New Mondial owner - engine light on | FerrariChat
Discussion in 'Mondial' started by fangiofan, Jul 1, 2024.
  1. fangiofan
    fangiofan Rookie
    Mar 25, 2014
    14
    Vero Beach FL
    Peter
    I just bought a 1990 Mondial T, 18k miles, essentially one owner. Wanted a Ferrari I was not afraid to drive a lot after owning a couple that I kept as garage queens. Seller claimed my Mondial had an engine out belt change about 1 year and 200 miles ago, although the paperwork leaves me slightly suspicious. After 10 miles of fun driving, the 1-4 engine light has gone on. I ran the ECU test button, but I don’t know how to read the code that flashed on the light. Mechanic can check the car in a couple of weeks. Can I drive the car in the meantime, or should I just leave it? There is no smoke from exhaust, but there is a slight oil burn smell, which makes me think it may be a mixture issue. I was thinking of taking the plugs out to check them, but even if I do that, I guess the check engine light will still be on. Appreciate any thoughts.
    paulchua likes this.
  2. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,376
    Menlo Park, CA
    Paul Chua
    How to Befriend a 348/Mondial t ECUs:
    1. Strip Down the Trunk: Pop open the trunk and remove the felt covers facing the rear seats. This will expose the two mysterious ECUs (a.k.a. the car's twin brains). Each ECU represents one side of the engine.
    2. Ignition Ritual: Insert the key into the ignition and turn it to the “on” position.
    3. Button Press Extravaganza: Locate the magic button next to the ECU (there will be two). Press and hold it for a solid 5 seconds, then release. Voilà! The check engine light should now illuminate, indicating which ECU you’re communicating with.
    4. Flash Dance: Let go of the button and enjoy the pause before the long flash (2.5 seconds). This is the car’s way of saying, “Ready, set, go!” After this, the engine codes will start flashing at you like Morse code. Long flash means start and end of a code. Your are now fluent in blink-speak.
    5. Decipher the Blinks: Each number in the code is a half-second flash followed by a pause. It’s like a bizarre light show. For instance, if you see four flashes, pause, two flashes, pause, one flash, pause, and two flashes, you’ve got code 4212. Now you’re a certified car whisperer!
    6. Next Code, Please: To move on to the next code, wait for the long flash after the current code. Hold down the button during the long flash and release it during the pause. The check engine light will flash again, signaling the start of a new code.
    7. End of the Show: When you’ve pulled all the codes, the car will just keep giving you long flashes, saying, “That’s all, folks!”
    8. Erase the Evidence: To clear out the old codes and start fresh, wait for the ECU to give you nothing but long flashes. Then, push and hold the button for 10 seconds. The ECUs will sigh in relief as they forget all their old complaints. Congrats, you’ve just befriended your car’s ECUs!
    Now go forth, car tamer, and may your check engine light!
    Motronic 2.7 error codes:
    Hot wire air flow meter 1111
    Engine coolant temp sensor 1112
    Throttle potentiometer 1113
    Lambda sensor (O2 Sensor typically unplugged or bad ground or bad sensor) 1114
    RPM sensor 1121 (this code will be shown if checked when your engine is off)
    Battery voltage 1122
    Secondary air solenoid valve 1123
    Purge valve 1124 (the purge valves are marked as part #21 in this diagram)
    Lambda regulation Additive value for self adaptation (O2 sensor or coolant temperature sensor or MAF) 1211
    Lambda regulation multiplicative value for self adaptation 1212
    Lambda regulation intake manifold compensation (MAF or O2?) 1212 (1213?)
    Short circuit on idle regulator 1311
    Open circuit on idle regulator 1312
    Electronic control unit 1313
    Injection valve 1 1411
    Injection valve 4 1412
    Injection valve 2 1413
    Injection valve 3 1414
    Malfunction Indicator Lights (MIL) 1444 *dash light burned out
    Valve 4111
    Stroke sensor 4112
    Power module not used 4113
    TDC control unit recognition 4114
    Catalyzer temp ECU 4121
    Catalyzer temp too high 4122
    Speedometer signal 4123
    Compressor connection signal 4131
    No error detected 4444
    What code(s) are you getting?
    Alden likes this.
  3. fangiofan
    fangiofan Rookie
    Mar 25, 2014
    14
    Vero Beach FL
    Peter
    @paulchua Thank you!! This was just what I needed. Will pull the codes tomorrow morning.
  4. fangiofan
    fangiofan Rookie
    Mar 25, 2014
    14
    Vero Beach FL
    Peter
    @paulchua I got the engine codes this morning: 1211 Lambda regulation Additive value for self adaptation???? 1212 Lambda regulation multiplicative value… again ???? and 1121 RPM sensor (engine was off). 1211 and 1212 sound like rocket science to me…. can I drive the car while those errors are on?
    Thanks again for your help.
  5. PeterS
    PeterS Five Time F1 World Champ
    51,499
    Goodyear, AZ
    PeterS
    Post #5 at this link may be of some help 348 CEL - Error 1212 - Any advice? | FerrariChat
  6. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,376
    Menlo Park, CA
    Paul Chua
    Hi!
    I've had this code before and it came down to the MAF. Easy way to diagnose if this is the problem. Swap them out (very easy to do on your own) and see if the engine light codes swap. If the lights switch to the other side, you know you have a bad MAF. They are no longer in production. You can get generic ones from China but they won't have the same AF map. So I suggest you send them here for refurbishment ($250) You have to clear the codes outfirst and then go on a drive to have them light up again. Here is a photo of the MAF
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,376
    Menlo Park, CA
    Paul Chua
