NEW MODEL KIT THREAD | Page 17 | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by F1tommy, Jan 3, 2008.
  1. F1tommy
    F1tommy F1 World Champ
    11,716
    Sugar Grove USA
    Tom Tanner
    His kits are very nice, but he is more of an artist than engineer.
    The Profil 24 kits bodies sometimes capture the look of the cars better than even Hiro, but they are not nearly as good at engineering.
    The SCUD 16M is a transkit.
    Tom Tanner/Scale Designs/Ferrari Expo-Strictly 43rd Revival model/photo contest-Chicago April 2010
  2. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,332
    Netherlands
    Hans
    #402 moriaan1, Jun 18, 2009
    new release in 1:12 kit and limited edition built...
    Ferrari 375 MM Berlinetta 1953
    MP12.44 1:12
    A - 24 Heures du Mans 1954
    #18 Porfirio Rubirosa / Count Innocente Biaggio - DNF
    B - Berlinetta Pininfarina competizione chassis 0380 - Genève
    Built model and kit box available
  3. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    #403 F1tommy, Jun 18, 2009
    Looks nice. I hope MG did a good job on the body!! I dont want to spend a 100 hours correcting it like on my last MG kit!! I wonder if they will do any other versions?
  4. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,332
    Netherlands
    Hans
    Building an MG is most of the times quite challenging....
  5. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    The Netherlands (071
    Ton
    Does "challenging" means bad quality or warped/broken parts? ...or just a challenge to build a complex model ;)
  6. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,332
    Netherlands
    Hans
    Mg's are pretty rough..
    I like a challenge, but builders without experience should be aware!
    My next project is a 250TR from which the front of the chassis needs to be corrected, wheels are in the headlight-area.
    Engine is in the right position, so the frame needs adjustment in front of the engine, and behind the suspension-mounts.
    I also have a 166MM which needs lots of ajustment, panels don't fit.
    Ton, I followed the progress on your F40, great work, and you shouldn't have a problem building an MG..
    Hans
  7. zoRob
    zoRob Formula 3
    Oct 31, 2006
    2,004
    Cambs, UK
    This might be a novice question as i have only been building around a year but why do some of these really expensive kits have so many problems? Should they not be perfect when i can get a Tamiya kit for £20 that fits together perfectly ?
  8. Dino Scuderia
    Dino Scuderia Formula Junior
    Sep 7, 2005
    565
    Southeast US
    Resin kits will never be perfect...and they are mostly made for the advanced modeler.
    Also they are in many cases one man operations who are not using CAD design equipment and other prototyping machinery.
    Price does not equal quality.
  9. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,332
    Netherlands
    Hans
    numbers made, availability, manual production, special models or versions, type of material...
  10. zoRob
    zoRob Formula 3
    Oct 31, 2006
    2,004
    Cambs, UK
    Thanks. So basically they are limited run models using different materials to people like Tamiya and producing cars that are not so 'mainstream'.
    I really like the look of the MFH FW16 but its a lot of money and i know i have no way near the skill level required to build it. Ill stick with my Fujimis and Tamiyas for now :)
  11. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    #411 Peperbus, Jun 19, 2009
    Bedankt Hans ...so it is matter of dry-fitting, sanding, filling, sanding, dry-fitting, sanding, filling, sanding ...I see :) I ordered the 250TR 1957 engine this afternoon as a kind of test run for this manufacturer. And the TR is on wish list too...great model.
    The F40 is almost finished..I guess a couple of weeks and than I am ready after 600+ hours and 16 month building and than this beauty will get a place in my "hall of fame" (very small one :) )
  12. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    That F40 is so nice!!
    On the MG kits, you might have to modify and reshape the body panels if you want to make it perfect. They are rather simple models, but become complicated due to the inaccuracy. Hiro kits are much better quality than MG kits(Not even on the same page), although they do make alot of small mistakes.
