new oil pressure sensor, and got oil pressure light | FerrariChat
Discussion in '360/430' started by 24000rpm, Sep 16, 2018.
  1. 24000rpm
    24000rpm F1 Rookie
    On for a split second and off. For a few times in 10 miles. Oil level's good.
    background 1. I have an incident before this, when I was removing the oil filter for access, the filter's o-ring dropped without my knowledge, so the oil splashed everywhere when I start the engine, for like 5 seconds.
    then I got everything back to normal.
    background 2. i used to mess with the instrument. Now the instrument's needle isn't accurate, oil pressure needle is set on 1/8 of the range without moving.
    am I getting a defective oil pressure sender? or forgot, this is a 360.
  2. 24000rpm
    24000rpm F1 Rookie
    oil temp at 89 celcius ( completely warmed up) and the oil pressure at idle on leonardo fluctuate between 0.6 bar to 1.2 bar.
    is that normal?
