New 550 owner needs advice on small problems | FerrariChat
Discussion in '456/550/575' started by Harris, Sep 19, 2006.
  1. Harris
    Harris Rookie
    Jul 30, 2006
    37
    Dubai, UAE
    Harris
    Just picked up a '97 550 and having a blast. Had a full inspection done by the main dealer before buying, but frankly they only told me stuff I already knew within a minute of test driving the car (like the a/c only works on setting 4), or stuff I could see immediately (like the car has an aftermarket (Tubi) exhaust). They relieved me of $500 for the privilege, and I just didn't feel they did a very thorough job of evaluating the true cost of fixing problems. (Switches a bit sticky? Oh, just replace the whole console...)
    Anyway, as this will be a daily driver, I'd like to sort a few irritating little problems and need some advice. It seems at some point in the car's life, the dash leather has been replaced (and the shrinkage has started again, but then temperatures do tend to average 35-40 in this part of the world). I think the whole dash was removed as there are four problems that may be related:
    1. The actuators are not adjusting the suspension between sport and comfort, even though all 4 shock units look ok (visually). Current is passing through the actuators, but all 4 units are stuck in their stiffest setting, so maybe there's something wrong with the sensors.
    2. The airbag light is on, although there's nothing to suggest they have been used or abused.
    3. The a/c only works on setting 4, which is a pain as it's so damn loud, it drowns out that gorgeous complex rumble from the engine.
    4. The horn doesn't work.
    Does anyone share my suspicions on there being a wiring problem, or experienced these before? I am holding off on ordering 4 complete shock units from the official dealer (extremely expensive) until I allow "my" guy to get behind the dash (the car is not warranted by the main dealer, so I can afford to let an independent loose on the car - besides he seems to know so much more).
    One final question: I see that the manual recommends 95 octane fuel. It seems bizarre to me that such a special engine should not be optimised for 98 RON, which is what I have been using. Is the general consensus that I should go with the written word, or stick with 98?
  2. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    Looks like 4 problems too many to me ...
    The only A/C problem I've had on my 550 is the compressor relay breaking down, easily replaced (it's a standard part, 15$ or so).
    Can't make sense of the fact that the AC would not work on lower fan settings. As long as the stop button is out and the fan setting not on 0, you should hear the compressor relay tick and cold air blow. Moisture in the AC system & clogged filter is a common problem, but for the rest, I'd be suspicious.
    Ferraris are designed to run on 95 because that's all that was widely available in Italy at the time. Some studies (Evo) have proved a marginal gain when running higher octane fuel on certain cars, but as far as I am concerned, running 98 is a waste of money.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I did some searching here a few months ago, before I put a bid on a 550 and found that the shocks and motor mounts were known problems with the early cars.
  4. Lynnf
    Lynnf Rookie
    Sep 19, 2006
    6
    have the dealer read the system from the plug in passenger footwell. The read out will give you an indicator of the problem. Mine said all 4 were out. NOT TRUE! Only one was.
    Look at the top of the shock and see if the wires are all twisted up. If so, then the motor is shot. If setting will move with vise grips and the shock is not leaking, get a new motor. If it won't move, you need both.
    On, A/C may certain that you are set on auto on both sides and see what happens.
  5. Harris
    Harris Rookie
    Jul 30, 2006
    37
    Dubai, UAE
    Harris
    Thanks for the responses. Have tried every combination on the a/c, and it's definitely just full on (ie setting 4) or full off only. Weird problem.
    The workshop is going to have to remove the dash anyway to check the wiring for the airbag and the horn, so they'll get a chance to check out other problems while they're poking around.
    Now for the gripe. Why is it main dealers seem to have a policy of replacing whole units if there's a glitch in a particular part? These days, most dealers seem to be "fitters" rather than engineers. They don't seem inclined to solve problems, which is why I much prefer to go to experienced independents, the kind who have seemingly chaotic workshops you can freely wander around and look at stripped down exotics in various states of build, whilst chatting to the owner.
    The workshop I am using is run by an ex-racer who loves Ferraris with a passion. Currently he is working on a Ford GT, an original Cobra, three Ferraris and a race prepared Mitsu Evo. Time will tell if he can solve my problems to my satisfaction, but here's hoping...
  6. dbcooper
    dbcooper Formula Junior
    Feb 7, 2005
    281
    Costa Mesa,Ca.
