NEW TIRES | Page 5 | FerrariChat
NEW TIRES
Discussion in '360/430' started by ferralc, Mar 28, 2016.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    #101 Need4Spd, Jul 13, 2017
    The OEM sizes make for a difficult selection. The highest acclaimed of the modern tires, Michelin MPSS and MP4S, do not come in OEM 18" sizes. The asymmetrical P-Zeros are an old design, and I personally would not use all season tires on this car due to the compromises made to get cold weather performance.
    I have been using Bridgestone RE-11s, and like them a lot. Great grip, and predictable breakaway at the limit. But these tires are no longer in production.
    Interestingly, Firestone released a new Firehawk tire last year, but no one I know with a real performance car has tried them. The Tirerack test results seem promising, however, though they were tested against what I would consider second tier tires. (Maybe I'm being a snob, but would like to see a test against MP4S.). Still, the results sound good and the price is certainly right. Note that they are said to lack feel at the limit, and were edged out by the BF Goodrich Comps in that regard. Check out the results.
    https://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=217
  2. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    How are you liking that set?
    same sizes I use
    Do you have OEM wheels?
    Rolled Fenders??
  3. Dewinator
    Dewinator F1 Veteran
    7,728
    WA
    My installer told me he wouldn't recommend the 235 fronts due to the risk of hitting a fender in a corner, and said it'd be a good idea to get the wheels rolled if you go even to 225. Of course the Bridgestones are back ordered right now too.
  4. I.T. Guy
    I.T. Guy F1 World Champ
    Jul 17, 2004
    12,926
    Canada
    Jason
    What are the rim dimensions that will fit 355 wide tires in the rear?
    Is 355 the max tire for a 360?
  5. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    No rolled fenders, sizes 275/40R18 Rears and 235/40R18 Fronts, OEM modular wheels. Like them a lot so far.
  6. RedNeck
    RedNeck F1 World Champ
    12,476
    The CSA
    Me
    Haven't followed this thread but just got a new set of Bridgestone RE760 for around 550 on closeout. Same tires I have on my Vette, very happy with them.
  7. F430_Mikli
    F430_Mikli Rookie
    Jul 17, 2017
    40
    Vancouver Canada
    I just got the new Michelin P4S on my F430. They were great during a comparison test drive in a wet/dry autocross event a few weeks ago. Hands down the best street summer tires between the Pzero, Conti Summer Ext and P4S.
  8. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    PS4 sizes not available for 360 as of now
  9. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    Not for the starfish but they are for CS wheels.
  10. F430_Mikli
    F430_Mikli Rookie
    Jul 17, 2017
    40
    Vancouver Canada
    Michelin told me more sizes are coming. Definitely worth it!
  11. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Did they say when?
    Only size in 18 is 245/40
    I love my MPSS but I really want to try the new 4S when it is time to change them.
  12. Majin_JT
    Majin_JT Formula Junior
    Mar 15, 2008
    395
    JT
    This is going to sound silly does anyone on here have a 215/45/18 89y pirelli p zero half used ? if so please message me
  13. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Hi guys I just wanted to let you all know that Michelin is launching more sizes of the new PS4S in February
    The problem is not all the sizes would be available, I requested all the sizes we have discussed here and this is what they told me
    “Below are the status on the tire sizes you requested for the New Michelin Pilot Sport 4 S tire.
    215/45R18 - Do not make this size -the smallest size in Rim 18inch is 225/40r18
    225/45R18 - Launch Feb.1, 2018
    225/40R18 - Launch Feb.1, 2018
    235/40R18 - Launch Feb.1, 2018
    275/40R18 - Do not make this size. We do have a 275/35r18 launching Feb.1, 2018
    285/35R18 - Launch Feb.1, 2018
    285/40R18 - Do not make this size
    295/35R18 - Do not make this size”
    So according to an old post of mine we have only these options, remember we have to keep a closer (no more than +/-0.015 in my opinion) diameter ratio between both axles to OEM 0.9610 (25.62/26.66)
    And also ideally the rear tire should be bigger than OEM to compensate the speedometer error.
    So with all these in consideration the matrix is:
    Front
    A) 225/40R18 25.09
    B) 225/45R18 25.97
    C) 235/40R18 25.40
    Rear
    D) 275/35R18 25.58
    E) 285/40R18 26.98
    A & D 0.9808 (+0.0198)
    A & E 0.9299 (-0.0311)
    B & D 1.0152 (+0.0542)
    B & E 0.9625 (+0.0015)
    C & D 0.9929 (+0.0315)
    C & E 0.9414 (-0.0196)
    So the winner is
    225/45R18 and 285/40R18
    And the speedometer error is compensated 1.18%
    I am currently have PSS 235/40 and 275/40 (0.9527) and I do not have ABS issues, I did however have a bit of ABS issues (too sensitive) before when I had 235/40 and 285/40 (0.9414) so options A&D and C&E Can have a bit of ABS issues.
    Or those two options I prefer C&E in order to compensate the speedometer error vs increasing it.
    All the rest are too far from OEM and in my opinion should not be considered.
    So the three options are (in order)
    1) 225/45 and 285/40
    2) 235/40 and 285/40
    3) 225/40 and 275/35
    (Actually on a personal note my rears PSS 275/40 are almost gone but my fronts 235/40 are still halfway so I most likely will install 285/40 and deal a bit with ABS being a bit sensitive until I need to change the fronts and then install 225/45 to match all 4 with PS4S)
    Hope this helps
  14. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    919
    TX
    thank you, Fernando for compiling this! This is super helpful!
  15. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    ^^^Thank you from me as well Fernando.
