New battery | FerrariChat
New battery
Discussion in 'FF/Lusso' started by RickLederman, Apr 7, 2014.
  1. RickLederman
    RickLederman F1 Rookie
    2,837
    Swanton Ohio
    Rick Lederman
    I will be driving mine to MAG in Columbus tomorrow to get a new battery. For the last week or two I noticed the radar detector making popping sounds while cranking it when starting cold. Three days ago on a cold start (25-40 degrees F while in a parking garage at my R/C Exposition) I saw both displays dim way down then go blank while cranking. It then started but a Complete Electrical Failure warning came up. I let her run a minute or two then shut it down, restarting and all was well except for a Engine Control System Failure. That ECSF fail went away today since I was starting her warm from my garage.
    So, looks like a battery after 33,000+ miles. We will see what the computer readout says tomorrow.
    Rick
  2. ferrari169
    ferrari169 Karting
    Jan 14, 2014
    147
    Northeast USA
    Does the FF have only one battery?
  3. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    Oddly, our FF was in last week to get the winter tires swapped and dealer tested the battery and found it lacking as well.
    The car has been driven and is constantly on the tender, but we ended up with a new one anyway, under warranty. I am sort of believing the OEM batteries leave something to be desired....
  4. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    They do. You should see which brand the OEM tender is. I think its CTek but I also think Ferrari supplies only the most basic CTek tender with the car.
  5. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    The battery on my 458 lasted less than a year. There are many similar stories of early battery failure in Ferraris. Oddly enough the battery in my wife's '07 F430 was going strong for 7 years; I just replaced it figuring it was living on borrow time.
  6. carcommander
    carcommander Formula 3
    Sep 28, 2006
    1,705
    Southeast
    Jim
    My '11 is on it's third battery.
  7. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    when do you connect battery tender, if not using car, 3 days, 5 days, 1 week, more?
    I ask because I use my car daily, but wanting to know if I take vacation etc
  8. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    There is only one battery in the FF. It was NOT replaced under warranty even though the car is still under warranty. I don't think I have let my FF set for more than a week :) so I don't know how long it will last.
    The computer had a host of electrical faults so the battery was really toast even though it still started the FF. After changing the battery the FF really cranked faster than it has lately and all faults are gone.
    Rick
  9. travellingbearsva
    Jul 22, 2012
    88
    Virginia
    Dave
    In my 2012 FF, the battery was considered toast (dealer said charge not holding as expected) a few months back and I paid for replacement at dealer (around $500 with labor). The loophole for Ferrari on battery warranty was I had driven less than 2500 miles per year (average around 2000/year using vehicle 5 days per week) so Ferrari wouldn't cover replacement under warranty. Their translation is low miles per year = infrequent use and lack of proper battery exercise. Dealer did give me new battery tender under warranty. Replacement battery was Interstate. My 2011 Maserati GTC and Ferrari FF have been only vehicles that I've owned with battery behavior issues. My Mercedes products easily start after sitting 30 days without special accommodation (battery tender).
    Dave
  10. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Opinions will vary, but I favor a no-more-than-1-week rule. Certainly the car will still start if you go a few weeks, but the battery will be more deeply discharged. Lead-acid batteries do not like to be deep discharged, so keeping them near top charge will increase their life.
  11. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    That's a LOL! I suppose there is a certain logic but ...
    BTW Interstate is the standard replacement battery and is likely to do better than the OEM one.
  12. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    That's what was put in my FF an Interstate AGM FMT5-49/H8. Bill was $475.45 plus tax. Plus I replaced my wiper blades, after 33,800 miles they leave a bit to be desired, new ones made a huge difference, $158.05 for the pair of blades.
    When the battery was uncovered there is a large plate bolted to the top of the battery box with three large fuse links and three large wires coming off the front, plus the starter cable coming off the inside. The starter cable had to be removed, two bolts holding the buss plate removed then the buss plate and other cables folded forward. I was not there during the actual battery removal (took a spin in a brand new Bentley) but Dan said the battery had to be tipped quite a bit to get it out. Not an easy move.
    And the FF now cranks far better and the crackle noise in the radar detector has gone away.
    Rick
  13. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    Rick,thats good news...glad it working normal,regards
  14. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Now that is one helluva set of wiper blades. But one of them is huge.
  15. tazandjan
    39,163
    Rick- At least with an AGM battery, you do not have to worry about acid spilling. It could have been mounted upside down. Did they give you the battery warranty with the new battery? Should be about 72 months.
    You sure about that number on the Interstate battery? Could not find anything on those numbers, but Interstate's website is really useless.
  16. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #16 4th_gear, Apr 12, 2014
    Terry, I think Rick meant MT5-49/H8. I was recently speaking to the tech specialists at Interstate about suitable AGM batteries for current Ferrari models. The German-made MT5-49/H8 is the best match from Interstate. Interstate is owned by Johnson Controls (Dallas), which also owns VARTA (automotive batteries) in Germany.
    According to a well-connected fellow FChat member, my HELE-equipped car uses the same FIAMM battery as the FF and the F12. Interstate batteries are commonly used as FNA replacements because the FIAMM batteries are not imported to NA. You can get the MT5-49/H8 for about $265 direct from Interstate.
  17. tazandjan
    39,163
    Michael- Thanks for the info. Always trying to figure out the best battery available. That is a big humming battery, 64 lbs and way too big for my 575M. Not a volunteer to change one of those.
