Need urgent HELP! 512TR brake question | FerrariChat
Discussion in 'Technical Q&A' started by jaturon, Jul 13, 2005.
  1. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    I was told by my mechanic that there was a oil leak in my front left brake so he looked into the ATE caliper and found that there was a crack in the 'cylinder' (I don't know whether I use the correct technical term).
    Can it be repaired? If not then where can I get a replacement?
  2. Ricambi America
    Sponsor Owner
    He could mean the "piston"? I'll defer to some of the other more senior folks here, a 512TR uses either TEVES or Brembo calipers. In both cases, I don't think the piston can be purchased as a distinct item.
    Did he perhaps mean master cylinder, or brake booster?
  3. JIMBO
    JIMBO Formula 3
    1,372
    Bradenton, Florida
    Jim DeRespino
    We need more info. By "oil" I assume you mean brake fluid. If "cylinder" refers to the master cylinder, then the fix is easy and relatively cheap. Open the front bonnet and pull back the top carpet (held by velcro) covering the master cylinder. Look in there for brake fluid leaks (should be obvious). If "cylinder" refers to one of the pistons, well... you don't want to know.
  4. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    Yes I think he meant brake piston inside the 'ATE' caliper and it was brake fluid that leaked on to the front left wheel. So can this piston be purchased seperately or do I need to replace the whole 'ATE' caliper?
  5. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    might only need a seal kit
  6. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    Three (at least) things can go wrong that will cause a leak at the wheel end of the brake system- the caliper can break or develop a crack, the piston that presses the pad against the disc can crack, or the seal between the caliper and the piston can develop a leak. Only the first problem is expensive, relatively, the others are pretty simple to solve and not costly.
  7. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    Definitely not the first problem but more likely the second or third. So what is thye solution here as I am now in UK so that I can get parts here.
    Need urgent help!
  8. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    I am now told that the piston is not sold seperately so need to find second hand one or otherwise needs to replaced the whole caliper!
    Help anyone?
  9. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    The internals of the ATE calipers are the same as some early 80's Pre ABS BMW 6 and 7 series (but not the actual caliper body) then give euro car parts a call to see if they can match up a seal kit and piston (www.eurocarparts.com)
  10. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    As per this problem then would it be better if I upgrade my front brakes to 550 or 575 systems?
