New owner with ventilation problem | Page 5 | FerrariChat
Discussion in '348/355' started by Skiday, Feb 22, 2016.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,327
    Serbia - Niš
    Miroljub Stojanovic
    The chips probably have MOSFET transistors integrated in them. I have surface mount MOSFET that is about the same size as what would be one of those chips in the AC ECU if cut into 4 equal pieces and stacked like cards. This MOSFET handles 75 amps (50 amps at 100C).
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ
    14,669
    Ian Riddell
    #102 Qavion, Dec 23, 2018
    Not sure about those tiny tracks on the circuit board, though :D
    Thanks, Miro.
    It was interesting to see how those Japanese technicians replaced a failed surface mounted resistor with a regular one. I see that SMD resistors can be bought online. Not sure why they used a regular one.
    SMD resistor code found here:
    http://www.resistorguide.com/resistor-smd-code/
  3. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    I am in the process of putting everything back together so that I can try the system with the actuator wound one way and then the other to see if it will auto-set to the default windscreen position, and I spotted a fuse on a relay missing;
    So what amperage fuse should be there and what does the relay operate? You don't suppose it's for the distribution actuator??
  4. Qavion
    14,669
    Ian Riddell
    It's simply for testing the ABS system. Normally empty.
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yup as above supposed to be empty
  6. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Well I did the test where I set the actuator to one direction and started up the system, and then set it to the other direction and started the system in order to see if the system reset the actuator to the default screen position, but I'm afraid it made no move whatsoever. Other than applying power to the black and red wires to rotate the motor (which it does) is there another test to see if the potentiometers and the unit as a whole is working. I did briefly get another puff of smoke out of it again. After everything I've gone through I still view the actuator as the prime suspect.
  7. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    I also did this but no effect. When I had the fan on 0 and disconnected the control unit and started the ignition the fan was off, when I set the fan to 2 and disconnected the control unit and started the system the fan came on a 2nd speed, so it seems it remembers the last used setting rather than finding a 'medium' setting as suggested above.
  8. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Hi John. Where from and what is the part name and number.. and dare I ask the price?
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
  10. Qavion
    14,669
    Ian Riddell
    When you did your amperage/current checks on the motor, was it attached to the tambour? Maybe something in the motor is breaking down under load.
  11. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    #111 Skiday, Jan 29, 2019
    The actuator was out of the car during the test, but I can confirm that the air direction flap rotates freely. I took it today to an auto electrician and he declared it dead, not only the potentiometers, but now even the motor simply connected to the red and black. I've tried all the suppliers for a new one (including allferrariparts) but it is no longer available. I have found one second hand at £222 so they've got me over a barrel it seems. I can understand normal manufacturers giving up on parts for models over 20 years, but it is very disappointing that Ferrari give up when so many of their cars will be kept on the road indefinitely!
    When I do get a replacement, not having made a record of the position of the flap relative to the shaft of the actuator (dooh!), I see there is a mark on one edge of the socket of the flap which I would presume coincides with the mark on one side of the shaft. You would think though that as the shaft has one corner 'cut' that the socket would be the same so you can only put it back in the correct position, but the socket is a square hole allowing the actuator shaft to go in in any of 4 positions.
  12. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Hmm... Turns out to be not much of an auto electrician - I just applied 12v to the black and red and it is still working (the motor at least) contrary to what he said!
  13. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    When you get the new motor, just plug it into the harness (don't mount it) and set the controls manually to the front vent position and turn the system on (start car, what ever). The motor should go to the correct position. Then mount the motor with the actually vent rotated to that position.
    To fully test the old motor, connect an ohm meter between one side of the pot and the sweeper. Then power to motor in both polarities. You should see the ohms reading change as the motor moves. Then do the same with the ohm meter connected between the other side of the pot and the sweeper. But that puff of smoke you have referred to several time doesn't sound like a good thing.
  14. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    I must have gotten he last one. I bought it in July of last year (2018).
  15. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    John, sorry to question this but are you sure I should be checking for resistance in ohms rather than voltage? I ask only because I saw another post (sorry I can't find it to say who wrote it, it might be from another thread) which said;
    "How basically the air direction control works is that the microchip runs as an Op-amp voltage comparator - it monitors the voltage on the middle pin of the flap motor's potentiometer ("pot") and the voltage coming from the control panel's air direction switch. The range of these voltages is usually 0-5 V."
  16. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    #116 johnk..., Jan 29, 2019
    Yes, if the actuator is out of the car just apply +/- 12 V to the black and red wires to operate the motor. Don't apply any voltage to the other 3 wires. The for the pot I guess the wires are yellow, purple, and green. The sweeper should be the purple wire. If you measure the resistance between yellow and green you should get the resistance of the pot which won't change as the motor rotates. Probable around 2k or 5k ohms, I don't recall the value. If you measure resistance between yellow and purple or between green and purple you should see the resistance vary from a low value to close to the value found between yellow-green. Of course, whether it goes for low to high or high to low depends on which pair of wires are connected to the ohm meter and where the motor is when you start. The point is that the resistance should vary if the pot is good.
    When the motor is in the car and connected to the ECU a voltage is applied across the yellow and green wires and in that case you would measure the voltage between the purple wire and either of the yellow and green to see if the pot was working and the bias voltage was applied. The sweeper voltage changes in this case because the pot acts as a voltage divider.
  17. Qavion
    14,669
    Ian Riddell
    Worrying. You checked the potentiometer and the motor previously. Anyway, those puffs of smoke don't sound normal.
