Need pictures of Fuel Distributor (328 GTS) | FerrariChat
Discussion in 'Technical Q&A' started by tfrancis, Mar 6, 2004.
  1. tfrancis
    tfrancis Karting
    Nov 3, 2003
    93
    Memphis, TN
    I have a 1986 328 GTS. I'm rebuilding my Fuel Distributor and putting it back on the car. I don't have clear pictures of how the Starter Assembly and Warm-up Regulator attach. Any help / pictures would be appreciated.
    Thanks,
    Tom
  3. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    If you call me I can tell you how to fix this. Not to sound arrogant but you will need my services before your car will run without catching fire anyway. My business is rebuilding fuel distributors, and it cant be done without the proper equipment. Also yours should be made of cast iron # 0 438 100 139 and these take special steps to seal against leaks.
    Larry Fletcher
    251-929-3771
  4. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Tom
    Hope these diagrams help,
    First diagram :-
    A=to fuel injectors
    B= to warm up regulator
    C= from warm up regulator
    D= to cold start injector
    E= from fuel filter
    F= return to fuel tank
    Second diagram :-
    A= vacuum connection to the inlet manifold
    B= return to fuel tank
    C= from fuel distributor
    MW
  5. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Sorry about the quality of the third picture / text will have another try
    MW
  6. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Larry:
    "Not to sound arrogant but you will need my services before your car will run without catching fire"
    Hmmm...
    I met Tom in Memphis, and helped him get setup for a wonderful Ferrari
    event a while back.
    Not only is Tom an easy going, genuinely nice guy...
    But I have also admired the wrench turning he has performed on his 328.
    I think he will be just fine with this project.
    ..... Dave not sucking up to Tom in hopes of using his powder coating system.
  7. fletch62
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    Rebuilding fuel distributors is not that hard if you know how. It is like anything that someone learned to do, they had to spend lots of time and have the right tools. There are many good mechanics out there, but that does not mean they can rebuild a fuel distributor properly. Just like there are many Heart Surgeons that can't do a root canal.
    Larry
