New owner with ventilation problem | Page 4 | FerrariChat
Discussion in '348/355' started by Skiday, Feb 22, 2016.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    It is certainly safe to connect 12V power supply to pins 1 and 3 (+) but, before doing that, I would first test with an ohmmeter the function of the "STOP" button - connect the ohmmeter between the pin 1 (ground) and pin 4 (black) and see if the "STOP" button connects and disconnects the two pins. Then, connect the ohmmeter between pin 4 and pins 5-8 (one at a time) and see if you get varying resistances when you turn the knobs. If you don't get sensible results, try with the ohmmeter between pin 1 and pins 4-8. With this test, you should be able to find out which of the pins 4-8 is for the air direction control and what the other pins are for.
    You can do another test with 12V supply connected - check the voltages on the pins 4-8, with the negative voltmeter probe on pin 1, by turning the knobs and find out the voltages on which pin vary with the rotation of which knob. If this does not give yo sensible results, move the negative voltmeter probe to pin 4 and measure the voltages on the pins 5-8. Do both with the "STOP" button on and off.
    Let us know what you get.
  2. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    There is no resistance or connection between 1&4-8 or 4&5-8 with STOP in either position.
    I have applied power to 1 & 3 (3=pos) and placed neg probe of multimeter on neg (1) and gone through pins 4 - 8 with the pos probe. Sad to say it does not seem to be a simple 1 pin to 1 operation. The only controls that did seem to have a direct clear signal are the STOP and recirc buttons. Having STOP in up position (which illuminates it even though there is nothing on pin 2) causes pin 6 to give out 4v and pressing it down cuts this. Having RICIRC in up position causes pin 8 to give 4v and pressing it cuts this. However the remaining functions do not seem to work as you might expect. Pins 4, 5 & 7 give out nothing with STOP out, but only when I press STOP in do I get a weak signal from them. With the controls on Feet/Aut/Cold/STOP-in/Recirc-in I get 26 on 2000m setting ( I don't know what that means in volts) on pins 4, 5,& 7, but press Recirc IN and all three change to half that.
  3. Qavion
    Qavion F1 World Champ
    14,682
    Ian Riddell
    Looking at the photos posted on the forum, the air direction control knob seems to select a resistor or combination of resistors (located below the knob).
    It's very difficult to check resistances without pulling them off the board. The only way to check that you are actually checking a particular resistor is to check its colour code and see if that matches the ohmmeter reading. I guess it's a relatively good sign if none of them look burnt.
    I tried to follow the tracks on the circuit board (from the photos posted on the forum), but the resolution of the photos wasn't great enough. Pin 6 seems to be connected to R2 on the board, but I can't figure out where it goes from there.
    Pin 5 seems to go to pins on the air direction control knob. The poster of one photograph has labelled this as a common ground on the switch. I haven't been able to confirm this.
    I'm wondering if the diodes are affecting your voltage results.
  4. m.stojanovic
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    "26" on the "2000m" range of the voltmeter (I presume you have correctly used the DC Volts, not DC Amps on your multimeter) means 26 millivolts (0.026 Volts), practically nothing. I am surprised that you get no volt readings that vary when you turn the air control knob. I suggest you do the following further tests:
    1. Connect the power and switch the panel "on" (STOP button up, as I understand); set the multimeter at 20 volt range and, with the negative multimeter probe on Pin 1, measure the voltages on the two diodes (D1 and D2) at the points as shown on the picture
    2. See whether there is any component under the large blue disc.
    3. Repeat the earlier test measuring voltages on the pins 4-8 but this time turn the fan speed knob.
    4. With no power connected, set the multimeter at the continuity check position (200 Ohms range or sound/beep position, if you have it) and go through all resistors at the left side of the picture (near the air control knob). Put one probe on one side of the first resistor and measure the continuity against all other resistor points, left and right including the vertical resistor to the right of the knob. Then put one probe on the other side of the first resistor and repeat the continuity checks. Go to the next resistor and repeat etc. When you move to the next resistor, you don't need to check the continuity back, just forwards. During the process, record between which resistor points you have direct links (zero resistance or you get a "beep") then try to show it on a sketch and post it.
    5. Read the values of all resistors near the air control knob. If you are not familiar with the resistor colour coding, just right the colours of their stripes and post them.
    Well, you now have something interesting to do over the weekend.
