New Guy First Post 360 Questions on Suspension Malfunction Light | FerrariChat
Discussion in '360/430' started by Michael200, Apr 15, 2014.
  1. Michael200
    Michael200 Rookie
    Apr 14, 2014
    17
    Phoenix AZ
    Purchased a 360 Cpe a couple weeks ago. Have already established a love-hate relationship with the car. Disappointing problem with the "suspension malfunction" light, happened the first time I drove the car after it was delivered. Have searched threads and have a general understanding of the possible reasons for the "suspension malfunction" light. Warning light comes on after driving a few minutes, goes out if you stop and restart the car, then comes back on after a few minutes of driving again. Suspension seems really stiff no noticible difference in "sport" or normal mode. Car had been sitting for several months at a time before buying it. Could that be a possible factor? But I have put over 200 miles on it and the problem continues. Also had a problem when parking the car last night in the garage turned off engine and could hear a humming noise in the rear area, seemed like an electrical load of some kind, and occasionally a pump would run for a few seconds. Got back in the car, turned the key on and made sure the trans was in N, shut off key and humming and pump stopped. Is that a pump relay issue? Also, any sound advice on the "suspension malfunction" light would be appreciated, I'm 100% DIY and capable, and would like to avoid dealer help if possible.
  2. DonJuan348
    DonJuan348 F1 Rookie Owner
    Aug 5, 2008
    4,442
    Taxing Jersey
    First , it could be one of three accelometers which I will be changing on mine this month . Second, it could be one of the shock actuators. There's a company that rebuilds them for about $150 each which I will also be changing .
  3. hangarsixco
    hangarsixco Formula Junior
    Oct 10, 2010
    396
    S. California
    Chris
    +1
    Have it scanned and you will have your answer. They are easily replaced if you are a DIY'er.
    Chris
  4. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,547
    Charleston, SC
    Curt
    there is absolutely no way to tell which component has failed without an sd2 scanner. could be a shock, more likely an accelerometer. you could buy all 3 used and then install them. should be about $150.. then again could be a bad shock actuator. perhaps check connections in the wheel wells.
  5. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,547
    Campbell, CA
    John Zornes
    And as I recall, the suspension goes hard when the suspension failure light goes on so that is normal, not a diagnostic indicator.
  6. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    Los Angeles, CA / Henderson, NV
    If you read through various threads on new ownership, you will learn that everyone who buys one of these cars gets hits with an error light either on the maiden drive (but never on the test drive!) or within the first 24hours of ownership. Welcome to the club!
    In case it didn't register with the other replies, take it in for service. This isn't a catastrophic failure and is probably easily fixed. What it costs is another thing.
  7. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    I have the same error with my F430. It didn't happen until after 600+ miles of ownership. It was intermittent at first but now it is steady. Working on an appointment with a local Ferrari tech to get a download and go from there.
  8. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    As a matter of interest, it's accepted procedure to leave the car in first gear and handbrake off. I always do this and avoid the annoying warning sound that the car is in neutral and having the parking brake caliper stick to the rotor after say a week without driving. First time this happened I thought I had a major issue with the transmission as the car would not move in reverse when all of a sudden the caliper let go with a bang.
    Just my observation.
    Alan
  9. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ Owner Silver Subscribed
    Nov 29, 2009
    24,551
    Honolulu
    Kevin
    LOL
  10. Hardistyfezza
    Hardistyfezza Formula Junior
    Dec 1, 2013
    720
    Gods own county - UK
    Not funny - but it seems par for the course.
    Hope you get it fixed and is not too expensive!!
  11. Michael200
    Michael200 Rookie
    Apr 14, 2014
    17
    Phoenix AZ
    Update - I bought a used rear vertical acceleration sensor on e-bay for $35, after reading info from other guys this is the most likely one to fail due to the high heat area. Replaced the sensor last night, it's fairly easy to remove the passenger side engine bay panel, and replacing the sensor takes about two minutes. Drove the car about 50 miles, no warning light, looks like problem solved.
  12. up4speed
    up4speed F1 Rookie Silver Subscribed
    Feb 16, 2012
    3,700
    Long Island, NY
    Chris
    Awesome news!!
    I get very happy when I get to fix problems that easily. I know how you feel, I recently had a transmission error light come on randomly. An error code traced it to a bad brake light switch. It was also about $35 for the part and it took about 3 minutes to replace, No more problem. I was also a happy camper!
