New ADDCO sway bars. Oh, Yeah! | Page 3 | FerrariChat
Discussion in '308/328' started by AZDoug, May 2, 2013.
  1. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    My bars are at Wade's shop.
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Both my bars just showed up in Canada at Newman's.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,554
    Canada
    Newman
    #53 Newman, Jun 28, 2013
    Bars are in, just got them today. What Ive run into is firstly they sent fine thread nuts and coarse thread bolts for the links. Its like they just grabbed fasteners and tossed them in the bag because the other bar has a different combination and quantity of fasteners.
    Rear bar should be shorter so I dont need spacers to keep the links vertical.
    Front bar hits the coil springs on both sides. Not sure I can make this bar work. I believe if I flip it over Ill have other issues that offer other compromises if it even fits. Not sure what to do here. The way the bar is bent now, it clears the inner tie rods if I flip it im sure it'll contact the inners.
    The bars seem universal or generic rather than model specific. Not impressed at all with the product.
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    So I guess we need to find out what the return policy is?
  5. Newman
    Dec 26, 2001
    14,554
    Canada
    Newman
    Tried the bar upside down, won't work on the angle it produces. Rounded the flat cut ends, still won't clear the springs. If I cut the end off taking away the soft setting it'll fit but we lose the adjustability. If its too tight in the front we can't soften it up.
  6. sherpa23
    sherpa23 F1 World Champ
    10,021
    Rocky Mountains
    Bastuna
    Hold on. So Doug says that the bars were two inches too narrow and Paul says they are too wide (let me guess, by two inches?). Am I the only one who is like WTF?
  7. woody6
    woody6 Karting
    Mar 9, 2009
    117
    Madison, AL
    Robert B.
    Thanks Newman. I only see two holes in the end of that front bar, has Addco already eliminated one of the three planned adjustment points?
    Currently I have only received a rear bar, which sits at my house unopened. It is disturbing to think that when I have received a set, that it may not fit and/or may not be as adjustable as promised.
    --Woody
  8. HotShoe
    HotShoe F1 Veteran
    9,044
    Lake Worth, FL
    Anthony Lauro
    Man, my head is spinning!
    Cue the Benny Hill music.
  9. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Call placed to Addco, left message ...........................................
  11. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,323
    Germany
    Steven
    O oh.
    I really hope that after 9 months of waiting we do not end up with a total **** up......
  12. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Along the Verde , AZ
    Doug
    #62 AZDoug, Jun 28, 2013
    What are the outside widths of your bars, at the flat mounting flanges? Front and rear.
    Edit, see comments on post #65
    edited:My second rear bar OK, though heims are not vertical, . edit: narrowing the bar side to side caused control arm clearance problems unless bar was shortened front to back. shortening front to back stiffens up the bar)
    My second front bar was 2" too narrow, i needed spacers to make it fit,a nd it wouldn't have fit with stock springs, unless it was widened a bit more and each leg shortened some front to back
    . The flanges may have to be somewhat above where you have the flange in ralation to the spring, so as to clear, making the heim joints at full extension, perhaps even needing an extension on the Heim, that aprt I wasn't sure about.
    Doug
  13. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    Looking at teh front pic, I seems like your Heims wouldn't be close to vertical either, i wonder if they made these bars off the second set,a nd didn't incorate my chnages.
    Doug
  14. matt_in_ca
    matt_in_ca Karting
    Oct 27, 2010
    163
    Los Angeles
    Matt
    Just left a VM for John.
    In my VM for John, I explained the situation with the front bar, told him I needed to speak ASAP about the way to remedy this design flaw, or that each of us needed to return our bars.
    I'll post as soon as I hear back from him. If we don't hear back from him, the good news is that these purchases are on our credit cards, so we're protected from issues such as these.
    I suspect that we're all at the point of deal fatigue - at least I am. The problem is, there's really no other options, and I really want the experience that Doug described when placing the correctly designed cars in his car.
    I should be frustrated, but instead find myself disappointed or simply sad :(
  15. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    On your rear bar, do me a favor and move it to one side so the heim joint is vertical, does the bar hit the lower control arm when placed like that? One of my suggestions was to shorten each rear bar leg by about 3/8" (also moving the mounting holes 3/8" closer to the main bar traverse).
    The original (first) rear bar was too short and hit the control arms, necessitating it be wider. My Heims on the rear have a 1/4" steel spacer between each heim and the inside of the bar flange, and still have an angle to the outside, so as to clear the control arm. Narrowing the rear bar causes control arm clearance problems.
    My front bar i have on now (second bar) is 40" outside to outside,a nd needed to be 42.2-42.5" outside to get rid of the spacers I had to make in front to make the Heims clear the control arm. That width "should" allow you to clear stock springs, maybe with longer Heims to get teh flanges up over teh lower part of the spring. I have QA1 springs, and used a card board tube to try and figure out where the stock springs would locate. I also suggested shortening each front bar leg for coil clearance. My understanding was the front production bars would get three holes back, as my second bar only had two holes and I couldn't use the softest position unless the bar was widened and each leg shortened.
    All this was balanced against being able to run wider than stock wheels and tires up front.
    Doug
  16. Newman
    Dec 26, 2001
    14,554
    Canada
    Newman
    Didnt measure the bars and its Friday 5:30 here, let the weekend begin! Addco said I can modify the front bar eliminating the soft setting to see if it fits. They said they have our backs and want to know how to solve the problem.
  17. Newman
    Dec 26, 2001
    14,554
    Canada
    Newman
    I will measure this evening
  18. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    My rear bar is 44 3/8" outside to outside, I have a 1/4" steel spacer between the heim and bar and each heim is angled out about 1/4" from vertical, well within limits. This is necessary to clear the control arm with both the heim joint, and bar ends. Only mod on the rear is the suggested shortening of each leg by about 3/8". Not sure if they did that. Shortening the bar ends would also allow narrowing the bar by 1/2", but again, shortening the legs increases the roll resistance.
    Doug
  19. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    Looking at pic #3 and 4, discounting the spring, can you even connect a heim joint to the front bar without a long spacer? I needed to make 5/8" or 3/4" spacers to get the heim to clear the control arms, thus my suggestion to widen the bar by 2.5", If memeory serves me correctly, this would make the heims mount to the inside of the front bar flanges. The clearance bugaboo on the front is the tie rod ends
    Doug
  20. Newman
    Dec 26, 2001
    14,554
    Canada
    Newman
    If I cut the soft setting portion off the bar (no heat applied) AND I use spacers I can probably/maybe run the front bar but have no adjustability. Addco says go ahead and mod it so they know what we need to do. Rear bar should be shorter by maybe 1.5".
  21. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    #71 AZDoug, Jun 28, 2013
    My original 3.9" shorter rear bar hit the control arms, and were totally uninstallable. edited for correct length
    You want to look at making that suggestion VERY CAREFULLY.
    Doug
  22. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    I have no adjustability now on my front bars and can only use the hardest setting, WITH spacers. Measure your front bar width. Get back to me.
    Doug
  23. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,636
    Doug
    #74 AZDoug, Jun 28, 2013
    Here is my 44.37" wide rear bar. It fits very well. If I was to order this bar again, i would order it at 43.75" wide, this would eliminate the spacers and leave the heims vertical.
    I left the heims inside the bar, so as to guaratee that the bar would not hit the control arms.
    You can probalby narrow the bar another 1", to make the heims mount on the outside of the bar, and still not hit the control arms, you have to be repsonsible for that. I do not see any advantge to inside vs outside mounting of the heims.
    Doug
  24. Newman
    Dec 26, 2001
    14,554
    Canada
    Newman
    42"
