New owner with ventilation problem | Page 6 | FerrariChat
Discussion in '348/355' started by Skiday, Feb 22, 2016.
  1. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Given that the actuator did test ok previously for function, even though it now doesn't, indicates that a replacement will not be the solution to my troubles. This could go on forever. I've checked everything I can as much as I can and there comes a time when one must concede defeat so I have now set the flap to the place where all areas get some air and reassembled everything. But... most of my cars are much older and therefore I don't always hold with the modern car philosophy of 'Take off the bit that doesn't work and fit a replacement'. With older cars you have to be creative sometimes when parts are no longer available. So...
    As the basic motor function of the actuator is working (and perhaps I could clean up the brush and spindle for smooth operation), what if I forget about this as a stepper motor and make up a simple circuit to operate the motor? I'm thinking a three position non-latching switch which could be hidden just out of sight. The switch sits normally in the middle position, switch it left & the air direction drum rotates one way until it reaches the end of its travel and the circuit cuts the power to prevent damage to the motor. Switch the switch to the right and the polarity is reversed and the drum rotates the other way. In either direction you remove your finger when the air is blowing the way you want it to. OK, it's not working as a stepper motor any more, but it will give you more control than there is at the moment. What do you reckon? The alternative when I come to sell is do what the guy who sold me the car did, which is when it is pointed out that the air direction is not changing say "Oh, I hadn't noticed that - I'm sure that's an easy fix - I'll knock a few quid off for you"
  2. Qavion
    Qavion F1 World Champ
    14,600
    Ian Riddell
    Andrew, were the potentiometer's resistive surface and wiper arm/s visible when you dismantled the actuator? Did you try cleaning the contacts?
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    I'm lost here. Thread too long. ;) Was it established that the ECU and things like the outside air temp sensor are OK?
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    The excessive sparking from the brushes (as well as rough running sound I could hear) are typical signs of a bad motor, i.e. partial shorting in its windings so it is drawing excessive current. Trying to remember again my motor current measurement about 5 years ago, I now think it was actually about 50-70 mA when bench testing and you measured about 150 mA (which I confirmed as same as what I measured but I think I was wrong). The AC ECU probably detects this overcurrent and cuts the motor off.
    It is strange that the pot suddenly lost resistance as it is not connected to the motor in any way; possibly damaged by the previously modified wiring or it has just worn out. If the pot was good, you could probably easily replace the motor with a motor from the fresh air flap actuator but these seem to also have gone up in price (GBP 105 at Eurospares and I don't see any cheap used ones).
  5. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Just found a picture of the internals of the fresh air actuator - the motor and gears arrangement look quite different from what your video shows so transplanting the motor seems not really possible.
    In the case of my (348) air direction actuator, since my AC ECU was bad and I completely modified it with my new simple circuitry, I am running the motor using two mini relays (for the change of rotation direction) and two of the buttons (as momentary switches) on the ECU panel to activate the relays, one for up and one for down, setting the air direction by feel. To prevent the motor stalling by the actuator hitting its ends of travel, I have attached two mini limit switches to cut the power to the motor off somewhere before the ends of travel.
  6. Qavion
    14,600
    Ian Riddell
    John, the air direction flap is not going to the desired position (automatically or manually). Initially, wiring checks on the actuator seemed ok, so the wiring between the ECU and actuator (and between the ECU and the control panel) were carried out (all ok). The ECU chip which drives the air direction actuator has been replaced. The ECU has not been interrogated. Smoke has been coming from the actuator and subsequent wiring checks of the actuator have shown a lot of intermittency.
    Andrew, do you have the part number of that Johnson's(?) motor? It looks like the company is still in business.
  7. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    The fresh air flap motor actually comes in two varieties. They look the same from the outside but the guts are very different. Totally different gear train. One has a worm gear on the motor, as pictured above, the other type has a spur gear on the motor.
    As for the current problem, As I suggested pages ago, put it back together and take it to someone with an SD1 or SD2 and have a proper diagnoses performed.
