Need to top off fluid for soft top 355 spider? | FerrariChat
Discussion in '348/355' started by JLP, Sep 8, 2006.
  1. JLP
    JLP Formula Junior
    Aug 18, 2006
    659
    Bay Area, Ca
    Where do you add the fluid? and what type is suitable?
    TIA
    Sorry I did some more poking around and found most of my answers.
  2. van22
    van22 Karting
    227
    Absecon Island, New Jersey
    VAN C
    its mercedes benz fluid and good luck cause i could'nt figure out how to add it even though they told me how!
  3. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
  4. JLP
    JLP Formula Junior
    Aug 18, 2006
    659
    Bay Area, Ca
    Thank you.
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
  6. f355spider
    f355spider F1 World Champ
    18,043
    I lost the link, but there is a couple threads with photos and diagrams here on Fchat. You can use any number of brands of hydraulic fluids...I am using Petosin (sp?) which I picked up at the Jaguar/Bentley dealer, and is what they use.
    The top up procedure is not at all difficult and only takes about 15 to 20 minutes from start to finish..I would recommend that everyone with a 355 spider do the check every 12 to 18 months. I have checked mine twice, once at about 24 months and it was below the min. mark. Filled it slightly above the max mark and after 17 months was about mid way between max and min. I refilled to slight above the max mark again. (about 7mm above the max line)
    Okay I looked for you....here it is:
    http://www.ferrarichat.com/forum/showthread.php?t=68482&highlight=spider+fluid
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Nice write up..though what the hell happens to the fluid?? Does it evaporate?? Does it leak into the body and carpet?
  8. speedy pete
    speedy pete Formula Junior
    Nov 1, 2003
    255
    darkside of the moon
    Pete B
    It seems to weep out through the body of the container. I noticed it being moist over the past couple of years....weird stuff
