Need some help on removing clutch slave (please) | FerrariChat
Discussion in 'Mondial' started by tdskip, Jun 11, 2024.
  1. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    #1 tdskip, Jun 11, 2024
    Got this far - how does the renowned come off the car?
    I am assuming the aluminum block stays on the car and the clutch slave hydraulic assembly is removed from the top once the large circlip is removed?
    If it pulls up and out won’t it fowl the top of the engine?
  2. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Ah - looks like I need to gently open the housing (maybe with a screw driver) and it will come out through the top?
  3. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
    If it is to change the seal, not needed to remove the entire pump. If you need to remove the pump, like you mentioned, remove circlips above and it should come out to the top. But not easy !, Try to heat up the alu housing without burning the wires around. And with a piece of wood, beat on the outer ring of the lower side pump.
  4. Rifledriver
    36,938
    #4 Rifledriver, Jun 12, 2024
    I do not recall ever removing a circlip with slave in place. Take out entire assembly.
    It has been quite a while but I just do not recall it being very difficult.
    It looks like the nuts were over tightened and completely closed the split in the clamp. That may be causing binding on the studs which might require some prying to get it off.
  5. theunissenguido
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
  6. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    542
    NYC
    Joe
    why would you remove the circlip and pull it out of the aluminum housing rather than remove two M8 nuts and just pull it all off together (with the aluminum housing)?
  7. 85QVEuro
    Jan 15, 2021
    542
    NYC
    Joe
  8. 85QVEuro
    Jan 15, 2021
    542
    NYC
    Joe
    Also, upon re-installation, it should be much easier to get the aluminum housing back on the two studs as opposed to trying to get the circlip back on in that tight space....
    Rifledriver likes this.
  9. theunissenguido
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
    Most of the time those studs are fused with the alu inside the housing holes so impossible to remove without braking something.
  10. 85QVEuro
    Jan 15, 2021
    542
    NYC
    Joe
    If that's the case, maybe some PB Blaster in the opening in the aluminum bracket followed by a large screwdriver from the top in that groove to gently open the bracket - mine came right off but I get what you are saying...
  11. Rifledriver
    36,938
    Never experienced that. On a Boxer either. They have always come off by hand.
  12. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Thank you for all of the responses and coaching.
    First time turning a wrench on this so it is all new to me, but the aluminum block that houses the slave should just pull off once the two bolts are removed?
  13. 85QVEuro
    Jan 15, 2021
    542
    NYC
    Joe
    You have the two nuts off. Provided the fluid line and linkage are disconnected, you should be able to just pull off the aluminum housing with the clutch slave - should slide right off those two studs
    moysiuan likes this.
  14. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Thank you
  15. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Life got in the way so just picking this back up now and that housing is properly stuck in place, tried carefully knocking it loose and it isn't moving at all.
  16. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
  17. 350HPMondial
    350HPMondial F1 Veteran
    5,316
    Edwardo
    Yes it’s tight,, put car on Jack stands,
    Disconnect and move wires out of the way.
    Time to clean those connections,, tape and bag them. ,,
    Then,
    I use a standard pry bar-nail puller type.
    next ,, I think I used a broom stick ,, like 18” long,,, pry it off.
    note; When you re-install it,, drill out those two holes. There is No need, for them to be that precise,, other then to,, Stick like Glue.
  18. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Excellent tip, will slightly enlarge the openings. Was also thinking that anti-sieze would be a good idea too.
    Think I can have this welded back together (making sure the dimensions stay the same)? I have access to people who are good at TIG welding.
    Thanks!
  19. theunissenguido
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
    I warned you something can brake ! It can be welded back and there is need to be perfect. Pump is secured with that span ring.
  20. theunissenguido
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
    ....."there is need to be perfect"...must be " there is NO need to be perfect" !!
    You are lucky you did not brake the engine case bolt mountings. That would be a disaster. And those who mention "They have always come off by hand.", o_O
  21. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    I think what happened is that the slave cylinder, not the hose, went bad and the leaking fluid got into the openings for the bolts and then seized everything together.
    I didn't use that much force so it may have already been fatigued.
    I will try getting it repaired.
    I assume that anti-seize on the case mounting bolts would be a good idea?
    Thank you for the help/support, hope everyone is having a good weekend.
  22. theunissenguido
    Jan 21, 2004
    2,621
    Argent/Brasil
    Guido
    When the slave seal leak it will flow under that pump, not going up to the bolts. That is why I mentioned not to try open that bracket but push pump up wards leaving that bracket untouched. This Alu material is very bridle. I try to leave pump and bracket untouched and only replace the seal in situ from the underside.
    Alden likes this.
  23. tdskip
    tdskip Karting
    Aug 25, 2012
    185
    SoCal
    Tom
    Hello!
    My bolt openings has fluid in them for whatever reason, and the inside of the housing was also covered in fluid. I did try gentle rapping the bottom of the cylinder to remove it that way but it did not want to move either.
    I think a little bit of anti-seize on the opening where the cylinder fits might be a good idea too since the method you have described would have saved a lot of effort.
    Thank you and everyone again for the information/methods.
  24. moysiuan
    moysiuan F1 Rookie
    4,137
    Canada
    Wow, that is unexpected! I will definitely put some antisieze on that surface next time I do this job. I guess the brake fluid attracts moisture, and then seeps in and causes things to corrode/galvanic action.
  25. CAustinWillis
    CAustinWillis Rookie
    Aug 19, 2024
    7
    Charles Willis
    i just replaced my slave cyl on my car ... i just purchased the car on 31 july 24 . i got it back to my home and found on inspection it leaking ... the repair went easy , what did shock me was my brake fluid was clean in the master cyl , but nasty in slave ... I am thinking that whomever had been flushing the brakes could not connect that the fluid in slave should be flushed at same time brake fluid is changed .... I am writing this as a warning ... next time you have your brake fluid serviced ... make certain your tech is doing the clutch bleeding too... I feel this whole experience was unnecessary if the tech had done a complete brake fluid replacement ... not just the 4 wheel calipers....
    tdskip likes this.