  8. Qavion
    14,600
    Ian Riddell
    Andrew lives on a small island ;) How he got the car there in one piece is a mystery. Those car ferry ramps must be a nightmare.
  9. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Put it on a truck. :D
  10. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Just found my picture of both:
  11. Qavion
    14,600
    Ian Riddell
    John, are you sure that's the air direction actuator (on the right)? The air direction actuator should have 5 wires (2 for the motor, 3 for the potentiometer) and has different coloured motor wires. Your two actuators have the same wire colours (light blue-brown and brown).
    Here are Andrew's wire colours:
    https://www.ferrarichat.com/forum/posts/146306075/
  12. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    No, these are the air flap (recirculation flap) motors. What Miro was talking about in post 130. Sorry for the confusion.
    Qavion likes this.
  13. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    I have cleaned the motor contacts and the it (the motor) seems to be running OK. No, the potentiometer's resistive surface and wiper arm/s are not visible. Johnson Electric made the motor and their website says they make actuators for OEM, but the case says MES Swiss, so who made the whole thing is not clear. It would be great to know if this item was made for other cars, but Johnson make quite clear they won't deal with anyone other than OEM, and their dealers wouldn't know that.I asked Eurospares if I could return an actuator if it doesn't solve my problem and they said no returns are allowed (I suppose less scrupulous people could send back their old one pretending it's the one supplied and say it's faulty?).
    John is right, I need to get it diagnosed by someone with a SD1 or SD2. That does mean taking it to the mainland (are SD1/2 strictly Ferrari only or any other make also?). Qavion, you're not wrong about the ferry. When I bought the E-type I managed to catch the exhaust silencer on the ramp and pull it off the previous section, ever since then I've always insisted on the lower deck and taken it very carefully.
    Although m.Stojanovic's solution above sounds very similar to what I suggested. Basically circuit wise the same principle as an electric window would do it.
    Qavion likes this.
  14. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    I am doing something similar. In my case it is the heater valve that is not functioning. The actuator motor and pot are fine but the ECU isn't responding (bad chip?). But not to worry, it's a spider and I don't need heat but I want to be able to open the heater valve for coolant changes. So I'm using a window switch to energize the motor and a small digital voltmeter hooked up to the pot to tell me the position of the valve until I can get the ECU repaired (or not).
  15. Qavion
    14,600
    Ian Riddell
    There are (still expensive) alternatives to SD1/2, but I believe they don't cover all functions on the F355. Anyway, it's unlikely anyone has the alternative on the Isle Of Wight. There are companies which repair/test the ECUs, and I assume, interrogate the fault memory. However, from your description of the actuator potentiometer, I think you've pretty much narrowed down the fault.
    (Often repeated story, but... ) I bought a new engine harness from Eurospares (at great cost) and discovered it was faulty from the factory. No returns. By the way. this policy of no returns on electrical components is not unique to Eurospares. My technician spent a day and a half trying to figure out why my engine wouldn't start after a major service.. and it cost me a fortune in labour fees... and would have cost me more if I hadn't volunteered to personally test all the wiring in the new harness and fix the problem. Eurospares contacted Ferrari regarding the problem, but there was no feedback.
    As a child, my parents used to take me on holiday to the Isle of Wight (Shanklin), so I have some recollection of the ferries :)
  16. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    It's a shame they stopped running the ferry from Ryde to Sydney! :D
    But seriously, It is illegal to sell goods that are not of merchantable quality and all goods are covered by the Consumer Act whereby retailers are responsible to repair or replace faulty goods. You could have taken it further no?
  17. Qavion
    14,600
    Ian Riddell
    Possibly, but lawyers are more expensive than Ferrari technicians ) and, for me, life is too short to worry about these things. Also, after paying UKP15,000 on gearbox repairs in that same year (previous owner negligence), it was a drop in the ocean. Being a retired avionics technician, I enjoyed dusting off my multimeter and getting to roadtest my coloured Ferrari wiring diagrams )
    Anyway, we digress.
