Networking 2 PCs | FerrariChat
Networking 2 PCs
Discussion in 'Other Off Topic Forum' started by Gilles27, Feb 1, 2009.
  1. Gilles27
    Gilles27 F1 World Champ
    Mar 16, 2002
    13,337
    Ex-Urbia
    Jack
    I have a second PC tower that I'd like to link with another system. Is there a way to do that using only one monitor? I thought I could just do it with a CAT-5 cable, but nothing doing. Suggestions?
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,295
    E ' ' '/ F
    Splenda Daddy
    What are you trying to accomplish?
    If you just want access to the files/services on the other machine, an ethernet crossover cable will get that done. Alternatively, and more likely, most environments have a switch somewhere to which the ethernet cables run.
    If you want keyboard/video/mouse, the easiest way is to get a KVM switcher to connect your existing keyboard, mouse and monitor to both systems. Alternatively, you can first install a remote management tool on the second PC (VNC is a big player, as is Remote Desktop built into later Windows OSes) and then attach the monitor back to your first machine, using the remote management tool to run the second PC from the first.
  3. Gilles27
    Mar 16, 2002
    13,337
    Ex-Urbia
    Jack
    One computer is an HP Pavilion that is good for basic computing. The tower I want linked is a Dell that I want for my photo processing and a guitar system I have (real guitar, not a game). I'd like to link the two as simply as possible without needing another monitor. I hooked up an ethernet cable but couldn't get a connection.
  4. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
  5. tjacoby
    tjacoby F1 Rookie
    Nov 1, 2003
    2,857
    Vancouver Canada
    tj
    this is easier to do with a home firewall - with both PC's plugged into an Ethernet jack on the firewall, as both PC's are likely setup to get their network values from the firewall. Otherwise they need to be hard-coded. Easy to do, but it takes a few more minutes, and can interfere with your Internet usage.
    With windows, you need to set the file space as 'shared' to allow network access to them. 2000, XP, Vista?
    bahh, sounds too much like work!
  6. Etcetera
    Etcetera Two Time F1 World Champ
    24,160
    C6H14O5