  5. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    I thought i had posted hi-res photos, but it seems not. Here is both sides of the board with my lines to show pin 6 to STOP, where it comes from before the button is to difficult to follow for me. NOTE *the back of the circuit in the photo has been REVERSED to give the same orientation as the top side for ease of viewing.
    for full res go to- http://i63.tinypic.com/wcbdx0.jpg
    Now I'll try the things suggested.
  6. Qavion
    14,682
    Ian Riddell
    #81 Qavion, Dec 8, 2018
    Great photo, thanks for the link. I tried something similar with the image reversed.
    The forum reduces the size of larger photos.
    Unfortunately, the left hand terminal of R2 still looks like it goes nowhere. And why is there a terminal under R2? Does the track going to R2 extend under the resistor?
    Plug pin 3 (main power) is still untraceable because it sits under the plug. In theory, it should go to all knobs.
    Here's a link to a colour decoder for four, five and six band resistors:
    https://www.digikey.com.au/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band
    Unfortunately, the lighting is still not good enough to pick the colours from the photographs.
    e.g. R3 = orange, orange, brown(?), gold = 330 ohms with 5% tolerance
    Miro... on boards like this, would the blue capacitor be a main power voltage stabiliser or something to help reduce sparks when switches are activated?
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    #82 johnk..., Dec 8, 2018
    I don't believe the blue component is a cap. To quote. It's a "resettable fuse, a polymeric positive temperature coefficient (PPTC) device that is a passive electronic component used to protect against overcurrent faults in electronic circuits." At least that's what PTC stands for.
    Or it might just be positive temp coeff thermistor.
    Qavion likes this.
  8. m.stojanovic
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    The PC board is double sided so there are many links under the white face that are difficult to follow. If there is a small solder point on one side that seems not to be connected anywhere, it is usually a link to a line on the other side.
    Are the resistor colours indicated on this extract correct? (first 4 colours shown, ignore the 5th) I have also attached the PDF of this pic where you can directly do the corrections and post back.
  9. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    They are not easy to pick out even when looking in good light and through a magnifying glass, but I have done my best and learnt how to read them and test them. I have produced a Word doc. All but one are within tolerance (and it is only just outside). I have uploaded the file (I hope). I hope it may be of use to others in the future. As the resistors are all as they should be (as far as I can determine - the blue disc cannot be lifted) and the knob is proved working I'm going to now assume the unit is working and my problem lies elsewhere (although I've checked just about everything now. I can only think my next move is to reassemble it and take it to a dealer/specialist and try a diagnostics on it.
  10. F355Bob
    F355Bob Formula 3
    Could you have a bad sensor and the air diffuser stays in the default defroster vent position.?
    What about a bad ground? I've had this problem for years.
  11. Qavion
    14,682
    Ian Riddell
    I'm not sure how you managed to isolate the resistors in the circuit from the other resistors (I guess it's just the way the circuit is wired).
    Did you check the diodes D1 and D2 as per Miro's instructions (below)?
    The only reliable way to check the resistance of a diode is to pull one of the diode ends out of the circuit. Having said that, did you swap your black/red test leads around anyway and compare the readings? Does your meter have a specific diode checking function?
    Did you also try Miro's suggestion of disconnecting the control panel to see if the air direction motor ran?
    Thanks for your efforts producing the word doc!
  12. m.stojanovic
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    The reason why I asked to measure the voltages on the diodes D1 and D2 (at there ends where the black stripe is) is to determine whether they are Zener od ordinary diodes. If Zener (voltage stabiliser), the voltage readings should (most likely) be 5V. If no voltage or some higher voltage is present on the diodes, and if there is no voltage stabiliser under the large blue disc (like LM7805, TA78L005 etc.), then the control panel is probably getting stabilised 5V from the AC ECU and that could be the reason why there are no changing voltages on the (disconnected) control panel outputs when turning the knobs.
    How basically the air direction control works is that the microchip runs as an Op-amp voltage comparator - it monitors the voltage on the middle pin of the flap motor's potentiometer ("pot") and the voltage coming from the control panel's air direction switch. The range of these voltages is usually 0-5 V. Example:
    The air direction flap is positioned in the middle and the voltage on its motor's pot (middle pin) is, say 2.5 V. If the air direction switch is also set at middle flap position, the output voltage from the control panel for that flap position should also be 2.5 V and the flap will stay where it is (no power is applied to the flap motor by the microchip).