    It's rather disappointing that the potentiometer is not accessible. It's a shame it wasn't like this type (start video at 3:55) :
    WATSON likes this.
  18. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    Quite right, shame it's designed not to be repaired almost deliberately. Would you have the time to design a circuit to control the actuator? It needs a on/off/on non-latching switch and a breaker to stop the power when it reaches the end of the rotation (just like an electric window). I hope it is as simple as it sounds. I'm sure I can make it if I'm shown how. Much appreciated if you could. Thanks.
  19. Qavion
    14,600
    Ian Riddell
    That's more Miro's forte' .... I never got into the design aspect. He sounds like a busy man, though (with his new MAF project). Also, any designer would need to look at the old actuator and tambour to see what was possible. I'm not sure you could install limit microswitches inside the actuator case, and access to the moving parts inside the tambour would be impossible. You might need to install some kind of cam on an extended actuator drive shaft and mount limit microswitches on the side of the tambour.
    I'm wondering if a manually controlled blend door actuator would confuse the ECU if it sensed that air was not going in the right direction at the right temperature... and start shutting things down.
  20. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    This is a picture of the limit switches I installed at the Fresh Air actuator. I attached the switches to the heater/evaporator housing and added a thin aluminium arm (with a square hole) that goes onto the actuator's square shaft. I made the arm as a "fork" so that I could bend them to fine tune the flap end positions.
    In the case of my air direction actuator, I used a similar aluminium arm but smaller limit switches which I attached to the actuator body (on the outside). Unfortunately, I did not take any pictures. As my dashboard is dismantled at the moment (repainting my sticky vents), I will try to get a picture (if possible) of my installed air direction actuator and post later.
  21. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Why would you need them of the air direction actuator? It's a servo motor and there are no mechanical stops on the air direction vent. Rotation and power to the motor stops when the HVAC ECU reads that it is in the desired position. No?
    By the way, these air direction actuator failures are far from unique to Ferrari. Just google Blend door actuator.
  22. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    My recirc flap would not work. Like you my plastic lug was fine (see it in the pic) and the motor ran you could hear it. I pulled the motor and it spun fine both directions. So I cracked it open. When you turn the big gears with the hand I noticed sometimes it would jam, In fact I could get it to to it every time if I put it under load. Turns out some teeth chipped off and that would cause it to lock when it hit that section. The gear was so brittle I cold chip teeth with my nail and parts would get caught int eh teeth making it worse. Bought a new motor and brass lug for good measure, lubed the door and back together it went, works like a champ.
    Motors are cheap, buy a few replace every 5 years.
  23. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Because my AC ECU was "dead on arrival" - a number of the traces on the PC board were burnt and, when I re-connected them, I had one of the large IC-s getting very hot. So, I built this:
  24. Qavion
    14,600
    Ian Riddell
    I just checked my actuator potentiometer (with a Fluke meter and it was 2261 ohms. At various flap positions, the sum of the two potentiometer sections Green to Violet-Black and Yellow to Violet-Black) was 2326 ohms. Not sure where the extra 65 ohms was coming from. The Fluke meter read "0.0" with the test leads shorted together.
    No smoking evident )
  25. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Obviously, 1+1 is not 2. The difference is probably from some additional resistance when measuring to the wiper (twice). So, it appears to be a 2.2 K pot (fairly standard value) but I believe it is linear and that it has the "wipe" angle smaller than the usual ~300 degrees. The only linear pots I found that have less than the standard wipe angle are 5K 120 and 188 degrees. I don't think the use of 5K (instead of 2.2) would be an issue as the ECU looks for the voltage from the pot, not the resistance. However, the wipe angle is critical - if not identical to the original pot, the air flap would stop at wrong positions.
    The 120 & 188 pots: https://www.ebay.com/itm/B5K-5K-Linear-Taper-Potentiometer-for-RC-Transmitter-Control-120-Degree-Rotation/252527810513?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 , https://www.ebay.com/itm/B5K-5K-Linear-Taper-Potentiometer-RC-Transmitter-188-Degree-Rotation/263075940016?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