  18. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #18 4th_gear, Apr 12, 2014
    Terry, you're welcome. About your 575M, (according to FIAMM literature) it uses an L3 size (190mmH x 278mm W x 175mm D) battery, which I understand is equivalent to an H6 size. There are apparently different battery size naming conventions.
    Bosch makes an automotive AGM battery in the H6 size called the S6585B. I've attached 2 PDFs. "2213441_BAT_TRDBRO_0114(edited).pdf" is an edited-down version of a Bosch channel catalog (I took out the lawn + garden + product display pages). It has a table showing the model number I quoted above. That's the model designation used in the US.
    "Batteries_for_Start_Stop_Systems_en.pdf" has more technical information but does not use the battery model numbers referenced by the sales channels in the US.
    AGM batteries tolerate deep-cycling much better than standard lead acid and EFB lead acid batteries. They last longer when challenged with repeated deep cycling (a regular lead acid battery would die in about 2 weeks in a HELE-operating car). AGM batteries can also recharge much faster depending on the charging system. Cars that experience constant heavy electrical draw (my HELE-California and perhaps the FF and F12) require AGM batteries because they can supply steady 12V voltage despite the repeated discharging. Otherwise, there would be no end of strange electrical faults and system error messages coming from sensors.
    I believe the S6585B is available in the US. VARTA also markets an almost identical AGM battery in the US, unfortunately, only Mercedes carries those in Canada.
  19. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    It is a big battery, much bigger than the sports cars. It needs to run all of those gizmos that take power when the engine is not running: Open the hatch; tilt the seats forward... all of that takes power.
  20. tazandjan
    39,163
    #20 tazandjan, Apr 12, 2014
    Michael- Affirmative, a document I made up a couple of years ago. Now out of date since several of the batteries have been updated. Price of lead has gone up since this was written.
  21. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #21 4th_gear, Apr 13, 2014
    Thanks for the battery document Terry. The Braille batteries, especially the lithium ones, look interesting. My dealer provided me with an Odyssey PC1350 which looks decent. The H8/L5 sizing is also known as "BCI group 49". All these different battery size naming conventions may/may not be necessary but they are kind a crazy IMO. :)
    The OEM FIAMM battery used in my car and the FF/F12 was probably the ecoFORCE AGM VR900 or a similar battery made for Ferrari. The original FIAMM battery in my car was likely defective. I am not sure what they do with the car batteries during the several weeks' journey from the factory but it would strike me as a distinct liability especially in a HELE car. I'm not surprised so many NA Fcar owners have problems with their FIAMM batteries as they all have to make that long trip here.
  22. tazandjan
    39,163
    Michael- I need to update a bunch of stuff. Ferrari has been using Braille, Interstate, and Odyssey batteries to replace the FIAMMs in the last couple of years.
    I think all the down time, from when the cars are finished until they are delivered to the dealers, is killing the batteries here. Funny it does not seem to bother Mercedes. Porsche, and BMW, but they probably have a more efficient delivery system with less time sitting in the port waiting for a ship.
    Mine still has an Interstate MTP-91 lead acid battery with a vent hose. They seem to last 6-8 years in a Maranello if used properly.
  23. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Yes, I know for a fact that Mercedes is actually a 'smalltime' VARTA battery 'dealer' in Canada.
    They are happy to sell you one of their batteries if you know which one you want - just don't try ordering a bunch. I know because I and other non-Mercedes owners have already tested the 'channel'. BMW was less 'cooperative' but I believe they also import their own batteries - they make their X models in Spartanburg SC so why wouldn't they have a ready source for their OEM batteries. When I was driving BMWs I had no problems buying original batteries from local garages. Porsche is also not likely to suffer battery shortages as they are really part of VW, which has a huge presence in NA. I would not be surprised if they simply ship their car batteries separately from their cars and install them during the PDI. That's what I would do. Electrical problems cost a lot of money and goodwill to trouleshoot and fix. Replacing dead batteries with the odd Interstate, Braille or Odyssey is probably a pain for FNA.
    Unfortunately, Ferrari has a tiny NA footprint by comparison to the likes of German carmakers and FIAT is arguably even smaller in NA so it's pretty obvious why Ferrari has battery problems in NA. I even spoke to a NA director for FIAMM who mentioned they would be quite willing to import FIAMM batteries if someone requested sufficient quantity. The issue here is 'sufficient quantity'. Johnson Controls plus Bosch dominate the market in NA so FIAMM has no business incentive to bring their automotive batteries into NA without a clear demand. FIAMM also probably has an exclusive supplier arrangement with Maranello so Ferrari cannot source Bosch or VARTA batteries for PDI in NA. Otherwise, FNA has to subsidize the process of shipping in and inventory small quantities of batteries separately from the shipping of their cars. It would create a challenge for FNA.
    Yes, this reality probably explains why electrical problems and dead batteries bedevil new FCars. The correct size batteries from various makers will likely work except in situations where there may be special requirements like specific internal resistance requirements on the battery to meet charging performance specs. The main issue is that the replacement battery meets the factory specs, crucial if you want to protect your car's warranty. So it's advisable to get something your FCar dealer will warranty.
  24. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    This is a very informative thread. I am learning quite a bit.
  25. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    bumping the thread
    Is the Interstate AGM battery still good for FF?
    MT5-49/H8
