Need to achieve a high tightening torque | FerrariChat
Discussion in 'Technical Q&A' started by swift53, Mar 5, 2021.
  1. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Have to tighten a 41mm nut onto a crankshaft to about 360 ft/lb.
    This has been suggested :
    "360 ft/lbs , roughly 500nm? So 50kg force applied at 1m along steel bar , with socket attached the other end. This can be measured different ways or at different distances eg 2m = 25 kg
    Use luggage scales or fish scales etc , hook end around bar by your own method and pull on bar with scales until you get the magic figure"
    I have some left over 2m, one inch bars, I can weld a 3/4" stubby extension to tip and not kill the socket that way, then go!
    Opinions? To me it makes perfect sense, and much cheaper than another torque wrench...
    Regards, Alberto
  2. Redneck Slim
    Redneck Slim Formula 3
    1,451
    Palo Alto,CA,USA
    Walt Kimball
    Auto parts stores like O'Reilly and Autozone lend tools.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    I used an analog bathroom weight scale.
    I stand on the scale, read the value (for example 200lbs)
    I use a long 1/2 ratchet with a cheater bar to make 3 ft long wrench.
    Push down at the 3 ft mark on the wrench, (horizontally on the cheater bar) until the scale reads 80 lbs. At that point, the torque is 120 lbs times 3 ft, or 360 lb ft.
    Having said all that, I own a 4 foot long 3/4 inch torque wrench for this purpose.
    JL350 and greg328 like this.
  4. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,760
    Western Mass
    Raimondo
    That’s really smart. I usually learn from your posts!
    greg328 likes this.
  5. INRange
    INRange F1 World Champ
    10,202
    Virginia/Florida/Caymans
    JD
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    #6 flash32, Mar 5, 2021
    Majin_JT, lm2504me and swift53 like this.
  7. fatbillybob
    Aug 10, 2002
    26,419
    socal
    I like using the right tools.
    2NA and Redneck Slim like this.
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,178
    Austin, TX USA
    Greg
    That torque measuring device is only rated to 147.5 lb/ft. You’ll need a heavier-duty one..
  9. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,264
    MA
    Yep! When I had to rebuild the rear hubs on my former Porsche 930 bought a Large 3/4" Drive Torque Wrench to meet the 250 Ft lb requirement. Then used a lot on my former Center Lock TR. Good Tool!
  10. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Got plenty of the right tools, including that 3/4 inch 600 lbs monster to the right. That one is used on Porsche axles.
    Red 27 likes this.
  11. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Don't you mean 280 lbs? That would be your weight plus 80, and how do you figure
    "the scale reads 80 lbs. At that point, the torque is 120 lbs times 3 ft, or 360 lb ft." ?
    Thank you.
    Regards, Alberto
  12. GordonC
    GordonC F1 Rookie
    4,121
    Calgary, AB, Canada
    Gordon
    No, he's correct. Consider that when standing on the scale while being able to push down on the wrench, there are two points to provide support to his body weight, which is the maximum vertical downward force that he is able to apply via gravity. If he's not pushing down on the wrench with any force, then the scale reads 200 lbs because all his weight is on his feet, on the scale. If he pushes down on the wrench handle with a force of 50 lbs, then the scale will only read 150 lbs from his feet - the same total 200 lbs downward force due to gravity, but because he is pressing on the wrench with 50 lbs force, only 150 lbs force is being exerted by his feet on the scale.
    Looking at it the other way - how to tell how much force is being exerted downwards on the wrench? It's 0 pounds when the scale reads 200 lbs; if he presses down and the scale reads 150 lbs, then the difference of 50 lbs must be exerted on the wrench. If the scale only reads 80 lbs, then the force on the wrench is 200 - 80 = 120 lbs. If the scale read 0 lbs, then his entire body weight of 200 lbs is being exerted downwards on the wrench.
  13. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    You are absolutely right, it is the same as weightlessness :)
  14. Ak Jim
    Ak Jim F1 Veteran
    8,498
    North Pole AK
    INRange likes this.
  15. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,931
    That is fantastic! thanks for the tip.
    Beats the $650 I spent on a torque wrench to tighten the wheels on my Testarossa
  16. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    I am going to try it next week, will post results.
    Physics vs. electronics...
    Regards, Alberto
  17. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    You can use a torque multipler wrench or just use an impact gun.
    Ray
  18. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Definitely Ray, we use an impact gun on a trucks lug nuts, but in this case it is
    a touch more subtle, and delicate. Would not want to damage the nut / crank threads.
    We are going the 'physics' route, after all simple math, and if they could run the F1 Mercedes
    grand prix cars in the 30's without exotic modern tools, I think we can get at least to an acceptable point.
    Thank you for the tips, much appreciated.
    Regards, Alberto
  19. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    If it's good enough for Archimedes, it's good enough for me :)
    There's no arguing with Physics.
    Ray