    If then the switch is turned to a lower flap position, the control panel will change the output for the flap control to, say, 1.5V. When the microchip sees the difference in the voltages between the motor's pot (2.5V) and the incoming 1.5V from the control panel, the microchip will run the motor (and it's pot) in the appropriate direction until the voltage on the motor's pot reaches 1.5V (equal to what's coming from the control panel switch) and then the microchip will stop the motor.
    Next change of the voltage from the control panel's switch (up or down) will result in the microchip running the motor again, in one or the other direction, in order to make the voltage on the motor's pot equal to what it receives from the control panel's switch. The motor's pot will have a specific voltage for each position of the air direction flap, in the span 0-5 V (or probably more like, say, 0.5 - 4.5 V). The resistors of the control panel's switch are accurately calibrated so that the switch produces the same voltages for its various positions as are required on the motor's pot for those flap positions. The panel's switch is actually just a potentiometer but, instead of continuously varying the voltage (like standard pots), it varies the voltage in fixed preset steps using various combinations of its resistors. As the accuracy of the voltages in the switch positions is important (to place the flap exactly where it should be), most of the resistors are of just 1% tolerance.
    It appears that the test of the air direction switch output voltages has to be done with the control panel connected to the AC ECU so that the panel can get the stable 5V reference voltage which the switch then varies (in steps) and sends it back to the ECU to control the flap position.
    Very good suggestion by "F355Bob". There could be something that causes the AC ECU to peg the air direction flap to the top (defrost) position. To test this, I would rotate the flap motor using a separate battery on the motor's (disconnected) wire plug and move the flap to its lowest position (feet). Then plug everything in, switch the ignition and the AC on and see whether the flap moves to the defrost position or stays where it is. If it moves, the problem is elsewhere, as suggested by Bob.
  13. Qavion
    14,682
    Ian Riddell
    It just seems odd that there are so many different voltages going to the control panel.
    I would have thought that manual selection of outlet position would override the sensors (?). In Auto, I believe at some ambient temperatures it will divert the air to the windscreen for a certain time period to prevent discomfort to the driver.
    Unfortunately, my car is working perfectly at the moment (knock on wood) and I'm not tempted to pull it apart to compare resistances/voltages :p
  14. m.stojanovic
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    The fairly standard voltage range for control of things by microchips is 0-5V. Also, the fan speed controller gets a varying 0-5V signal from the AC ECU to vary the fan speed from zero to full (the full speed comes on at about 4.7 V). So a 5V supply needs to be provided to all potentiometers (mechanical or digital) which is then varied by them 0-5V for control, via the microchips, of various functions (fan speed, heater valve opening-closing, air direction flap motor etc.). In the case of the air direction control, the 5V supply to the motor's potentiometer and to the selector switch on the control panel (the "step" potentiometer) most probably comes from the same source (a voltage step-down regulator) to eliminate any inaccuracy in the flap positioning due to any voltage fluctuation of the 5V source.
    If the diodes on the control panel are not Zener and if there is no voltage regulator on it, then one of the 5 wires (pins 4-8) between the AC ECU and the control panel probably carries the 5V supply to the control panel. The other four wires, carry the control signals from the panel to the AC ECU (three rotary switches/potentiometers and one RECIRC switch). The STOP switch then probably does not send any signal to the AC ECU but just switches the incoming 5V to the control panel on and off.
    Qavion likes this.
  15. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Hey guys
    I am very appreciative that so many knowledgeable people have helped by giving so much information and help. Please understand though that I am an electronic novice and just trying to understand things is somewhat bewildering, but I am trying to not give up on this. It feels like when you're in a strange town looking for a location and someone helpful has given you very clear instructions, but in a language you barely understand.
    I will try those tests suggested and come back. I did try reversing the probes of my multimeter on the diodes (I didn't know what they were till now) but the reading was identical both ways.
    BTW, are we absolutely 100% positive about the chip in the ecu controlling the direction being chip No.6? LorenzoR says he's 'pretty sure' but also that he only narrowed down the function of three of the chips. (Incidentally, I notice that the chips are labeled on the board with i.d.s beginning with a U. Would it not be better to use those numbers to i.d. the chips?) Perhaps if I had replaced all 6 I might have got a result - no one can be sure right?
