New contender for single din carplay | Page 11 | FerrariChat
Discussion in '360/430' started by GogglesPisano, Apr 12, 2024.
  1. wtam608
    wtam608 Rookie
    Sep 24, 2015
    46
    Gr430 likes this.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    OMG, you’re absolutely right. I just went to check mine. I could have sworn there was a hole left there, but the nub is still in there. So much for me providing good advice on here. Thank you for your correction on this. Hopefully I didn’t lead someone to damage their unit.
  3. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    Ok so what's the adapter to buy? Haven't moved my F430 off the rack yet.
    *Rubs 6105 nub for good luck*
  4. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    Thanks. This darn radio has triggered an all out arms race in my garage. I need every car now to have similar level of Carplay/Speakers+quality amps/etc.
    Before I didn't really care. This car has engine music etc. This car just sucks so whatever. Now that this deck is so cheap there is no excuse.
    DanNE, Plainview and MaranelloMark like this.
  5. CoreyNJ
    CoreyNJ Formula 3
    2,447
    New Jersey Shore
    I'm curious, has anyone figured out how to replace the startup screen on the CP-71 yet? Figure it's android, so some one has hacked it.
    Flea7 and wtam608 like this.
  6. oc23
    oc23 Formula Junior
    458
    Rob Yo
    Just triple checking to make sure - so if I have the Bose system I don't need to solder anything at all?
  7. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
    You’ll have to solder the harness that comes with the CP-71 to the harness in the links above. You’re joining two generic harnesses together - one that fits the CP-71 and one that fits the plug for the stock harness in the car.
    look at wtam608’s post above (post #251).
  8. GogglesPisano
    3,205
    Joe
    What Jeremy said,
    You need to solder (or use one of those solderless connectors) to join the two harnesses together.
  9. oc23
    oc23 Formula Junior
    458
    Rob Yo
    Got it, thanks guys.
    jerbear27 likes this.
  10. CoreyNJ
    CoreyNJ Formula 3
    2,447
    New Jersey Shore
    Ok. I ordered one of the CP-71 radios from Walmart. Since no one figured out the startup logo yet I think I will not install it in the car but hook it up to a bench supply and see if I can hack it. Might not get to it for a couple of weeks because of how busy I am at work. Wish me luck.
    kestrou, benzo1968, wtam608 and 2 others like this.
  11. GogglesPisano
    3,205
    Joe
    Good luck!
    Pretty sure it's some sort of android auto software.
  12. robst
    robst Karting
    Mar 9, 2024
    108
    Houston
    Rob
    Keep us posted
  13. WantaF430
    WantaF430 Karting
    170
    Fort Worth
    Joseph (Joe)
    Good Luck!
    Ill mail you a beer or two upon successfully copying you to load in my car lol.
  14. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    677
    Hi guys does anybody have this on a 360? I assume it's similar as the 430 for the install...or am I missing it?
    Also any pics on how it looks on the 360? Since the car is a bit more....dated in the interior?
    greg328 likes this.
  15. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    280
    Just purchased one. I will update on the install once I get it. Thanks to everyone who contributed!
  16. benzo1968
    benzo1968 Karting
    May 3, 2020
    78
    Ben Clarke
    DanNE likes this.
  17. benzo1968
    benzo1968 Karting
    May 3, 2020
    78
    Ben Clarke
    Def keep us posted with how you go - I'd def be in on the action to compensate you for your efforts to get the same in mine!
  18. DanNE
    Jun 7, 2013
    677
  19. benzo1968
    benzo1968 Karting
    May 3, 2020
    78
    Ben Clarke
    CD Changer is no longer used (actually, i ditched that a while ago for a bluetooth module on the Becker deck).
    I went with the Metra 70-1786 harness, and also got a radio adaptor. SUPER easy to wire/install - I took my time and had to run to the basement to get soldering iron, etc., and I was approx 45 minutes from start to finish.
  20. DanNE
    Jun 7, 2013
    677
    Thanks @benzo1968 -- can you advise on the radio adaptor is this a separate module and does it connect with the harness? Or directly into the new head unit?
  21. benzo1968
    benzo1968 Karting
    May 3, 2020
    78
    Ben Clarke
    It's just an additional extension that goes on the end of the plug that goes into the back of the deck. Someone else mentioned that their factory Becker deck has this extension - you just need to remove if, but that wasn't the case for mine - I bought this:
    https://a.co/d/9jJxPPq
  22. wtam608
    wtam608 Rookie
    Sep 24, 2015
    46
    IT IS NOT AN EXTENTION ON THE ORIGINAL UNIT. DO NOT TRY TO REMOVE IT. I use what benzo1968 posted.
  23. DanNE
    Jun 7, 2013
    677
    Thanks the link did not work for me it goes to some offer spam site...
    So with the mantra is there any issue with the coax outputs from the speakers? Does it make a difference to connect to the other speaker pins?
    Finally does the head unit come with a harness which matches the plug on the unit to open wires?
  24. ThunderDent
    ThunderDent Karting
    Jul 24, 2023
    59
    Barboursville, WV
    Joel
    Great find and thread
    Hope the splash screen gets hacked!
