NEW MID ENGINED V6 (LITTLE BROTHER) | Page 18 | FerrariChat
Discussion in '296' started by ajr550, Feb 28, 2019.
  1. Ale55andr0
    Ale55andr0 Karting
    May 23, 2019
    228
    ....mmm, so the new gen will have less/pair HP of the "old" F8tributo/488pista o_O
  2. SoCal to az
    SoCal to az F1 World Champ
    14,228
    Arizona
    I would have thought 750 hp at a minimum.
  3. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,291
    I think the new little brother will be smaller in size.
    will it weigh more or less or about the same? ( given the extra weight of electric motors and battery).
    With the hybrid comes immediate torque and faster times
    I bet that the little brother will only need to outperform the F8 by a smidge.
    Also it will be interesting to see the pricing comparison
  4. PA Wolfpacker
    PA Wolfpacker Formula Junior
    Aug 19, 2007
    654
    Naples, FL
    Neil
    If that is the case then McLaren will be 2 car generations ahead of Ferrari in performance. The 720 has been outperforming the Pista in some comparisons so I suspect the LB will have a significant improvement over the F8.
  5. SoCal to az
    14,228
    Arizona
    I sure as hell hope so- otherwise the 765 is gonna blow them all away.
  6. Ale55andr0
    Ale55andr0 Karting
    May 23, 2019
    228
    and 765LT definitely kill it.
    I can't believe that the f8/488pista successor will have only ~700 hp and even more weight (imho 2 cylinders less hardly compensate the weight of a 7-8kw battery, electric motor and dedicated cooling)
  7. Ale55andr0
    Ale55andr0 Karting
    May 23, 2019
    228
    if you pretend that there is no competition out there, mclaren in particular ...
  8. maha
    maha F1 Rookie
    Mar 17, 2014
    3,414
    dinajpur, bangladesh
    mahmud
    i read here the v6 would be able to produce over 700 hp without any assistance
  9. red passion
    red passion Formula Junior
    Mar 4, 2012
    793
    Hockenheim, Germany
    Exactly, that's what someone mentioned here some time ago.
  10. SoCal to az
    14,228
    Arizona
    So 700 hp from v6. Another 125 from hybrid- 825 hp for little brother which makes more sense
    Senna1994 and LARRYH like this.
  11. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,361
    Le caylar (France)
    mathieu Jeantet
    Exactly
    700hp
    And 150hp more with the hybrid system
    Senna1994 likes this.
  12. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,109
    Toronto
    Joe
    Ha! Already more power then I will ever need :)
  13. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    7,751
    Tropical
    Will it still sound rubbish like the SF90? Even if it has 1500 hp without great sound track would be 'boring'.
  14. MalibuGuy
    Sep 18, 2007
    5,291
    I thought that the new V6 will have a smaller displacement than the current V8 which for the F8 is 3.9 L.
    A smaller discplacement with 2 fewer cylinders would be unlikely to produce the same HP
    The Porsche flat 6 twin turbo 3.8 liter produces less hp than the F8 V8.
  15. Ale55andr0
    Ale55andr0 Karting
    May 23, 2019
    228
    just a bit (700HP ~ same torque for the V6 GT2 RS). It's supposed that the next generation will have higher specific power (HP per liter)...
  16. day355
    day355 Formula 3
    Jun 25, 2006
    2,074
    Sound, sorry Noise, is worse than the SF 90
  17. 9nb
    9nb Formula Junior
    Sep 1, 2012
    633
    I think this, the SF90 and the 812VS will sound muted at idle and town speeds because of GPF. Have to wait for the final calibration and independent reviews or customer cars to get a better idea. At least this is my hope.
  18. MalibuGuy
    Sep 18, 2007
    5,291
    They say that because the GPF is located further away from the front-mid engine in the 812, that the engine music is not affected as much as the mid-rear V8s since the longer length of the exhaust plumbing produces engine music In spite of the GPF. (Of course deleting the GPF would be better. And if you believe the naysayers, the GPF requirement is based on deceptive science since it does little to address the stated goals of the regulation. Sorry to digress!)
    ferrarifanatic25 likes this.
  19. red passion
    Mar 4, 2012
    793
    Hockenheim, Germany
    Didn’t you told us some time ago that the Little Brother will be more exciting than the SF90 and that it is also internally a well beloved project?
    9nb likes this.
  20. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,251
    Austin TX
    That seems contrary to what GPF devices require, specifically, heat and lots of it. It only makes sense the GPF be attached to the exhaust header or as close as possible to achieve maximum heat for 'passive regeneration'.
    Do you know who said/indicated that it is further away?
  21. MANDALAY
    MANDALAY F1 World Champ
    Owner Rossa Subscribed Silver Subscribed
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    Any update on the release because of the Covid virus ?
  22. MalibuGuy
    Sep 18, 2007
    5,291
    i read that here on FChat.
    Go figure.
  23. Solid State
    Solid State F1 Veteran
    9,652
    Maximus Decimus Meridius
    I think they posted that the GPF is part of the cats right at the headers to form a three-way converter. I think same with mid-engines. The reason why affects them differently is because you have a high compression big block 6.5l NA V12 and a low compression small block turbocharged V8. The latter has such little sound to begin with that muting it further results in what we hear. The NA V12 has a lot more to start with but the GPF ruins the F1 sound as you would expect from another filter blocking the engine.
    polishhammer83, MalibuGuy and day355 like this.
  24. day355
    day355 Formula 3
    Jun 25, 2006
    2,074
    The design, for sure, is very attractive ! but the sound is a disaster...
    of2worlds likes this.
