need thoughts on 456 troubles | FerrariChat
Discussion in '456/550/575' started by ross, Nov 1, 2017.
  1. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,982
    houston/geneva
    Ross
    the 456mgta that we bought for my mother a couple months ago has developed a recurring CEL light that we have tracked down to occasional misfire in three cylinders on the left bank.
    the possible causes could be the spark plugs, the lead wires, or the coils.
    i dont think it is the plugs, just because they have recently been changed.
    it might be the leads since this car has lived its entire life in the heat in florida, texas, and cali.
    coils? are they susceptible?
    thoughts?
    second issue
    seat potentiometer. i need one. i will call ricambi tomorrow. but in the meantime, does anybody have a spare used one they would like to sell me?
  2. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    My money is on the wires, esp if they are the originals.
    John Cribb told me they are an eventual trouble spot.
    They have a COP solution available on their website.
    I’d look at the wires first.
  3. asgor
    asgor Formula Junior
    Sep 8, 2016
    716
    Virginia, USA
    Had a similar problem a few weeks ago. I thought the plugs very beyond reproach, as they are only 15K miles old (replaced 9 years ago by the previous owner!) but decided to changed them anyway. They were COOKED - DONE - KAPUT! I couldn't believe the engine was actually still running on those things. I swapped the old Champion plugs with new Denso Iridiums and now she purrs like a kitten. No more misfire codes.
    My take: start with the easiest potential solution first.
  4. Cribbj
    Cribbj Formula 3
    Can't believe your car was still using the Champions. Those things went out years ago, along with points and distributors :).
    I liked, and had always used Denso Iridiums in my boosted cars, but they didn't seem to idle as smoothly in the Ferrari as the NGK's, so I reverted back to the NGK's. Just MHO.
    To the OP, yes, check your plugs first before investing in a new set of wires or a new COP system.
  5. tazandjan
    39,174
    John- I am running the NGK iridium plugs, too. The NGK plugs that came out of her a couple of years ago still looked good.
  6. 348SStb
    348SStb F1 Rookie
    Forget the seat potentiometer. The price will cause you to want to hang yourself. Nevermind the labor to install the thing, which is also horrendous if the seat has to come out.
    There is a workaround that may work for you, depending on your problem. Sometimes, my seat motors would decide they didn't want to move the seats forward and back. I would say once out of 50 tries, the seat would say, "screw you." I discovered a clever trick. If I got out of the car, lifted the lever at the rear of the backrest and moved the backrest forward as if I were entering the rear seat, and then attempted to move the seat forward and back using the forward/back seat movement button while the seat backrest was positioned forward, this maneuver would reset the seat. The seat would then operate normally while driving until the next random "screw you."
  7. ross
    Mar 25, 2002
    37,982
    houston/geneva
    Ross
    i will try that !
    i did find a seat potentiometer for $250.
    if an alternative fix works, i can probably resell that part since they are virtually impossible to find.
    as for the other stuff, we are swapping out the plugs and coil pack. thats the least cost path since the labor is the same for both.
  8. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    This helped me after my father of all people tilted the seat and used the seat switch to move it forward with the switch, the seat wouldn't go backwards after the seat back locked in. I tiled the seat and moved it all the way back.. bingo all good.
  9. ross
    Mar 25, 2002
    37,982
    houston/geneva
    Ross
    turns out the seat problem was a small metal cylinder of indeterminate origin was somehow caught in the track. it was removed, and the potentiometer works just fine.
    now we need to figure out where that little cylinder came from ! (roughly 8 mil tall, outer area ridged, inner section not threaded).
    looks like misfire was the coil pack. but needs to be tested now that the seat is back in it.
  10. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Have a picture?
  11. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Not sure about 456's, but a regular seat runner is two inverted channel sections with a couple of rollers taking the weight, and held by ball bearings trapped in opposed concave sections on the sides of the U channel. Might be worth folding your body into a pretzel and having a peek under there (I doubt it's in a parts diagram)
