Need recommendation for Garage Door Installer | FerrariChat
Discussion in 'New York Tri-State' started by testarossa717, Feb 12, 2012.
  1. testarossa717
    testarossa717 Formula Junior
    Jan 13, 2007
    263
    NY/NJ
    Antonio
    I started my garage project already and am on my way to an 11 foot one inch ceiling . After I finish, I will look to spackle/tape and paint and then onto the floor. I picked up MotoFloor (Black and White Tile Pattern) at Costco. The paint scheme is going to be Sky Blue Benjamin Moore for the walls and flat white for the ceiling. I am going to add some diamond plate trim to finish it off.
    When finished, the dimensions will be 10 1/2 wide by 16 feet long(to the staircase) by 11 feet high. LOL I guess it's like every project. You start off with one upgrade in mind and you end up with a huge project. I believe I should be finished in about a week. Then onto flush mounted fluorescent lights.
    If anyone knows of any good local garage door installer in Monmouth County NJ, please let me know. I need to change my garage door standard opening track to a high lift track to take advantage of the 11 foot ceilings in my garage for my new four post car lift that I will be buying. I also want a garage door opener installed.
    Thanks Again guys.
  2. 328turbo
    328turbo Formula Junior
    Jun 15, 2009
    306
    nyc
    http://www.christieoverheaddoor.com/
    These guys are located in Staten Island, but being that they serve all of NYC, I'm sure where you are in NJ shouldn't be a problem.
    These guys are great and can do any custom application for garage/overhead doors or electric gates.
  3. testarossa717
    Jan 13, 2007
    263
    NY/NJ
    Antonio
    Thanks 328, I will give him a call.
  4. HH11
    HH11 F1 Rookie
    3,344
    I tried to respond to your PM but it says your inbox is full.
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Just freshening this thread as I need the same job as Antonio done in Monmouth County as well. Any leads would be appreciated.
  6. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Bob- These guys did my side mount motor/re-route rails when I got my lift a few years ago. I subsequently used them to repair the garage door lift on the other side of my garage- very friendly, great work and prices. I don't know how far they travel- they are located in Fairfield NJ:
    Door to Door | Garage Doors and Openers, Fairfield, NJ
  7. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Thank you Andrew. I just contracted with an outfit to do it. Seem very knowledgeable and repaired my current door a couple times and I was very pleased with them.
    $1450 for the modification. All new tracks, new torsion type spring across the front of the garage ( has the two side springs now, side mounted jack screw lift. I'm Ok with that.
    Ceiling height is 118, current door is at 83. He said he will get with 6 inches total of available height, so 112. Should work well.
    Found a guy to move the lift on referral from a fellow fchat person as well. Strong referral and I think all will go smoothly. I'll post names , etc. after the job is done if all goes well as I think it will.
