need some helpful advice | FerrariChat
Discussion in 'Canada' started by cmb, Jan 29, 2005.
  1. cmb
    cmb Karting
    Mar 19, 2004
    52
    Toronto
    my car's been stored since nov of last year.
    under cover
    battery unhooked
    now, i decided that i would rearrange the cars in my garage, and wanted to move the ferrari.
    however, i can't seem to get the doors open.
    my garage is currently not heated (though i will do the rennovations this spring - for next winter)
    are my doors frozen shut?
    i put the key in, turn it and pull the handle and nothing. neither door will budge.
    seeing as the battery is unhooked, i can't use the remote.
    what do i do now?
    i've placed a little heater by the door to see if that'll correct the problem, but it's slow going.
    (one thing i did is unhook the battery, close the hood, and then use the key to manualy lock the doors back when i first stored it. do the door locks require power to open? if so...i'm up the creek)
    any advice would be greatly appreciated!
  2. cmb
    cmb Karting
    Mar 19, 2004
    52
    Toronto
    actually,
    it might be frozen. i remember cleaning it sometime in december on one of the warm days and probably moisture remained and froze when it got colder.
    whoops.
    the heaters are still going..we'll have to see.
  3. evansp60
    evansp60 Formula Junior
    Nov 2, 2003
    384
    Ottawa, Ont. CANADA
    Be gentle! You do not want to tear the rubber stripping on the frame. A pain to replace (and expensive).
  4. cmb
    cmb Karting
    Mar 19, 2004
    52
    Toronto
    thanks.
    well the heaters brought the garage up to 10+ degrees and the doors opened fine. (must've been frozen).
    she got a brief stroll on the driveway and street and then back to hibernation. LOL!
    i too can't wait for the warm days of spring to arrive.
  5. KoenigFerrari
    Feb 16, 2004
    56
    Next time, you should use WD-40. You spray it inside the key hole and door locks through the door gap. It acts like an anti-freeze without damaging your car. It works fine for me with frozen doors.
  6. cmb
    cmb Karting
    Mar 19, 2004
    52
    Toronto
    thanks for the info. :)