    Tim Romero
    The resistor assembly for the A/c fan motor is burned out and thats why you only get full blast.The resistor assembly has 3 separate resistors that drop the voltage/amperage of the juice going to the blower fan motor.
    slow speed=highest resistance value,medium speed=middlin resistor value and full blast=no resistor value so motor gets full voltage/amperage.thats why your hauls butt on full blast only.it will be located somewhere on or in the A/C condenser/Heater core housing.It gets cooled by being attached to the housing and being blown on by the air flowing thru the housing
  7. Harris
    Harris Rookie
    Jul 30, 2006
    37
    Dubai, UAE
    Harris
    Great - thanks for that advice. I will get right on it...
  8. jonp
    jonp Karting
    Jun 24, 2006
    86
    Essex, UK
    Jon
    I agree with Tim re the aircon, had the same on a vauxhall/opel, part was £20 on that, I'm betting ferrari will charge a tad more!
    From what I know on the actuators, it tends to be the teeth inside the units that strip off, same actuators on 355's etc. Need to pop them off to check, but I doubt all 4 are problematic. My understanding is from what folks have told me that when the car powers on, part of the checks are to run the actuators through their full movement so they calibrate, then move to the position determined by the switch setting. Also from what I was told, if there;'s a problem at that point, you'd get the warning light show on the multi display to indicate this. Must confess, other than onboard diags and SD units, not sure how you would test these. Does the Sport light come on and off on the dash when you alternate the switch setting, if so I assume you don't get any warnings...to me if that was the case I would have thought all was well??
    The horns are actually air horns, not electric, however the unit that provides the air is electric i believe. There are two air horns, when I got mine one of the pipes was loose, may be a loose pipe or a duff air unit, fairly cheap parts wise I think, all circa £20-25 each. Makes a change! That's obviously assuming that current is getting to the air generator when the horn is pressed.
    Airbag light, not a clue, probably an SD hookup required.
    One thought, duff horn - airbag light, are you sure the steering wheel hasn't had issues or puffy bags appearing!!??!!
    Just a layperson, so don't profess to be an expert so please correct the above if I have put anything incorrectly, otherwise hope this helps
    Jon
    ps if you fancy figuring out the parts you need or roughly where they are i always find this site helps www.eurospares.co.uk really good parts diagrams etc
  9. Argento
    Argento Formula Junior
    Dec 23, 2005
    531
    Argentium
    Harris,
    Congrats on the car, Stick with 98 RON, It's worth 2-3 BHP over 95 RON and if you use Shell or BP then the cleaning additives help reduce engine wear and carbon build up too.
    PS - Colour's of your car & S/n for the record, Any options fitted?
    Argento
  10. Harris
    Harris Rookie
    Jul 30, 2006
    37
    Dubai, UAE
    Harris
    I spoke with my workshop yesterday, and yes, you are right about the steering wheel. Something broke behind the column which meant the horn was only intermittently connected. Now fixed.
    Workshop has another 550 in at the moment, so he will swap actuators to test whether that's the problem. No warning lights on the dash, though, and the switch shows Sport mode ok.
    Thanks for the tip on eurospares!
  11. Harris
    Harris Rookie
    Jul 30, 2006
    37
    Dubai, UAE
    Harris
    Tubi exhaust fitted. Truly wonderful sound. I have to be honest, I'm not sure what's standard and what are options, but the Tubi's all I need.
    Now regarding the colour, here's the thing. It's TDF blue on crema, and it's my sixth blue car, so I'm pretty fed up with the colour. It's just that the car had been sitting at the dealer for ever (no-one wants blue Ferraris in Dubai) and I bagged an absolute bargain.
    The exterior is cosmetically a little scruffy (a few chips, scratches and dings), so rather than merely tidy up, I will be doing a high quality repaint to rosso. Yeah, I know, I've thought about resale, I've thought about the cost, the quality of the job, the funny looks from other Ferrari owners. But I've weighed it all up and believe I can have a first class job for a fraction of the cost of doing the job in the UK, plus possibly increase my resale chances (since red is the preferred colour for Ferraris here).
    Plus the fact I always wanted my first Ferrari to be red. In isolation a blue 550 looks great, but frankly I saw a red one the other day and decided it was no contest. All in my personal opinion, of course...
