New contender for single din carplay | Page 13 | FerrariChat
Discussion in '360/430' started by GogglesPisano, Apr 12, 2024.
  1. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    Thank you!!
    How would I remove the clarion nz503 that’s installed? Assuming I need to get the keys not sure where to put them.
  2. goto35march
    goto35march Karting
    Jul 23, 2009
    231
  3. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    230
    Lenoir City, TN
    Scott Williams
    The floating touchscreen units just don’t look right in these cars
    robst and oc23 like this.
  4. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
  5. goto35march
    goto35march Karting
    Jul 23, 2009
    231
  6. jerbear27
    299
    CT
    Jeremy
    I think you have to remove that black plastic trim piece. You just have to be careful as there are small plastic tabs on the back of it that can break. You should be able to grab that trim piece and squeeze it from top and bottom to remove it. That should give you access to use the keys.
    Or wait until you get the keys and see if they will slide down the sides of the unit with the trim piece still installed.
  7. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    677
    That looks amazing!
    EJW likes this.
  8. CoreyNJ
    CoreyNJ Formula 3
    2,447
    New Jersey Shore
    As I am ordering cables right now... Does anyone if Amazon has a GPS adapter needed to plug the factory antenna into the Power Acoustik?
  9. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I linked a place that has it. Wiclic to SMA
  10. Pashaj
    Pashaj Karting
    87
    NYC
    PJS
    It'll take a little time to receive. I ordered it on a Sunday night, granted Monday was Memorial Day but I received it the following Monday via USPS.
  11. Pashaj
    Pashaj Karting
    87
    NYC
    PJS
  12. CoreyNJ
    CoreyNJ Formula 3
    2,447
    New Jersey Shore
  13. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    230
    Lenoir City, TN
    Scott Williams
    i still dont know what the GPS antenna is for? it does not have navigation unless you are using the carplay?
  14. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
  15. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    280
    Just got mine installed. Everything works great. I just wanted to share a small problem I had so you can save yourselves some headaches if you come across the same issue. I have an aftermarket system already in the car, HU, amp, and subwoofer. The head unit was super old and didn't even have bluetooth, let alone CarPlay. When the new power acoustic HU was initially installed everything worked great except that I could not hear anyone on the other end of the phone. They could hear me, the music worked fine, turn by turn worked fine, etc. It turns out that this HU only puts the phone/messages/Siri through the front speakers. Mine was installed with the RCA's plugged into the rear pre-outs. So the music worked fine when the fader was set all the way to the rear, but nothing when it was set to the front. Simply switching the RCA cables to the front pre-outs fixed the problem. Just a tip for anyone using the pre-outs with an aftermarket amp.
    Enjoy!
  16. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    Thank you. So to confirm my connections and wires should look like yours right? So i only need to connect 5 wires?
  17. wtam608
    wtam608 Rookie
    Sep 24, 2015
    46
    Yes, also the connections to the little white connector. (Blue/white is the AMP on signal, Brown is the handbrake (connects to the ground.))
  18. goto35march
    goto35march Karting
    Jul 23, 2009
    231
  19. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    EJW likes this.
  20. EJW
    EJW Rookie
    Feb 22, 2024
    21
    PNW USA
    Nice clean install.
    The Pioneer flip-out DIN I took out (installed by PO) must have been wired by a 10 year old. Unused wires, everything taped together… smh. Problem solved fortunately.
  21. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    Ok installed! Wow this thing is the best thing ever.
    But the biggest problem is that my Claion nx503 Ferrari unit has a trim.
    Without the trim looks like this Image Unavailable, Please Login
    So I put the button and trim back with tape for now
    But in the original Clarion box I ended up finding one price Image Unavailable, Please Login Image Unavailable, Please Login
    I’ll need to order the other piece.
    OP THANK YOU SO MUCH
    REST OF YOU THAT HELPED IM SO GRATEFUL TO YOU.
    Best upgrade ever.
  22. jerbear27
    299
    CT
    Jeremy
    Nicely done! Flip the trim piece around - it’s upside down…
    Denzel Yang likes this.
  23. Exvetteguy
    Exvetteguy Karting
    Aug 5, 2012
    122
    Wolcott Ct
    Eric Schifilliti
    Just Ordered Mine...Thank You For The Info...Already Have A Aftermarket Alpine So Hopefully Its Just Plug And Play!
  24. goto35march
    goto35march Karting
    Jul 23, 2009
    231
