Need to remove steering rack 88 Mondial 3.2 HELP | FerrariChat
Discussion in 'Mondial' started by ownferraribeforedie, Oct 15, 2025 at 4:47 PM.
  1. ownferraribeforedie
    Aug 26, 2025
    37
    sarasota fl
    Jeff Stepek
    Hello again,
    Joys of owning a 67k miles Mondial.
    Driving the the other day and started hearing and feeling a knock in the steering, especially when turning right. Got car on my 4 post lift and by grabbing the right steering tie rod, I can move it up and down. It seems as thought the entire rack is moving up/down in the tube.
    Been doing searches and perhaps there is a bushing at the end of the tube that centers the rack. I cant tell cause the boot is in the way. Also I have learned from searching that the rack may have been also in Panteras? My is a TRW. Also could the tie rod come loos from the end of the rack. Not much in the way of diagrams.
    To remove I see the 2 u-clamps that holds the rack to the car, also of course need to remove the L/F tie-rod ends, But how does one access where the steering column attaches to the the rack box? Don't see how one can get to the top of the rack box to disconnect. Does one go thru the drivers footwell?
    So any help getting this rack out is appreciated.
    Jeff
  2. Alden
    Alden F1 Rookie
    3,759
    Central Florida
    Year and model? We a're not going to guess what you have.
    Jeeeeeze! Some basic info with your posts please!
    Alden
  3. ownferraribeforedie
    Aug 26, 2025
    37
    sarasota fl
    Jeff Stepek
    Sorry the car is a 1988 Ferrari Mondial 3.2 Cab with 67k miles USA version with new proper size tires. Thought the title provided that information, "Need to remove steering rack 88 Mondial 3.2 HELP"
    Jeff
  4. Alden
    Alden F1 Rookie
    3,759
    Central Florida
    You're right, I guess I didn't read it, LOL!
    Alden
  5. afterburner
    afterburner F1 Rookie
    3,510
    Switzerland
    Urs STEMMLER
    There is a bushing on the pax side that can be changed with the rack installed
  6. ownferraribeforedie
    Aug 26, 2025
    37
    sarasota fl
    Jeff Stepek
    Thanks for the info, but it seems there is no diagram showing the bushing. I assume of course the boot has to be slid aside. Where can I get info on the bushing? I am new to this car but not to cars, so would love to fix without removal.
    Jeff
  7. afterburner
    3,510
    Switzerland
    Urs STEMMLER
    Jeff those racks were only sold as complete units so no diagrams exist. You'll find information re the bushing on my Mondial thread. You'll have to remove the track rod (it's screwed onto the treaded rack end and clean out the old, broken bushing before inserting a new one. If that bushing is the only defective part of your rack I would not remove it. It's no fun.
  8. ownferraribeforedie
    Aug 26, 2025
    37
    sarasota fl
    Jeff Stepek
    Can you supply the link to the thread?
    Jeff
  9. ownferraribeforedie
    Aug 26, 2025
    37
    sarasota fl
    Jeff Stepek
    Well it's the passenger side bushing as plastic pieces are falling out. I have decided to replace some bushings "while I am in there" and maybe the shocks. See my recent post on ground clearance.
    So I got the rack out and it is "not fun" but I have done worse on cars. Anyhow being a 88 3.2 the rack is not power steering so it does not have all the hoses etc.
    I want to take the rack apart and re grease and of course put new bushings in. Some research said brass bushings from a Pantera might work. Anyhow I would appreciate how to replace the bushings and where to get the brass ones. My rack is a TRW
    I will post photos tomorrow of how I got it out in 5 hours including taking off the front tires. Again I have a 4 post lift, can't imagine doing this laying on the ground. I am way too old for that.
    In my post on ride height, a suggestion was made to look at SF racing shocks, I contacted them and they can only provide lowering. I want to get back to stock height as my front is way too low. So I am looking for a relatively inexpensive source for stock replacement shocks.
    Jeff
    ownferraribeforedie
