need quick advice | FerrariChat
need quick advice
Discussion in '308/328' started by manta147, Aug 7, 2013.
  1. manta147
    manta147 Karting
    Sep 7, 2006
    128
    seekonk,mass
    carter petter
    Hey Guys,
    What's the secret to removing the front cam cover?Do I need to move the fuel distb?It's unbolted and I can slide it to the top of the studs,but then get blocked by the F.D.......
    It's an '82 GTSI......what am I missing?
    Thanks in advance.
    Carter
  2. italianjoe
    italianjoe Formula Junior
    Jun 30, 2010
    295
    dearborn heights mi
    joe
    try removing the stud before you try to remove the cover..........two nuts lock together at the end of the stud will help to remove the stud from the block.
  3. manta147
    manta147 Karting
    Sep 7, 2006
    128
    seekonk,mass
    carter petter
    Thanks Joe.Just got the cover off.Had to remove the F.D. from the mount,and slid the cover up and over the studs and over to the pass side.Frustrating......removing the cam cover was never taken into consideration when they put the F.D. in that spot.
    Carter
