New contender for single din carplay | Page 14 | FerrariChat
Discussion in '360/430' started by GogglesPisano, Apr 12, 2024.
  1. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
    Believe it only comes as part of the window switch… new they look to be $161 or so. Maybe you can find a used one on eBay or somewhere else, especially as you don’t care about the condition of the switch.
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/430-group/f430-05-08/dashboard-and-tunnel-instruments.html
  2. goto35march
    goto35march Karting
    Jul 23, 2009
    233
    Does anyone have the screw size for these 3 screws? Ricami is saying its not listed on the parts diagram.
    Could someone take a photo if are installing their unit?
  3. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    OK, getting ready to build my Power Acoustik harness for my Bose system and many things do not make sense with the recommended Metra harness which just arrived from Amazon. I haven’t removed my radio in a while so I pulled the Becker Cascade install doc.
    Looking at the Becker docs i can see the reverse signal is sent, but the Metra cable doesn’t have a pin/wire for it. I’ll have to add a wire for that.
    I also know the Becker radio line out is on connector C1 not connector B which the Metra uses for the RCA plugs. The lines the Metra use on connector B are for powered, not line level according to Becker, so I expect the Bose amp doesn’t use them and instead uses the line out on connector C1.
    When I pull my radio I can confirm this, but can someone who has a Bose setup post a picture of your harness for the Power Acoustic?
  4. RS RS
    RS RS Rookie
    Aug 14, 2019
    38
    usa
    It looks like that his unit will soon support Android Auto and customizable background images. The walmart page reflects this with an option to download new firmware. Unfortunately, the download link shows the firmware as coming soon.
    It does look promising for Android users.
    Sj_engr and anotherred360 like this.
  5. MaranelloMark
    MaranelloMark Formula Junior
    439
    Bay Area, CA
    I don’t know why, but I find this thread more interesting than the ones about how often I should change timing belts.
    [emoji23][emoji23]
    kestrou, fossilfuel and Pashaj like this.
  6. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    I imagine you would want to create a connection into the BOSE amp inputs with the low level RCA outputs of the new deck.
    Perhaps you can get a mini-ISO extension to cut up to access the various Line Out (which would go Line In) to the amp?
  7. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    I actually ordered one of these cables last night to cut up. I also need to figure out which de-pining tool I need for these connectors.
  8. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    You’ll need the harness adapter with the RCA connections to connect directly to the head unit.
    mine is the same.
    robst likes this.
  9. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    How does this work for your Bose unit? You don't have the Bass signal hooked up, the Power Acoustik's RCA output are line level which you are then feeding into the speaker level inputs? Doesn't the Bose use the yellow connector (C1) for the audio input or did you bypass your Bose amplifier (8800)?
  10. GogglesPisano
    3,213
    Joe
    Works fine. Sub works too. I connected it the same way the previous owner had it done at an audio shop. As far as I know, you simply need line level in to the usually speaker harness and the Bose amp takes care of the rest.
  11. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    Wait the owner of the car previously had audio modifications? Maybe your car is different then mine which has the stock unmodified Bose setup.
  12. GogglesPisano
    3,213
    Joe
    They only replaced the head unit so it was stock except for that.
  13. CoreyNJ
    CoreyNJ Formula 3
    2,469
    New Jersey Shore
    I guess I'll pull my radio to see if the yellow connector (C1) is wired up and in use. I suspect it is as there were some references to the yellow connector here on Ferrarichat for the Bose. Are you sure they didn't bypass the amp or add a line converter when they changed the head unit. It seems to be the easiest thing to do if you don't care about keeping the Bose
  14. GogglesPisano
    3,213
    Joe
    I've done a deep dive inside to see what was installed and I have the original invoice. No line converter, just the harness adapter that takes pre-amp out directly into the harness.
  15. Exvetteguy
    Exvetteguy Karting
    Aug 5, 2012
    122
    Wolcott Ct
    Eric Schifilliti
  16. BAturb
    BAturb Formula Junior
    Nov 14, 2007
    550
    Australia
    Allan
  17. Exvetteguy
    Exvetteguy Karting
    Aug 5, 2012
    122
    Wolcott Ct
    Eric Schifilliti
  18. GogglesPisano
    3,213
    Joe
    That was a different unit altogether. Notice the screen extends above the radio opening in his picture.
    Exvetteguy likes this.
  19. grtoz
    grtoz Karting
    Dec 14, 2010
    164
    Byron Bay, Australia
    Graeme Towers
    I looked at this but it won't fit. The nose is too large (189 mm x 71 mm). It needs to be approx 188 mm x 58 mm.
    Sent from my SM-G955F using FerrariChat.com mobile app
  20. Exvetteguy
    Exvetteguy Karting
    Aug 5, 2012
    122
    Wolcott Ct
    Eric Schifilliti
    I verified my front speakers are stock tonight…I love how the new radio looks but sounds awful…(even the alpine was awful) the speakers break up especially if you turn it up where u can actually hear it over the Tubi exhaust…willl just upgrading the speakers fix the issue or do I need a amp…what’s the difference between the plug and play speakers at scuderia audio https://scuderiaaudio.com/product/360-audison-6-5-plug-play-system/ And these that appear to be the same on eBay ? https://www.ebay.com/itm/235549885064?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=lasbGYihQ-m&sssrc=4429486&ssuid=BI0GYspITgu&var=&widget_ver=artemis&media=COPY
  21. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    230
    Lenoir City, TN
    Scott Williams
    I just have some pioneer 6.5 3 way speakers that fit right in with the Factory speaker grills. You don’t really need to spend hundreds of $ on those unless you just want to. I still have the factory tweeters also.
  22. MinoclanF1
    MinoclanF1 Karting
    108
    Mendham Township, NJ
    Paul H. Ciancimino
    I installed my Power Acoustik unit on Sunday, and it looks and works great. I also tried the update, which didn't go well. I think it is for Android Auto, but I use an iPhone, so I don't care.
  23. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    696
    Wait - is there an Android Auto update for Power Acoustik unit? I just sent mine back because it was Apple only...and we are an Android household :-(
    LorenzoR likes this.
  24. DanNE
    Jun 7, 2013
    696
    Is the unit not sitting flush with the rest of the surrounding area?
  25. MinoclanF1
    MinoclanF1 Karting
    108
    Paul H. Ciancimino
    The Android upgrade was just released.
