Neoprene washer or copper on thermostat? | FerrariChat
Discussion in '308/328' started by Sean308, Nov 25, 2012.
  1. Sean308
    Sean308 Formula Junior
    Jan 12, 2011
    287
    Victoria, Australia
    Sean
    Hi Guys,
    The neoprene washer I have on my thermostat has split in half, should i go back to a copper one or stick with the neoprene rubber one?
    I figure the rubber one has a better seal but due to heat in engine bay will crack over time. Also is this an 8mm washer?
  2. Steve Magnusson
    26,839
    The difficulty with using a rubber washer there is that you really can't tighten the bleed screw much without squeezing the washer out or breaking it. With the engine vibration, you'd be better off using a fresh (i.e., fully annealed and soft before crushing) copper washer IMO.
  3. Sean308
    Jan 12, 2011
    287
    Victoria, Australia
    Sean
    Thanks Steve,
    As always you make a lot of sense.
