new member, help! '83 308 GTS QV - slight noise in cam? | FerrariChat
Discussion in 'Technical Q&A' started by ferrari_rich, Oct 1, 2006.
  1. ferrari_rich
    ferrari_rich Karting
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    I'm a new member. Just got a '83 308 GTS QV - seems to have a slight noise in camshaft??? Is it safe to drive it to repair shop? It just had the timing belts done, could this be related?
  2. PeterS
    PeterS Five Time F1 World Champ
    52,571
    Goodyear, AZ
    PeterS
    When in doubt, flatbed it to a mechanic or ask a mechanic to drop by your house to look at it. If you are a new customer and their are 2-3 F mechanics in your area, find one that will come to your house and give THAT mechanic ALL of your business.
  3. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    did you change the cam belt bearings?
  4. ferrari_rich
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    No, just the belts. But it sounds as though the noise is from under the valve cover. Camshaft area. Also, is this quatro valve an "interference" motor.
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    No offense, but if you/they went to all the trouble to get in, change the belts why not change the tensioner bearings while your in there? A "new" belt will be toast in a minute when an "old" bearing goes tits' up.
    Anyway, what does the noise sound like? Ticking, clanking, metalic, etc...
    I just had a "ticking" noise that I had never heard before. Sounded like it was under the cam cover as well. With some great advice hear it's turned out to be a plug wire or extension going bad.
  6. ferrari_rich
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    sounds to me like a bad bearing, maybe? It is very slight. Are there bearings at end of each camshaft?
    I also have a slight exhaust leak that needs to be addressed. I can't tell where it it is coming from, and only noticeable between 2000 and 3000 RPM, under pressure. Are leaks like this hard to get at. It's probably a gasket, maybe even as simple as tightening.
  7. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    middle of timing belt. take a long screwdriver and pointed to the bearings the other end to your ear and listen .
  8. Glassman
    Glassman F1 World Champ
    Before you go too far check the exhaust emission air rails for pin hole leaks. These have a tendancy to rust out easily and will give you an exhaust leak with a slight ticking sound. These are a bear to replace so I patched mine with a hose clamp and a piece of aluminum strap for a temporary fix.
  9. ferrari_rich
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    Thanks for the advice.
    Question: Is this and interference motor? Will it crash valves if timing belt fails?
    Also, need good Ferrari mechanic on Long Island, New York. I have a line on a good exotic repair shop near me, but I would like to find someone had the experience with this car. Is there a listing somewhere?
  10. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    All Ferrari motors are interference motors. If the belt breaks, it will be very expensive.
    Brian
  11. ferrari_rich
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    What might the cost be of an engine rebuild?
  12. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Probably in the $10,000 range, though I'm not sure on exact dollar amounts for the QV motors. I suppose it all depends on how bad it is inside.
  13. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,830
    Cerritos, CA.
    Was it making noise BEFORE the belt was change? Or maybe its just a valve clearance issue.
  14. ferrari_rich
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    the car has about 300 miles since belt change. I did not notice the sound until now. But that's not to say that it hasn't always been there. I'm not sure. It is a VERY slight noise, not heard in the cockpit, only with lid opened.
    also, where is the "exhaust emision air rail" (mentioned earlier) located, can't find mention of it in the manual. because that sounds like it could be the problem of exhaust leak. Though slight as it is, it disrupts the music that the sound of this thing makes. Awesome!
  15. Mantinger
    Mantinger Karting
    Jul 30, 2004
    145
    Netherlands, Drenthe
    H
    Maybe it is a broken valve-spring. The valve wil still be operated by the inner spring. The broken spring however produces a slight rattling noise.
    You have to remove valve-covers to investigate the springs. Use a mirror and the broken spring wil be found.
    Hopely this is not the case. Repair is possible without removing the head.
  16. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Are you sure it isn't your A/C compressor?
  17. Glassman
    Exhaust rail is located on each exhaust manifold. Four tubes per bank connect it to the manifold. It is silver in color and about 3/4" wide. The tube then comnnects to the left of the engine into the emission pump and other plumbing.
  18. deprince3
    deprince3 Rookie
    Jul 2, 2004
    6
    Medford, New Jersey
    Dan DePrince
    I have a 1985 gts qv, my ferrari mechanic is awesome, I am probably about 2 hours away (NJ 15 mins from Philadelphia), that may be too far for you to use them, but if you want I will ask the guys who they know and like in your area by Long Island. There name is Palmas Automotive and they specialize in early model ferraris. They have done a great job for me at a very reasonable prices and they offer towing anytime I need it. Let me know.
