Need to find an oil cooler for my '83 QV | FerrariChat
Discussion in 'Mondial' started by davemqv, Jun 1, 2021.
  1. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Hi All,
    Appealing to the hive mind here...
    A friend of mine is helping me sort through an overheating issue on my QV. Turns out it needs a new oil cooler. Anyone here know where to find one? I tried emailing Stefan who often parts out Mondial's in the EU. Waiting to hear back. In the meantime any leads very appreciated.
    Dave
    Matthew 6:19 likes this.
  2. afterburner
    afterburner F1 Rookie
    3,215
    Hong Kong
    Dave were you recording high oil temperature?
    Have you cleaned the actual outside of the core and flushed it?
    Or why do you think the oil cooler itself is bad?
  3. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    The radiator got flushed out but the oil cooler fell to pieces upon removal.
    Still need one if anyone has leads.
  4. afterburner
    3,215
    Hong Kong
    Oh not good... sorry no lead.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Superperformance in uk listing 2 types. 320 and 400 £
  6. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Thank you!
  7. Matthew 6:19
    Matthew 6:19 Karting
    Dec 19, 2018
    156
    Ohio
    Jamie
    Dave sorry to hear of the issues! I've been working through fuel issues on my 83qv... replaced fuel pump and this week the fuel accumulator. Hope that solves it!
    Good luck on yours as well.
  8. 83Mondialqv
    83Mondialqv Formula Junior
    May 18, 2021
    326
    New York
    Vito L
    My 83 qv yesterday was running hot as well. Went for gas when I started the car up the RPMs were reving up all on it’s own I figured it was the throttle body that got stuck bc the pervious owner didn’t drive it as much. So I shut it off and let it sit when I turned it back on it was normal. Drove it around for a few while I went to put it back in my garage it began doing the same thing. Then all of a sudden anti freeze began coming out to the hose from the reservoir I shut the car off let it cool down and it was normal again. I’m wondering if it the thermostat that is getting stuck and both of my fans kicked in. I’m wondering if it because the old owner didn’t drive it as much major service was done a year and a half ago.
    davemqv likes this.
  9. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Did you see what the temp was reading during this?
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    The throttle cables are known to get hung up on the carpet and you get high tickover, check the quadrant on the rear bank where the cable connects to see if it springs back easily, wd 40 helps
  11. 83Mondialqv
    May 18, 2021
    326
    New York
    Vito L
    I didn’t even check all I heard was the rpms go up but while driving g it was at 210
    davemqv likes this.
  12. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Yeah I think unless you're stuck in traffic that's probably too hot. Everyone I've discussed my issue with says the temp should never really pass the mid point (195)
  13. afterburner
    3,215
    Hong Kong
  14. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    338
    My fundamental belief about the radiator is - two fans need to be mounted regardless of climate where car lives; and the fuse box must function perfectly to avoid fans turning/cutting off due to faulty fuse box and overheated connections. Poorly functioning fans is something you may never observe, but the engine knows!
