need touch up paint for the drivers door (fer 300/6) | FerrariChat
Discussion in '308/328' started by irondogmike, Jan 2, 2008.
  1. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    on my 308qv on the drivers side door by the lock on the edge where someone opened the door and hit either a wall or something to chip a little piece of the paint enough to make you mad,someone said to touch it up with finger nail polish,I would like to find just alittle bit of the right stuff,fer 300/6 Rosso Corsa,can you help without me buying a gal or pint?
  2. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
  3. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    Mike,
    It will cost a few dollars but go to a paint jobber and buy a pint. Have them check the type of paint and they should be able to make a near perfect match. Most cost effective is a single stage urethane [same as base coat/clear coat w/out the clear step]. Red is expensive due to pigment. I would guess about 50-60 for a pint but you can keep it for future mishaps. Another is to just buy a base coat color match and use a clear touch up from an Autozone. Only problem will be the base tends to be more difficult to match to the car but such a small area should be OK. The color pens sound good but there is no guarantee it will match.
  4. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Matched when I used it and it is easy to apply on rock chips I wouldn't do a scratch with one
  5. PT 328
    PT 328 F1 Rookie
    4,005
    I found VW tornado red at autozone. Perfect match
  6. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    It's not a bad option unless you want lots of extra.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Either go to an auto paint dealer or a good body shop that has a laser paint matching system. I did this a while back and the guy came out with a camera and took a picture of my red rear deck . He went inside and stuck it in the computer and it spit out the formula and he mixed me a touch up bottle full for $7. It was a perfect match.
  8. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    i use touch up paint for my red 81 from a discount auto store - recent ford red is a pretty close match. jon s
  9. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,327
    Montana
    Kim
    +1 on Steve Kings post. My family owns a body shop and I painted cars for 12 years. Go to an automotive paint supplier and let them take a reading off the car ( or bring them in a piece of the car ) along with your paint code,model, and year and they can mix you a touch up bottle that comes with a little brush for around $12.00. If you don't have paint guns, thinners, sealers etc. a quart of paint will just be a waste of $$. And If you don't know what your doing when it comes to mixing and spraying paint, and the type of surface your trying to match or spray over, the chemicals can end up lifting the factory paint and leaving you with quite a mess.
  10. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    #10 irondogmike, Jan 3, 2008
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Just use a touch-up brush, and then you'll want to use this stuff to get rid of the "blob" after touch up -- it works GREAT
    www.LANGKA.com