  16. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    OK, I just did test 1. above. Nothing, not a flicker, zip, nill (power was deffo connected as STOP illuminated when pressed in and multimeter was on 20 V and 3 dots with line above {as opposed to V~})
    Re 2., The large blue disc is hot glued down so cannot be moved, but I have checked resistors from the back and they give readings as I reported in previous post.
  17. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
  18. Qavion
    14,682
    Ian Riddell
    Unfortunately, when diodes are in a circuit, you can never be sure you are checking the resistance of the diodes. If a diode's resistance is the same in both directions out of a circuit, you have a faulty diode.
    If there were no visible faults with the resistors, I would have recommended changing the diodes, but Miro is usually correct with his diagnoses (and your problem will lie outside the control panel).
    I assume Lorenzo was able to positively identify chips 4, 5 and 6 because there were circuit board tracks going from these chips directly to ECU pins (which are attached to specific external components)
    If the "U" numbers are readily identifiable, then perhaps this would help the technician changing the chip, but I don't think he/she would have too many problems if he/she had access to Lorenzo's FChat photographs.
    There are companies in the UK which specialise in the repair of the ECU. Unfortunately, we are still not 100% sure that the ECU is faulty and it might be difficult to find a volunteer to give you a loan ECU to see if it works on your car. Faulty external components are known to destroy ECUs.
    When you did your motor checks, was it fitted to the tambour when you saw the smoke?
    Did you check that the tambour rotated freely with the motor removed?
  19. Qavion
    14,682
    Ian Riddell
    Thanks again for the great photographs. It's interesting to note the 8 dip switches (top left hand corner). This suggests the device may be suitable for other cars, but the large IC labelled "FE25" kind of dashes any hopes that you might find a cheaper version of this unit on, say, a VW.
    "FErrari"?
    Note that component checks on the ECU are not recommended (for beginners). The voltage produced by your multimeter may be enough to damage some of the more sensitive devices. Indeed, make sure that you don't handle the board or touch the plug pins too much. Static electricity may damage some components. You may even have received your new chip in a bag which reduces the possibility of static electricity damaging the component in transit. Speaking of which, it seems your repairman has made it rather difficult for the next person to replace that chip again (and the components around it).
  20. m.stojanovic
    3,333
    Serbia - Niš
    Miroljub Stojanovic
    This confirms that the control panel is getting the "control voltage" (5V) supply from the AC ECU and this is why you couldn't get voltage readings on any of the pins 4-8 which vary with different position of the air direction control knob when testing with the control panel disconnected. To do this test correctly, you would need to connect the control panel to its loom and then, with the ignition and the panel "on", measure the voltages between Pin 1 and each of the Pins 4-8 and find out the voltage on which pin changes with the rotation of the air direction knob.
    But, before doing this, you should do a test to establish whether the AC ECU operates the air direction motor or not, as follows:
    1. Rotate the air direction motor using a battery (on the bench, as you did before) and position its shaft to where it would be when the air direction flap is down (feet); this would be rotating the shaft that engages the flap clockwise when looking at it.
    2. Connect the flap motor to its loom but don't plug it into the flap and place it where you can see it (it's shaft).
    3. Plug the control panel in and position the air direction knob to "feet".
    Then switch the ignition and the panel "on" and see if the flap motor will turn. It may turn anticlockwise and stop at a certain point (which could be at the "defrost" position) or it may not turn at all. If the motor does not turn, you can try switching the air direction knob to other positions and see what happens, Depending on what the motor does in this test, further investigation can be narrowed down.
  21. johnk...
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Just a thought. On my 95 the air direction flap cycles through its movement range the first time the ignition switch is turned on when ever the battery is switched back on after being disconnected.
    Qavion likes this.
  22. F355Bob
    F355Bob Formula 3
    John , does the a/c have to be switched on for this cycling to happen?
  23. johnk...
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    I don't recall, but I have spider so pretty much the stop button is always depressed and fan speed set to zero with dash vent selected for direction control. I don't know if it's supposed to do that or not, but that's what if seems to do.
  24. Qavion
    14,682
    Ian Riddell
  25. Qavion
    14,682
    Ian Riddell
    For the electronic gurus... Some data on the Dual Power Operational Amplifier chips on the HVAC ECU circuit board:
    http://www.htmldatasheet.com/siemens/tca2465.htm
    I find it surprising that these surface mounted chips can handle 2 amps. I couldn't understand how these tiny chips could drive large devices such as recirc and air direction actuators.
