Need some help...caliper spacer washers? | FerrariChat
Discussion in '348/355' started by Badabing!, Aug 14, 2015.
  1. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    I just removed the right rear caliper off my 97 F355 as part of pulling the axle shaft to replace torn boots.
    As I removed the caliper bolts, washers fell to the ground. I wasn't sure how they go back so I checked The parts diagram and I see they sell them in different thicknesses (fractions of a mm). I'm not sure which washers came from where and now I'm not sure how to put it back together.
    As far as I can tell, there are 2 really thin washers and 2 that are a bit thicker.
    Can anyone tell me where they go?
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,739
    You want the caliper shimmed so that it is centered on the rotor to within 0.005" and parallel to the rotor to within 0.003".
    It does not mater which order you think the washers go, you need to hit this spec.
  3. Badabing!
    Mar 30, 2014
    731
    NYC
    How do you go about doing this?