  16. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Well don’t thank me just yet because I made a mistake, they clearly told me they don’t make 285/40R18 so I need to redo some of the calculations (updating option E) Here they are:
    Front
    A) 225/40R18 25.09
    B) 225/45R18 25.97
    C) 235/40R18 25.40
    Rear
    D) 275/35R18 25.58
    E) 285/35R18 25.85 (update)
    A & E 0.9705 (+0.0095) (update)
    B & E 1.0046 (+0.0436) (update)
    C & E 0.9825 (-0.0215) (update)
    So the winner is
    225/40R18 and 285/35R18
    But the speedometer error will increase 3%
    I am currently have PSS 235/40 and 275/40 (0.9527) and I do not have ABS issues, I did however have a bit of ABS issues (too sensitive) before when I had 235/40 and 285/40 (0.9414) so options A&D and C&E could have a bit of ABS issues.
    1) 225/40 and 285/35 (update)
    2) 225/40 and 275/35 (update)
    3) 235/40 and 285/35 (update)
    The other three settings are too far from OEM and in my opinion should not be considered
    (Actually on a personal note my rears PSS 275/40 are almost gone but my fronts 235/40 are still halfway so I most likely will install 285/35 (update) and deal a bit with ABS being a bit sensitive until I need to change the fronts and then install 225/40 (update) to match all 4 with PS4S)
    Hope (now) this helps ;)
    I will provide the MSPN (part number) for the tires in a following post (I already requested them to Michelin)
    cavlino likes this.
  17. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    ^^^Thanks for the update, I like the 225/40 and 285/35 combo and would chose that one as well.
    I used to run 225/40 and 275/35 on my F355 and it did make it slide in the back on fast corners more then when it had 275/40 in the rear.
  18. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Thanks actually I don’t think I will have ABS issues using my already halfway worn 235/40 fronts with new 285/35
    This because they are 10/32 when new and they will be about 6/32 by that time. 4/32 of an inch per side is 8/32 overall less in diameter or -0.25 inch
    So supposedly my fronts would be 25.40-0.25=25.15 and the ratio vs the new rears will be 25.15/25.85=0.9729 making it closer to OEM.
    Disclaimer: I am using generic tire sizes for all these calculations, I have no way of knowing the exact diameter of the new PS4S (every tire is different) because those sizes don’t exist yet and they are not published anywhere. But I don’t think the difference would be too much to change the results.
    cavlino likes this.
  19. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Ok here are the MSPN numbers for the PS4S sizes we discussed, as I mentioned before I recommend the following setups:
    (235/40 MIGHT require rolled fenders and/or a wider front wheel than OEM)
    225/40R18 02717
    235/40R18 43847
    275/35R18 00795
    285/35R18 12182
    cavlino likes this.
  20. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I think combination 1 is the way to go unless someone starts making first tier tires in the OEM sizes again. I did a bit of digging and Firestone Indys are reportedly the same as Bridgestone RE-003s, so it is not a real alternative to the more premium RE-11s (which have been discontinued). I would also hesitate to get MPSS in the combination 1 sizes because MPSS are being superseded by the MP4S. Later when the weather is warm again, this means going to MP4S in 225/40 and 285/35, all 18" on my OEM starfish wheels. Probably. Depends on availability.
  21. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    I am getting combination 1 as well in MP4S, but in the meantime I will get combination 3 with MPSS in the front until I finish those tires.
    My rears MPSS are basically gone and I have been waiting for the new tires to be available, funny thing I have always thought almost gone tires would perform better than brand new due to more rubber surface in contact with the road, not the case with this compound, the more wear the tire has the harder the compound becomes and you start losing the tail pretty easy. Even on straight accelerations the car becomes “mustang-ish”
    Need4Spd likes this.
  22. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    #122 ferralc, Jan 25, 2018
    so to put everything in one post
    You can do all the combinations you want as long as the ratio is closer to 0.9610 as possible (no more than 1.5 in my opinion so 0.9610+/-0.0150, and you do not decrease the diameter of the rear tire that much or you will have a bigger speedometer error.
    The diameters for all the tires mentioned here are
    Front
    OEM 215/45 25.62
    225/40 25.09
    225/45 25.97
    235/40 25.40
    Rear
    OEM 275/40 26.66
    275/35 25.58
    285/35 25.85
    285/40 26.98
    295/35 26.12
    For example OEM is 25.62/26.66=0.9610
    so if you are planning on getting the new Pilot Sport 4S the combinations (in order) would be
    1) 225/40R18 and 285/35R18
    2) 225/40R18 and 275/35R18
    3) 235/40R18 and 285/35R18
    if you are planning on getting Pilot Super Sports the combinations (in order) would be
    1) 235/40R18 and 275/40R18
    2) 225/45R18 and 275/40R18
    first combination closer to OEM ratio but might require rolled fenders.
    NOTE all these calculations were made with generic tire size diameters, I advise to check manufacturers exact diameter to get a most accurate number, but I do not think it would make a huge difference to change the actual ranking.
  23. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    I hope this isn't too off topic, but I need tires for a set of 19" CS wheels.
    Currently wrapped in 225/35's and 285/35's.
    Is there any leeway for tire sizes for these wheels?
  24. Skidkid
    Skidkid F1 Veteran
    9,632
    Campbell, CA
    John Zornes
    That's about optimal for those wheels. What are you thinking?
  25. arizonaitalian
    arizonaitalian Two Time F1 World Champ
    Oct 29, 2010
    20,527
    Wyoming
    Many of us run 235/35 in front (the scud size tires). No issues (although that is on CS's, which might have rolled fenders, not sure on a regular 360/430). Also try the "search" function as there were (once upon a time) a number of very informative threads on going "up size" with tires. Might require some creative search parameters.
    I'm 360 Canuck likes this.
