New 348 Project | Page 2 | FerrariChat
New 348 Project
Discussion in '348/355' started by spiderscott, Jan 9, 2019.
  1. DrStranglove
    DrStranglove FChat Assassin
    29,156
    Google Maps
    DrS
    Funny. Pretty sure first photo is my 348.
  2. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
  3. DrStranglove
    29,156
    Google Maps
    DrS
    Thanks. I think I see what you are showing.
  4. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Yep. It’s the length of that little “shelf” under the dash. The start of the “other color” on the 348 dash. In the example, where the red or the tan starts.
  5. spiderscott
    spiderscott Formula 3
    1,654
    Ratarossa HQ UK
    Ratarossa
    Interesting thats the same on the US v Euro Testarossa. My TR is US and much less knee room than my old Euro car.
  6. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Few more jobs sorted on the 348 today.
  7. GTO Joe
    GTO Joe Formula Junior
    989
    Charlotte, NC
    Joseph Troutwine
    Scott, I had the same issue with the mirrors, it was the switch. Simple replacement, you just pull the three switch grouping out and you unsnape the switch. The problem is finding a new switch, they have been gone from parts for a long time. I was able to find one on EBay but of course it was not cheap. Interesting tidbit, the switch is shared with one other vehicle, the F40 :). I never did get into the inside of the switch so mught want to explore the contacts inside. Good luck, I enjoy your vids.
    spiderscott likes this.
  8. Ferrarium
    Ferrarium F1 Veteran
    5,637
    Central NJ
    Eric
    #33 Ferrarium, Feb 16, 2019
    Yey FChat! My window switch is fine but I searched found the xref part numbers and found a new one on ebay from an alpha #60529884. Bought it just in case a bit of future proofing.
    You can get them here.
    https://alfa-restoration.co.uk
  9. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Good to know, I think I will take a look inside and see if I can resolve it. Price is high already without it being shared with an F40 :rolleyes::rolleyes::rolleyes:
  10. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Brilliant, found one cheers for this info.
  11. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Yep, Alfa Romeo 75 (Milano in the US) mirror switch. Also used in the Series 4 Spider (91-94). My Milano is a 3 liter Verde so the mirror switch is the same but the arrows and the dot are orange instead of white.
    Interestingly enough the dash vents are also from a Milano. (only the moveable part)
  12. GTO Joe
    989
    Charlotte, NC
    Joseph Troutwine
    Good news to say the least. I had to give $125 for the one I found but of course I got the pretty yellow box with a black horse on it. :)
  13. Ferrarium
    5,637
    Central NJ
    Eric
    Odd, I found it on ebay the other day from Germany for $77.72 shipped.
  14. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    712
    Treasure Coast Florida
    MATT
    Still Loving the channel and the videos. I had similar problem with my mirrors... it was actually broken wires inside of the multi pin round door connector. You literally just pull the rubber back and I found wires that were completely severed. Lots of write-ups on this you can buy the pins and extractor tool on eBay Tyco. I was able to meticulously drill mine out resolder in a jumper wire And re crimp. Others not so easy you've got to Ohm out each pin connector poke a hole in each wire few inches back to determine which ones are faulty
  15. Ferrarium
    5,637
    Central NJ
    Eric
    Don't you just do all the pins when in there fixing 1 or 2? While the patient is open and all that.
    Sent from my LM-Q710(FGN) using FerrariChat.com mobile app
  16. POLO35
    Feb 21, 2005
    712
    MATT
    I think most folks do but I chose not to. There are A LOT OF PINS and a lot of room to get wires crossed so I just chose to repair just the two Broken ones... one was affecting the window one was affecting the mirrors. Some guys opt to do away with the pin connector completely rewire with crimps which I think is Ludicrous. Think about it these connectors have lasted 25 or more years that's really not that bad. My Mercedes S550 recently had a wire go bad in the door Loom affecting my right side mirror...things don't last a lifetime nor should they ever be expected to. Just my thoughts.
  17. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Lovely weather here is the Uk so been doing some work outside on the 348 Project
    NeuroBeaker likes this.
  18. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Finally got some time to film another Episode on the 348 Project.
    I gave the car a full annual service and thought it would be handy to share the process.
  19. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    chopsui likes this.
  20. brent Lachelt
    brent Lachelt Formula 3
    1,828
    Brownsburg, INDIANA
    Brent R.Lachelt
    Scott thanks for the video on cleaning and regressing the window rails. I had actually made the hard wire update on the drivers door due the broken pin connectors several years ago, but didn’t clean and re grease the rails. Wow what a huge difference, it goes up and down much faster. Going to do the passenger window next. Thanks again!
  21. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    Most welcome, let us know how you get on.
    It's quite a quick and easy process, you should be able to have it apart, re greased and back together well within half an hour.
  22. steved033
    Apr 12, 2017
    7,792
    Atlanta, GA
    Steve D.
    The most important tidbit is that you get to it from the OUTSIDE of the door. I don't know if I realized they were constructed that way.
    Thanks for the vids!
    sjd