    It shouldn't matter. The potentiometer (variable resistance) is creating the variable voltage on pin 1 (violet-black wire). The ECU supplies a voltage on pin 3 (yellow wire) and then measures the variable voltage on the violet-black wire.
    I guess that's the one at Eurospares. At least the postage is free at the moment (on certain orders). :rolleyes:
  18. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    The actuator is out of the car. Between the green and yellow there is no ohm reading at all except when you first touch the terminals and there is a split second jump to 170ish ohm then nothing, and that's without power or with power in either direction to the full extent of rotation. Also there is no reading at all when connected to the purple and yellow. When connected to purple and green there is nothing until the pin get almost to the end of its clockwise rotation. Fully clockwise it reads 0.9ohm. As you begin rotation anti-clock the reading quickly leaps to about 190ohm within about 30deg of travel and then the reading is gone. This is the only reading I have got, but I have got it reliably every time of trying. (at least there has been no smoke now)
    From everything that's been said it would seem that the potentiometer is faulty. Yes It is only Eurospares who have s/h units. Now that we know that my unit unit is knackered there would be nothing to loose in opening it up if only to get a photo of what there is in there. I don't suppose there is any chance of even a boffin doing anything for it.
    One thing I did find curious is that while experimenting with turning the direction flap manually to see where the air came out when in different positions, is that it is far from clear cut or cleanly divided where the air is delivered it's all a bit muddled. The actuator only has 180deg of movement so all settings must be within half a rotation. With the mark on the socket pointing down (South) I got vents & screen (mostly). South-East gave vents, East gave feet & vents, North-East gave screen, and upwards or North seemed to give an equal amount of air to all 3 directions. I found that there was no position which gave screen and feet which is one of the options on the control. I must say, having found a setting that spreads the air evenly it is very tempting to set it there and leave it there forever, but I have been trying to solve this for three years now (good grief!).
  19. Qavion
    14,669
    Ian Riddell
    The green and yellow reading is showing the type of potentiometer (ohms range). Without knowing the physical construction of the potentiometer, there could be all kinds of problems. e.g. a breakdown of the resistive surface or, perhaps, the physical movement of the potentiometer is moving a broken wire or affecting a "dry" solder joint. I guess it wouldn't hurt to open up the actuator and look for obvious faults.
  20. m.stojanovic
    3,327
    Serbia - Niš
    Miroljub Stojanovic
    Obviously the potentiometer is bad. But in an earlier post, you informed that the pot was reading 2.11 Kohm between the yellow & green wires and that the resistance was changing smoothly between yellow or green to violet/black when running the motor. It seems that the potentiometer has now burned-out; the puffs of smoke were probably from its burning. This should not have happened when using just the red and black wires to run the motor, unless the PO has done some (stupid) modification inside the actuator and connected internally the potentiometer to the motor terminals (you will find out when you open the actuator).
    If you do not want to spend money on another actuator, you can do a fairly simple modification: buy a small standard 2K potentiometer (it would be better if someone who has a good spare actuator can reconfirm that the resistance between the yellow and green wires is indeed 2K or thereabouts); you could also try with a 5K potentiometer which would be safer if you are not certain what the exact resistance of the original pot is; then, connect the new external pot to the yellow, volet/black and green wires, with the violet/black going to the mid-pin of the new pot, after cutting them off from the actuator (if you positively determine that the original pot inside is burned); if then the air direction flap moves as you rotate the new pot, you can mount it somewhere and use it to change the air direction; this would, however, be "by feel".
  21. Qavion
    14,669
    Ian Riddell
  22. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    #122 Skiday, Jan 30, 2019
    You're quite right and I had forgotten that I had done that [22 Nov 2018 page 3]. (This thread is now so long it's hard to keep up with it all). This is very bad in so far as even though the actuator is now junk the fact that it was tested as working in November means (or at least strongly suggests) that a replacement will not make everything work. Looking at my actuator I think the welded four joints look factory and it has not been previously opened. I will open it up and look for obvious faults, but if nothing is revealed, now that I have found there is a setting of the air distribution flap the gives an even amount of air to all three directions I think it might be best to set it there and leave it there.
  23. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Frankly, these actuator are fairly common and I would expect you could fine one that would work. All you need is a 5 wire, servo motor actuator with correct potentiometer resistance. Something like this: https://www.dormanproducts.com/p-64237-604-006.aspx You would have to modify it a little to connect, mount and engage the vent correctly, they are about $20. I'd certainly be experimenting with one before paying £222 for a used one.
  24. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    OK, I've got it open (now and it has definitely never been opened before). The wires all connect to the circuit board cleanly, solder joints are good, no dry joints. The cogs are perfect. The smoke comes from the brush of the motor. In operation lots of little sparks come off the brush, but the brush is of a good length and is not in need of replacing. The brushes could perhaps be cleaned, but it won't affect the pot at all. I have repeated the test as above (the most recent test) with the ohmeter on the circuit board and the results are the same.
    When I said above that it is poor that Ferrari have allowed this part to be NLA, it can be said of any part, but all electric motors with brushes cannot last forever as brushes wear down, spindles foul from arcing, and cogs wear. The unit is plastic welded shut, even though they could have used screws, so is not designed to be serviced (unlike say an electric drill which will be screwed together and will often be supplied with spare brushes) so this really should be always available, but nothing will be done of course :mad:(rant over).
  25. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    You can see the motor arcing here;
    Qavion likes this.
