NEED PART NUMBER | FerrariChat
NEED PART NUMBER
Discussion in 'Technical Q&A' started by Dcup, Feb 8, 2005.
  1. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    hey guys, im going to repalce my ecu which is located behind the rear shock tower controls [1/4], any one have a part number and a pic? its for a 1990 348ts, thanks >>>> john
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #2 Ferrari_tech, Feb 8, 2005
    john,
    Haven't got a picture of the ignition module fitted to the car, only from the parts manual - the part number is 132216
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #3 Miltonian, Feb 8, 2005
    I think John is talking about the ECU for the exhaust thermocouple, not the Motronic ECU. The exhaust ECU is the one behind the shock tower.
    The part number is 142581 (unless it has been superceded), and it's the same part for either the left side or the right side. When I purchased these about four years ago, they listed for $307.82 each.
    Here is a picture of one removed from my car.
  4. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    thanks malcolm, this is the small black box behind the shock tower with 2 wire plugs coming from it ? if so, i just priced it and holly sh%t. 1900 us dollars. i did find one used for 550 us dollars, worth it ? to buy used that is.
  5. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    thats the one jeff [ exactly }, thanks, will get a price, thanks anyway malcolm.
  6. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    jeff where did you purchase the ecu, have a number ?? thanks bro!
  7. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #7 Miltonian, Feb 8, 2005
    We're talking about item #37 in this diagram.
    Come to think of it, there was a thread in the old Ferrari Chat about building your own exhaust ECU, using a hobby board and components from Radio Shack. If I remember correctly, you could adjust the ECU to trigger the overheat warning at different temperatures, depending on the variable resistance built into the system. I know there were pictures, but I don't remember how long ago it was (two years?) or who did it.
  8. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    John: I purchased mine at Ferrari of Seattle (206-329-7070) (www.ferrariofseattle.com), but any dealer should have these in stock, as they fail pretty regularly.
  9. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    TAHNKS BRO, YOU ALWAYS COME THROUGH FOR ME !!!!
  10. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You are welcome, Sir !
    I would have thought that a new Bosch Motronic 2.7 module would cost a lot more than $1900 ??? Was that a dealer quote?
  11. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    yes that was a dealer quote for new, also said he would knock a few bucks off if i needed it, hopefully i wont need that for a long long time.
  12. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #12 Miltonian, Feb 8, 2005
