New contender for single din carplay | Page 6 | FerrariChat
Discussion in '360/430' started by GogglesPisano, Apr 12, 2024.
  1. docapl
    docapl Formula Junior
    Apr 26, 2002
    401
    SF Bay Area
    Anthony
    So is it correct that both this harness from Scuderia Audio, and the Amazon one you linked to earlier are needed and the wires need to be soldered together to make it all work?
    I ordred the radio at Walmart and want to make sure I have all the other wiring that is needed.
    Thanks!
    Anthony
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,976
    East Bay, California
    Joe
    You only need one, they’re both the same. If you want to support a forum sponsor, go with the scuderia audio one.
    greg328, docapl and jerbear27 like this.
  3. jerbear27
    jerbear27 Formula Junior
    289
    CT
    Jeremy
    If you have the HiFi system (not Bose), then yes, you need that harness I linked. You’ll have to join that harness with the harness from the power acoustic radio with those solder connectors or via some other method.
    On the back of the packaging of that harness you’re going to buy it will tell you what each colored wire is for (ACC, Power, Ground, Left Speaker, Right Speaker, etc.). You’ll match those up to the wires on the power acoustik radio (they are labeled as well). Here’s the back of the packaging:
    Jaywhitebc and robst like this.
  4. docapl
    Apr 26, 2002
    401
    SF Bay Area
    Anthony
    @jerbear27 and @GogglesPisano - Thank you! That really clarifies what is needed. Look forward the the project once I receive enerything.
  5. AandSC
    AandSC Formula Junior
    919
    Jax, FL
    Allen
    I’m interested in this setup, but primarily for Waze. I’ve googled and can’t find a single din Waze image. Would someone mind either taking a pic or letting me know how usable Waze is on these? Thanks in advance (realize I’ve asked this once already but I think my request was lost in the conversation).
  6. RossoF430
    RossoF430 Karting
    Jun 6, 2022
    142
    Clint
    My previous head unit is an Alpine and was connected to a crossover to amp to speakers. The picture below show the connections - aside from ACC, BATT, Ground, the only other connections are for the 4 speaker wire pairs. I did not connect the car antenna or the GPS antenna. I have to say that the Alpine unit was clean, no white noise or hiss, so I am pretty certain the fault is with the unit. Also, I called 3 people using Carplay and all calls had echo on the other side (my side of the call was very clean).
  7. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    215
    Lenoir City, TN
    Scott Williams
    If you want to use this unit for calls, you are going to need an external mic. There is a jack on the back of the unit for one. Maybe you have a bad ground, or maybe the unit is defective? You should go get another one and try it out if your local wal mart has one. The good thing about Walmart is their generous return policy.
    GogglesPisano likes this.
  8. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    215
    Lenoir City, TN
    Scott Williams
    I will try to take a pic for you, but it works just like any of the other CarPlay units. The screen is just a little smaller.
    AandSC likes this.
  9. benzo1968
    benzo1968 Karting
    May 3, 2020
    77
    Ben Clarke
    I took this video for someone else curious about Google Maps, but basically the same:
    https://share.icloud.com/photos/0d6wL4lmYrE2E6k4AE4XTprEw
  10. houtie123
    houtie123 Formula Junior
    Dec 9, 2007
    547
    Cape Town, RSA
    Andrew
    Does anyone know if this will plug and play as I have the Bose factory fit in my car
  11. GogglesPisano
    2,976
    Joe
    Yes, works fine. I have the Bose as well. You just need the harness with the RCA inputs. Read through the thread and you’ll see the links and references.
  12. GogglesPisano
    2,976
    Joe
    You should have illumination and the amp wire connected as well. Also, go ahead and ground out the parking brake override. Sometimes, you still need the amp wire connected to trigger factory processor controls. I don’t know if that’s the case here, but it won’t hurt to have it connected.
    Like what was mentioned above though, there’s a chance you have a faulty unit. Maybe try re-pairing your Bluetooth connection as well after a reboot.
    jerbear27 likes this.
  13. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    215
    Lenoir City, TN
    Scott Williams
    So I went through the owners manual, and there is no navigation software for this unit besides CarPlay apps. What is the purpose of the GPS antenna? I didn’t hook it up, but what’s the advantage to doing so??
    Burli81 likes this.
  14. Dmartin
    Dmartin Rookie
    16
    Los Angeles, CA
    David Martin
    I bought one up in Simi Valley for my 360, but I never thought about getting another for my S2000! Great idea!
  15. dakilla
    dakilla Karting
    Jun 18, 2006
    57
    NYC
  16. AandSC
    919
    Jax, FL
    Allen
    Thanks Ben and Scott! Just want to make sure the app is usable on the smaller screen.
    benzo1968 likes this.
  17. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,580
    San Jose
    dc
    #142 Sj_engr, Apr 20, 2024
    Jaymac, robst and dakilla like this.
  18. jerbear27
    289
    CT
    Jeremy
    Did you wire those RCAs into the harness? If so you have to plug them into the back of the head unit. Tough to tell with that picture.
    also you probably need the blue/white wire run in order to send a signal to the amp to tell it to turn on. Doesn’t look like it’s connected but I can’t tell.
  19. swc5150
    swc5150 Formula Junior
    696
    Wisconsin
    Scott Calderwood
    imahorse likes this.
  20. WantaF430
    WantaF430 Karting
    May 10, 2023
    151
    Fort Worth
    Joseph (Joe)
    I don’t know about you, but I’m feeling teentyyytwoooo
    swc5150 likes this.
  21. swc5150
    696
    Wisconsin
    Scott Calderwood
    We’re a family of unapologetic Swifties! Our daughter is 9 after all:)
    GogglesPisano and MaranelloMark like this.
  22. WantaF430
    WantaF430 Karting
    May 10, 2023
    151
    Fort Worth
    Joseph (Joe)
    lol you are safe here sir, I’m the resident Swiftie here. I don’t want to derail the thread lol.
    This single din is a great find. Glad I saw it here and got one before they went out of stock. Wild it took this long for someone to step to the plate.
    I am ready to pay someone for the Ferrari splash screen… that’s above my pay grade.
    swc5150 and MaranelloMark like this.
  23. swc5150
    696
    Wisconsin
    Scott Calderwood
    I can't believe it was only $140 and from Walmart. Really brings the cabin into 2024 and I'm shocked how good it sounds.
    MaranelloMark likes this.
  24. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    215
    Lenoir City, TN
    Scott Williams
    A Ferrari splash screen would take this unit over the finish line!
  25. Jimmysmith
    Jimmysmith Karting
    Mar 5, 2023
    62
    Jim smith
    Given that these head units are so popular with the BMW and S2000 guys, hopefully it’s only a matter of time until someone figures it out.
