need suggestions | FerrariChat
need suggestions
Discussion in 'Ferrari Discussion (not model specific)' started by coledoggy, Nov 4, 2009.
  1. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    #1 coledoggy, Nov 4, 2009
    not sure what this dark stuff that wont rub off on my ferrari engine letters is. does anybody have any idea whats going on here and suggestions to fix it?
    by the way i live in south mississippi, hot and humid. the car is always garaged. i dont live close to salt water either.
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Looks like oxidation. Get some aluminum polish and try to ge it cleaned up.
  3. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    what should i use the aluminum polish with, towel, fine sand paper?
  4. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    It looks like some oxidation to the aluminum. It is just a naked finish with no clear coat on top. This is wHat i would do;
    1. Tape off the area around the badge to protect the red wrinkle coat.
    2. Use and aluminum polish ( mothers, mequires, zymoil ) with a cloth to
    polish each letter.
    3. If the staining is too deep you can wet sand it with 800-1000 grit, using the paper on a block to keep the surface level. Then go back over the area with the polish.
    optional.:
    ..Once you polish it to your liking I would clean the area with a de-greaser and dry throughly.
    take a lint free polishing cloth and spray some high-temp clear coat on it and dab it onto the letters with a few light coats.
  5. mellymel
    mellymel Guest
    Nov 4, 2009
    23
    Lodi, NJ
    Melissa Duffy
    Hey
    That is the aluminum oxidizing. The clear coat gets chipped or cracks from the heat and the elements get under and oxidize the aluminum. The best way to correct it. You need to get very fine sand paper or emery clothe and wrap it around a small block of wood and sand the letters evenly. Then you have to clear coat them but most likely will just happen again or the best bet is to wipe it down every so often with WD-40 after you sand it down.
    Melissa
  6. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    i would not use sandpaper.
  7. mellymel
    mellymel Guest
    Nov 4, 2009
    23
    Lodi, NJ
    Melissa Duffy
    The oxidization has etched itself into the aluminum and a very FINE sandpaper will remove the surface corrosion and bring the shine back. Much like wet sanding a car finish when its dull or scratched. I do it all the time, especially when I do a major and repaint the valve covers. It shines better then new.
    Melissa
  8. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,049
    Coolum Beach AUSTRALIA
    Karen H.
    Try liquid "Autosol" metal polish - gentle but effective; I live right by the ocean and use this on all sorts of polished aluminium/chrome/stainless bits.
  9. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    Now that I think of it, you are right. A very fine, I think it's called 1000 or 1500 (or something like that) whatever is the one that bodyshops use on the clearcoat to take out blemishes.
