Need some help from the F430 Guru's | FerrariChat
Discussion in '360/430' started by boba fett, May 28, 2025.
  1. boba fett
    boba fett Formula 3
    1,081
    England UK
    Hi I have just been fitting my X-Pipe, and all was going well, then when doing up the bolts "snap" one has broken off, and its one thats a stud welded on from the bottom.
    I have removed the exhaust and cut off the remaining thread that is stuck out, and I am attempting to drill out the rest of the bolt, buy my god I have no idea what its made of, but I am only half way through, running off centre and its taken out about 10 drill bits!!
    Any suggestions?
  2. boba fett
    boba fett Formula 3
    1,081
    England UK
  3. Mario Andretti
    Mario Andretti Formula 3
    1,765
    Boston
    Go with a smaller bit and try to get through next to the bolt, then use bigger and bigger until you can punch it out . U have enough "meat" in that lip to be able to tighten it after...
  4. boba fett
    boba fett Formula 3
    1,081
    England UK
    Thanks, I've tried that, and it just melts the drill bit or snaps them! Think I might need to buy some expensive drill bits! Looks like cobalt ones are needed!
  5. GogglesPisano
    GogglesPisano F1 Rookie
    3,115
    East Bay, California
    Joe
    Make sure you’re spraying that with some type of lubricant while drilling. You likely already smoked the bit. You should be using hardened steel bits made for metal. Might be quicker to make a quick run to harbor freight or your local auto parts store and get the proper bit.
  6. swc5150
    swc5150 Formula Junior
    702
    Wisconsin
    Scott Calderwood
    Glad the x pipe showed up. Sorry the bolt snapped, easy fix though with lube and the right bit.
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,766
    England
    Mark
    Use angle grider with a thin cutting disc to remove the two welds that are holding the bolt in place.
    aventari likes this.
  8. Mario Andretti
    1,765
    Boston
    He's in UK :)
  9. aventari
    aventari Karting
    Dec 9, 2010
    151
    San Diego
    Yeah easier to cut the weld
  10. GogglesPisano
    3,115
    Joe
    Ahh. Then Machine Mart :D
  11. boba fett
    boba fett Formula 3
    1,081
    England UK
    I’ve got one but the welds would be very difficult to get to in if you see where they are, and given the look of the exhaust clamp, I’d rather pass on removing the tailpipes to do it!
  12. boba fett
    boba fett Formula 3
    1,081
    England UK
    Yes got it thanks, went straight to fit it and then this! I did start her up and it was very loud even with the valves on quiet!
  13. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Boba Fett, if needed, hit me up and I can fix any CEL's and make the car drive better than a 430 Scuderia once you resolve your fitment challenges :)
    swc5150 likes this.
  14. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    756
    Bollenstreek - Netherlands
    Jeroen
    Try using cobalt drill's, we found those the best way to get through bolts seized and snapped on a Jag we are restoring
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,936
    Isle of man- uk
    It has gone hard due to it been welded
  16. boba fett
    boba fett Formula 3
    1,081
    England UK
    Well my local agent can sort it!
    Not sure to put a difference post up on my thoughts of the X-Pipe with headers.
    I quite liked the old set up I had before, headers and standard exhaust with Remote valves. That was more bassy and louder, but at low revs under say 2.5k and pulling away, it did not make a nice noise, almost like a crude bassy, farty, spitty noise and like the exhaust was blowing. Up in higher RPM it was very noisy but also very nice. A point to note, I do miss the titanium sounding howl it used to do at around 3k revs. I thought that was very nice, and it does not pop and bang so much on the overrun.
    I've put the exhaust on, and it certainly is more high pitched, its very F1 sound. I need to do a tunnel run! The X-Pipe is quieter which is a surprise! It is now more of a refined sound at lower revs, and from in the car. Further up the revs it is more F1 high pitch scream once over 5k revs. The valves also work the opposite way as most other cars, and you cannot keep the valves shut, even with remotes because the ECU tells them to open, when you start putting your foot down. So until it can be coded (if I decide to keep it this way) I have strapped them closed so the X-Pipe is in play. One thing I could not stand with completely standard set up was the valves opening and closing with the gas pedal, its awful, on off, on off, noisy, quiet, noisy, quiet, made it sound like the car is broken!
    I like both, and it leaves me thinking was it worth it. I need more time at the wheel and I am off to a Ferrari meet soon get some opinions!
