Need Photoshop help with FCA logo... | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by rob lay, Feb 10, 2004.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,955
    Southlake, TX
    Rob Lay
    I need a 600 dpi black & white version of this logo for some FCA concours trophies, but I have no idea how to do it. Please help out by giving me directions or doing the edit yourself.
    Thanks!
    rob
  2. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    #2 Chiaro_Slag, Feb 10, 2004
  3. MikeZ_NJ
    MikeZ_NJ Formula 3
    Dec 10, 2002
    1,533
    Southern NJ
    Mike Z.
    #3 MikeZ_NJ, Feb 10, 2004
  4. MikeZ_NJ
    MikeZ_NJ Formula 3
    Dec 10, 2002
    1,533
    Southern NJ
    Mike Z.
    FYI, just do a select all, copy, then create a new image that's 600 dpi that is the same size and paste it in there. Then Image -> Mode -> Greyscale.
  5. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    Maybe this person can help. He publishes the FCA News Bulletiin in Florida. His first name is David.
    [email protected]
  6. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    rob - that's gonna look like sheeite when you print it. you need a better (larger or better-scanned) source image to scale to 600dpi for printing.
    doody.
  7. Robin
    Robin F1 Rookie
    Nov 1, 2003
    2,931
    Arlington, VA
    Lemme in.. I'm a professional :)
    First off, to change the dpi (dots per inch for whoever asked) in Photoshop, just go to image/image size and change the 'resolution' setting. Second, Doody's right, it'll probably look like crap. Increasing the resolution won't make it look any better, since the computer can't make anything that's not already there.. it just inteprets what it has to work with. Crap in, crap out. If this is going to be printed on a trophy, and therefore only be an inch tall or so, you might be ok....but your best bet is to find a higher resolution image to begin with, or scan a picture of one at the resolution you need, or get someone to convert it to a vector format that can be printed 100 feet tall and still look good..
    -R
  8. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    Yeah, you need to convert it to vector graphics format before you scale it up. Otherwise, the dots become increasingly bigger blocks until you end up with something that looks like it was made out of brickwork.
  9. rob lay
    Dec 1, 2000
    63,955
    Southlake, TX
    Rob Lay
    Thank you very much everyone!
    Yes, it's only for some very small trophies and will only be about an inch high. This will be perfect.
    Thanks again.
  10. rob lay
    Dec 1, 2000
    63,955
    Southlake, TX
    Rob Lay
    Actually, the grey scale wouldn't even work for them, they needed black & white. They just did the photo work themselves. Here it is if anyone needs it in the future...
  11. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    What's with the donut holes in the 'e' and the 'a' of 'Ferrari'?
    I think I have that in vector form and can produce any size you want if you need it again in the future.
    Brian
  12. ForzaFerrari
    ForzaFerrari F1 Veteran
    Jul 25, 2003
    7,198
    The Netherlands
    Waldo
    Rob...
    can't you just ask FCA for the Illustrator file? Then you don't have to worry about dpi.
    Ow..and may I ask why 600 dpi. Most (almost every) print is made at 300 dpi, not 600 :confused:
    ciao,
    Waldo
    ForzaRossa.nl
