/technical/Tech/348.html towards the bottom
  6. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Thanks potxoli,
    I can't believe I never found that site before, tons of info and photos. Hopefully the codes are the same.
    I can't believe Ernie or Plugzit didn't know this. Obviously the power of the brotherhood is slipping away :)
  7. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I knew about the348.com
    We're not slipping it's just that, a lot of times people really don't look enough for things that have been already posted. Yes I know you looked but some times you need to try several different wordings. It seems that it's easier to post a redundant question that it is to spend the time looking for it.
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  9. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    You're welcome. That page is so big, that I've made a local copy on my mac to access it, makes it more tolerable. But it is a GREAT resource!
  10. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  13. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Ernie,
    Thanks for showing your search prowess but I came up with the 5.2 stuff too which doesn't apply to me as I'm OBD1 with the 2.7.
    Now, if you'd have kindly pointed out that I should have searched for 348 stuff because the codes are the same then that would have been educational.
    I was going to wear my 348/355 Brotherhood cap at VCR with plugzit to show solidarity but now I'm not so sure.....
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Good, because it's the 348 Brotherhood. We just let you 355 guys just tag along. ;)
