Need some help with my paint brothers | FerrariChat
Discussion in '348/355' started by md0811usmc, Apr 18, 2008.
  1. md0811usmc
    md0811usmc Karting
    Feb 21, 2006
    75
    Reading, Pa
    Marco Decamillo
    Hello, I have a 1991 348 and noticed yesterday that I have alot of swirl marks in my paint. It was very bright out and in direct sunlight it looked horrible. Is there any way to get rid of them. I tried a porter cale buffing machine and it helped, but did not take them out all the way. Any suggestions without getting crazy?
  2. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    I would get a professional detailer with a good record to fix it.
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    +1
    And then do proper washing and waxing techniques to prevent them from happening again in the future.
    BT
  4. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    is there the cliff notes version of these techniques somewhere? I'm getting a professional detail tomorrow, and want to keep it looking new after, but all the posts I've seen are like an encyclopedia....I need the dummies version :)
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    UserID Tropicaldetail has covered a lot of this in recent months, mostly in the Ferrari Discussion forum. He seems to be a true professional expert and artist in this field. Here's a link to search for his threads..
    http://www.ferrarichat.com/forum/search.php?searchid=2224675
    Let us know how things work out :)
  6. LamboBully
    LamboBully Karting
    Apr 24, 2007
    56
    Sioux Falls, SD
    Brett Keller
    I had a diablo in with the same problem. I ended up doing a 4 stage buffing process to get it out. Well worth to have a professional detailer to fix it.
  7. md0811usmc
    md0811usmc Karting
    Feb 21, 2006
    75
    Reading, Pa
    Marco Decamillo
    Anyone know a professional detailer in the area of Reading, Pa?
  8. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    try posting on the mid-atlantic forum. I'm sure they will give you good recommendations.
  9. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    Marc, Marc, dude!
    Do it yourself. You can use a decent wash, like Maguires or Mothers. Polish with HD Cleanse from Zymol. Finish with a few coats of Zymol or Griott's carnuba wax. Apply with your hands. Zymol is removed before it dries with a clean T-Shirt and Griott's is removed after it dries to a hazy white powder. If you feel the need to go further, there is wheel polish and fiberglass polish for those parts of your ride. Just dedicate an afternoon. Wash the car, drive it down the block and do a few 360's to spin off the water. Dry iit off and let it sit for an hour or 2. Then attack it with the Zymol or Griott's products.
    The swirl is aged wax residue and you need to take it off before applying the new wax.
    BTW, the best glass cleaner in the world is hot, hot water (like you can barely stand it) with 1-2 drops of dishwashing soap in per gallon (holds the dirt in suspension). Apply with a wash cloth dipped and wrung out. Do small areas, interior first. Dry immediately with no-lint terry cloth. Change the water when it looks hazy. I do all the interiors, change water then do the exteriors. If you feel you must use chemicals, try mxing up your own alcohol and distilled water mixture 1-3 I think. It's not necessary and it will eventually dry out the trim rubber.