    Tom Tanner/Scale Designs/Ferrari Expo -Strictly 43rd Revival model/photo contest-Chicago April 2010
  13. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    We're in the same boat. :) I admire the work you guys are able to do, and the patience you do it with. :)
    Peperbus, that's look awesome, hope you can share the pictures with us when you are done.
  14. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    I definitely will :)
  15. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    Cool. :) We also need to see the rest of your Hall of Fame. ;)
  16. Philmodelcar
    Philmodelcar Karting
    May 19, 2004
    221
    Belgium
    Philippe
    #416 Philmodelcar, Jun 26, 2009
    Just a quick note for a specialist, tom, I just discovered that the Piper LM at Le Mans 1967 had different numbers on pilot and passenger doors, did you know it ?
    look at this picture (sorry for bad quality) bu the 21 from the pilot door is surrounded by a green line...
    phil
  17. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    #417 F1tommy, Jun 26, 2009
    Hi Phil,
    I had seen another shot from a different angle showing the different
    number on Car 21 from Lemans 1968. Was that from this French Lemans Ferrari book that I just ordered?? The first volume had some great color photos.
    Best,
    Tom Tanner/Scale Designs/Ferrari Expo-Strictly 43rd Revival 2010-Chicago
    April 2010
  18. Philmodelcar
    May 19, 2004
    221
    Belgium
    Philippe
    Yes, it comes from this book. You will like it. I'm pleased by both volumes as the text (in french...) in quite good, giving some funny little stories and in addition, probably the most important, I think that more than 80% of the pictures were not published in other books before !
  19. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    #419 F1tommy, Jul 1, 2009
    Here are some rare 1/18th scale kits. Not to many people build 1/18th since it is mainly a diecast built scale.
    MG 250MM 1/18th kit
    MG 350 P4 1/18th kit
    S.M. Model Art 412I 1/18th kit
    The quality is more toy like than model kit, although they do include nice photoetch that includes
    window frames. I wish Model Factory Hiro would include (BBR style) window frames in their kits.
  20. Dino Scuderia
    Sep 7, 2005
    565
    Southeast US
    I just finished the Tecnomodel 250 Sperimentale...I must say I'm not a fan of photo etch window frames. The metal look is fine but most frames are not dead flat like that so for realism sake they miss the mark.
  21. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    Thats true, but you can bend the frames so they will not be flat around
    the curves. They don't have a better way to do frames in .. kits ..(bare metal foil looks like crap compared to photoetch frames).
    One thing I will say, nickel works much better than stainless steel on photoetch as nickel can be bent without much trouble.
    Tom Tanner/Scale Designs/Ferrari Expo 2010-Chicago
  22. ItalianHorses
    ItalianHorses Formula Junior
    Feb 16, 2004
    390
    I could not disagree more.
  23. Dino Scuderia
    Sep 7, 2005
    565
    Southeast US
    I don't think either one is ideal...but well done BMF is not that bad...both are a compromise.
    There are a lot of photo etch parts that fail because they aren't 3D enough, window frames fall into that category in most cases.
  24. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    Thats true unless its a racing car model like the P4 wich only had flat sheet layed on a fragile door frame to hold the window in. What I like about photoetch is the crispness of the metal edge and also the clear glass installation with plastic sheet. The bare metal foil applications look more sloppy 99% of the time compared to the photoetch unless the modeler messed up the glass on the photoetch window. Your 250GT model has some of the best window frames around in a kit. The only thing I think they could have done was have it fold over to make 3D, but then the glass installation would have been very hard to intall. Good points dino scuderia.
    Alex, I hope you come to the Ferrari Expo 2010 so that I can show you why
    I dont agree with you 100% on this. Bare metal foil can look good if done well. Also some frames are black and photo etch looks good on them also.
    Tom Tanner/Scale Designs/Ferrari Expo 2010 model/photo contest- Chicago April 2010
  25. F1tommy
    11,716
    Sugar Grove USA
    Tom Tanner
    #425 F1tommy, Jul 4, 2009
