New owner with ventilation problem | Page 10 | FerrariChat
Discussion in '348/355' started by Skiday, Feb 22, 2016.
  1. Qavion
    Qavion F1 World Champ
    14,600
    Ian Riddell
    The air direction actuator has 5 wires and has a built-in potentiometer for position control. The recirc actuator has two wires and doesn't care where it is.
    MAD828 likes this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ok that makes sense.
  3. cooper1330
    cooper1330 Rookie
    Feb 21, 2007
    1
    So is anyone selling these gear sets yet ?
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ugh wrong thread response above thought it was another thread, sorry.
    A company does sell the gears with a repair however. It's called ECU doctors or something like that.
    Sent using FerrariChat.com mobile app
  6. Leclems
    Leclems Rookie
    May 12, 2023
    1
    Clément bentejac
    Hello. I m very interested to by this. It is possible ? Thanks a lot
    Cole_ve and steved033 like this.
  7. Cole_ve
    Cole_ve Rookie
    May 29, 2018
    15
    Cole B
    I’m also interested. ECU repair has no repair service anymore. At least not available as of today….
  8. Cole_ve
    Cole_ve Rookie
    May 29, 2018
    15
    Cole B
    Hi. I’m wondering if you ever got these made?? I would love to buy one as there is NO availability of these units anywhere. Let me know…. Even a service like shapeways.com would be great…
    steved033 likes this.
  9. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,449
    Atlanta, GA
    Steve D.
    I did, PM me.
    sjd
  10. TinkerF355
    TinkerF355 Rookie
    Jul 10, 2022
    10
    France
    I'd also be interested
  11. steved033
    Apr 12, 2017
    10,449
    Atlanta, GA
    Steve D.
  12. austincarnut
    austincarnut Rookie
    Nov 10, 2023
    1
    AUSTIN
    gerald mitchell
    Are you selling the timing actuator gear? i need one also.
  13. steved033
    Apr 12, 2017
    10,449
    Atlanta, GA
    Steve D.
    shoot me a PM, I'll get to get another batch made.
    308 GTB likes this.
  14. P-92
    P-92 Rookie
    Nov 24, 2023
    1
    P-92
    Hi,
    Fantastic work on getting these gears created.
    I'm in a fortunate position where i have a 3D printer. would it be possible to get a copy of the CAD /(.stl) file so can can print a set for myself.
    I'd be very grateful.
    Kind Regards,
    Peter
    IvanRico likes this.
  15. PBRacer
    PBRacer Karting
    Nov 3, 2003
    164
    Virginia
    Stan
    FYI
    Eurospares.com now has a ferrari replacement for the 7100 actuator. Not the original style but supposed to be a ferrari superseded part alternative. Mine came in a ferrari parts box, etc
    Unfortunately that isnt my problem but for those looking for a new actuator
    Qavion and IvanRico like this.
  16. Philipnz
    Philipnz Karting
    Apr 12, 2015
    226
    Whitianga New Zealand
    Philip Hart
    I have just had this repaired on my car (i think the same thing) replacement actuator came from ferrari classique. Not the original part but one they have adapted. ECU turned out to be okay after a reset
  17. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Are there any identifying numbers and the name of the manufacture on the replacement part? It's likely an off the shelf item that can be purchased for much less else where.
  18. Qavion
    14,600
    Ian Riddell
    Here's a photo from Eurospares:
    Looks like some of the identifying marks have been melted away. The other numbers helped me find this:
    https://www.befr.ebay.be/itm/195186881585
    Looks like a wiring harness has been added. The internals may also have been changed. Poti 120° is printed on it. The Ferrari potentiometer moves through 180 degrees. The drive shaft also looks different.
  19. Philipnz
    Philipnz Karting
    Apr 12, 2015
    226
    Philip Hart
    That looks like it. The part my tech got was 869184 and price about what all the places are charging
  20. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Yes, melted part numbers. Real Ferrari stuff. LOL
    These actuators are a dime a dozen. A few years back I bought a couple to see if it they would work. The problem I had with the one that would have was that the shaft was too big and being hollow it could not be cut down to fit.
  21. Qavion
    14,600
    Ian Riddell
  22. vincentf355
    vincentf355 Karting
    Feb 24, 2010
    128
    Taipei
    vincent tseng
    For the broken gear of f355 timing actuator 63307100, after I bought one from Japan with crazy price, found a healthy genuine gear from same outlook actuator, molding and casting with improvements, I have precisely recovered and replicated genuine-like gears.
    The gear from Japan weights 3.4g runs ok but noisy due to off-centering or hard material I think, so I give up.
    The healthy genuine gear, which I have sourced some, weights 2.7g will eventually break due to life span, so I give up.
    Looking at genuine gear, the material of the broken part is different, so I recover my own which is genuine-like, 2.5g weight, similar material. solid, smooth and QUIET.
    Do not throw away your broken gear/faulty actuator, it can be recovered.
    Buckets, IvanRico and Qavion like this.
  23. steved033
    Apr 12, 2017
    10,449
    Atlanta, GA
    Steve D.
    clever!
    What material did you use for the new overmolded area?
    sjd
    vincentf355 likes this.
  24. vincentf355
    vincentf355 Karting
    Feb 24, 2010
    128
    Taipei
    vincent tseng
