New 348 owner....Need some help | FerrariChat
Discussion in '348/355' started by cantthinkofone, Aug 28, 2018.
  1. cantthinkofone
    cantthinkofone Karting
    Jul 12, 2018
    146
    New York
    Michael Orifici
  2. boxcarracer
    boxcarracer Formula Junior
    Jul 29, 2005
    333
    Montreal
    Luigi
    Can't identify your setup, but you seem to be missing the exhaust heat shields which that may help with your heat issue.
    Is that round cross-bar aftermarket as well?
  3. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Ive not seen that set up before. The bumper should have some heat protection cloth on it but it may only be effective for radiated heat not a touching muffler. Looks as if it will be difficult to adjust forward which is what you need to do.
    Heat protection.
  4. cantthinkofone
    Jul 12, 2018
    146
    New York
    Michael Orifici
    Already tracked down a set of heat shields. But thanks.
  5. cantthinkofone
    Jul 12, 2018
    146
    New York
    Michael Orifici
    The bumper has the insulation on it but the muffler is touching it. No air gap.
  6. boxcarracer
    Jul 29, 2005
    333
    Montreal
    Luigi
    Oh I just noticed that the round bar is the exhaust support.
    I think the cheapest way to get a gap is to shorten the end spool of the cat (they're aftermarket anyway), should give you enough to clear the bumper.
    Otherwise, you can get new cat bypass pipes and exhaust setup from Superformance for relatively cheap.
    Post pics of the new car!
  7. cantthinkofone
    Jul 12, 2018
    146
    New York
    Michael Orifici
    My first thought was to cut it down also. Just wanted to make sure that it wasn't for another year/type of car that would make more senses selling and replacing then cutting.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I was going to suggest shortening the cats as well, along with changing the mount bar attachment points (probably at the muffler attachment). But then it would effect the aesthetics of the exhaust tips exiting the bumper openings. If you add different tips... now its just project creep altogether. Best to replace the whole thing?
  9. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  10. cantthinkofone
    Jul 12, 2018
    146
    New York
    Michael Orifici
    The more I look into it, some things not right where the cats and muffler bolt together. There is something in between them. Got to take it apart and see.
