new 348 owner tech help | FerrariChat
Discussion in 'Technical Q&A' started by 360F1, Dec 26, 2003.
  1. 360F1
    360F1 Rookie
    Dec 21, 2003
    26
    360F1
    MEMBERS
    I have recently bought a 1992 348ts 26,000 miles that seems to cut out now and again and run on one bank for 1/2mins then pick up and run ok.It happens when hot or cold, is it the coil for that one bank of 4 or something else.
    Also how do you turn on the parking lights or is it a fuse gone?
    Also water temp gauge not always working what connections do i check.
    I have also put this on the U.K. site but would like more help please.
  2. JSL
    JSL Formula 3
    Jan 5, 2002
    2,212
    California
    J.S. Leonard
    Try resetting your ECU. To do this, disconnect the battery, your's has a plug devise on the positive cable, just unplug it. Leave it alone for 15-20 minutes. Reconnect the power and start the car. Don't touch the gas or anything else. Let the car idle for 15 minutes. Your ECU will be reset and maybe this will cure your problem. It has mine more than once. Good luck.
  3. 92_348ts
    92_348ts Formula Junior
    Jun 6, 2002
    282
    Boise, Idaho
    Chris
    Alan- Your car has the Motronic 2.7, which has a self diagnostic feature. Pages C78-C81 in the workshop manual will show you step by step how to download the MIL's to determine your problem. Once you find the problem, simply search the archives by key words for a fix.
  4. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    Sounds like you have a bad thermocouple ecu. the insulating material cracks on the seams and allows moisture to infiltrate the electronics causing the failure.
    on the 348, they are located behind the rear shock towers with one on each side for each bank. What happens is that the tc ecu sends a false exhaust over temp signal to the motronic ecu which in turn shuts down the bank to lower the temp.
    unfortunatly a very common, expensive fail point of the 348.
    Determine which bank you are losing and then swap the ecu`s left to right. If the bank lost follows, you have your problem.
    best regards, jim
  5. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    FWIW - I had some intermittant "slow-down" light messages until I replaced the CATS with test pipes - no more problems....
  6. NC348
    NC348 Karting
    Feb 18, 2003
    154
    Houston, TX
    James I. Movich
    I would also suggest to go to the old site and do a search on :
    348 AND "slow down"
    there is almost TOO much information available. its a gold mine.
